Question about Toro Lawn Mower With Toro Power Tools
How much oil does the toro model 20070 mower hold? The manual says 20 oz, but that is way too much. After the oil was drained, only 1 oz was added and the dipstick read full. The dipstick is very difficult to read, but yes it is clean. Thanks.
  • 147 Answers
SOURCE: toro self propelled mower will not move
This is a very simple solution, When you pull the lever it simply pushes a pulley into the belt to make it tight. Most of the time the belt has come off or maybe the cable broke. Turn the mower over and you will see the belt. My money is on the belt off.
Posted on Nov 06, 2008
  • 201 Answers
SOURCE: Oil Drain Plug Location
that is the drain plug sometimes hard to get loose but should come out it is in bottom of engine above blade.
Posted on May 08, 2009
  • 10865 Answers
SOURCE: toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
Posted on May 30, 2009
  • 32 Answers
SOURCE: Toro Lawn Mower model 20016
it isn't the spark plug if it wont turn over. maybe your battery is dead.
Posted on Jun 12, 2009
  • 4 Answers
SOURCE: Toro Personal Pace Mower won't start w/ electric starter
There are a couple of things you can check;
First, check to make sure the bendix is engaging. It is the gear that meshes with the fly wheel.
If it is, then try and see how fast the motor is spinning. Don't look at the blade though. It could be a faulty starter motor.
Make sure to also check the battery voltage with a volt meter. It should read at 12.0 or higher.
Posted on Mar 03, 2010
Toro Model 20070 lawn mower starts and runs, just does not seam to have a lot pf power does anyone have a lack of power issue with their Toro 20070 Pace Lawn mower. Runs fine just no balls
could be dirt in the carby , blocked fuel filter or lack of adjustment in the accelerator cable
I will go for a cable adjustment as they slip under the clamp on the carby bracket when the throttle is pull wide open
May 30, 2016 | Toro Power Lawn Mower
I own a Toro model 20070 mower with a Tecumseh engine. It's 8 yrs old. I have regular maintenance conducted. The mower starts and runs well but about 20 minutes into mowing, when I shut it down to empty...
Are you sure there is oil in the machine?
Are the Fins on the engine clean and not loaded up with sand and mud?
Sounds like it is running so hot that it is seizing.
Aug 06, 2014 | Toro Garden
Toro 22" recycler lawn mower, Briggs & Stratton engine. Engine low on oil, would not start after a few pulls. 20 oz oil added, mower started after a few pulls. Finishing the lawn when a white puff of...
Hi michael, You have most certainly put in too much oil. Try draining a bit off and then clean the spark plug with some paper towel. Leave the mower level for a few hours and then try it again.
Sep 22, 2013 | Toro Garden
I have a 2006 recycler model 20070 and am getting oil on the deck and it seems to be getting worse. Can it be a seal on the fill tube or something else? Also can you give me part numbers for what I...
If your Toro mower came equipped with a Tecumseh engine, then the dipstick seal is a common place for oil to leak. Look under the right side of the red plastic cover that is on top of the engine for an engine ID sticker. Take the model and spec numbers from the engine and go to either your local repair shop, or go to www.partstree.com for your parts. This is a simple repair and can be done with basic hand tools and mechanical knowledge. This is a good time to change to oil, too. Drain, replace gasket, refill.
Sep 12, 2010 | Toro Lawn Mower With Toro Power Tools
Oil dripping on push mower deck
maybe from spilling that would be the best case. the worse case could be the sump gasket could have a tear in it and that would have to be replaced..good luck
Apr 09, 2010 | Garden
How much oil to put in a 6.25 briggs and stratten
They hold APPROXIMATELY 20 ounces. Put in around 18 oz and start checking the dipstick and adding a little until it gets to the full or MAX or whatever it says on your particular engines stick. Each time you ad a little, give it a chance to drain down or you will get a false reading
Sep 20, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
How to change oil and where i put the oil in to the lawn mower mtd 3.5hp / 20
Warm up the engine so the oil will flow out. Push the handle to the ground and either have someone stand on it or wedge it underneath something to hold it down. Disconnect spark plug!! Remove blade. Place a drain pan underneath mower (one that's shallow enough to lower the mower down on) and using a 3/8 extension on a ratchet, stick the square end of the extension in the drain plug in the bottom of the engine and unscrew. Lower mower back down for a couple of minutes then reverse proceedure. I think it holds about 20 oz. of oil. Put in 18 oz. and check it. Be sure not to overfill.
Jun 03, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Toro Lawn Mower With Toro Power Tools Logo
474 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
