Question about Epic 425 Mx Treadmill EPTL88105 !
It powers on at high speed and then immediately spots
It powers on at high speed and then immediately stops. If you shut down and restart it again starts at a very high speed and then stops.
Also how can i get a workshop manual
    President:
  • Epic Master
  • 832 Answers
Its sound like either a speed sensor not functioning may need adjusting or replacement refer to your owners manual on page 25 and 26 for this procedure. Now if you complete the adjustment and have the same problem, then you can test this sensor by using a multi meter on continuity setting follow the black connector to the lower board disconnect it and place leads on to connector MAKE SURE you have a good connection when testing. Then move the running belt and the front pulley which has a magnet, have the magnet move back and forth this will open and close the sensor circuit if good then it is the motor control board replace it, if not replace the sensor.
Posted on May 31, 2010
At night its shuts down when the therm is satisfied,but trys to restart right away and when it does start it shuts down right away and just keeps doing this
The thermostat has a differential built into the temperature sensing operation. The differential is normally a degree or more. If the stat shuts down at 72 degrees it should not start the unit again until the temperature in the room reaches 73. If the AC runs and cools properly until it shuts down, I would check the thermostat. The AC can not restart immediately after it shuts off because the pressures in the system are too high at the compressor. It takes a few minutes for the pressures equalize allowing the compressor to start. If the stat tells the unit to start under high pressure, the compressor will shut down on overload. It will start and run after the pressure falls enough for the compressor motor to run.
Jun 04, 2015 | Dometic Rooftop RV Air Conditioner
Computer shuts down
Make sure Windows Update is turned on. For Windows 7, Vista, and Windows 8 there are Updates that resolve some hardware glitches such as the one you are experiencing.
Apr 03, 2014 | Dell (6F858) Cooling Fan
Hi, I recently been have a problem with my 1998 Honda, passport. While driving my Honda it would shut down then starts again on its own while rolling. At times it would not start again on its own you need...
sure, rolling in gear you mean. (same effect as push starting a car with M/T) what speed did it restart, 5mph or 50 or 85mph.?)
what transmission. A/T or M/T? BEG ERROR there !
shut down,?
you mean stalls,
and engine can do 3 things
run too slow (way below 800RPM idle , illegal idle speeds)
stalls (rpm goes to zero or you find zero power from the engine )
if you stop the car, and the engine stalls that is an engine stall.
or run perfectly.
does your model have a tachometer to you can see RPM?
and if idle controls work,
not posting the trans type, (non body does here) makes answers near impossible. infact most will just ignore you posts.
with a M?T car the engine immediately returns (hot ) to 800rpm
and is regulated very closely by the EFI brain (PCM)
if not you are seeing IDLE control failure.
with and A/T there is no MT clutch and when you stop
the autoclutch drags (wastes fuel like mad) and puts a huge load
on the engine, stopped say at a red light. the idle controls
on A/t are greatly taxed here.
so RPM can drop real low. fail. or stall. below 800
a stall happens at about 400 RPM.
the M/T can at any time be restarted on the fly (moving)
but just dumping the clutch. or just waiting as you coast in gear.
this is how push starting any M/T car works.
but on an A/T car , on the fly restarts take huge speeds.
and only works on A/T that have 2 oil pumps.
the A/T with no rear pump , the A/T can not be push starter
or coast restarted, if the front pump is dead(engine stalled)
im not looking up your tranny spec. because you never stated, it.
my engine stalls. (not tranny slip)
1: bad 12vdc power to any EFI system component.
2: never ever tuned up per the free operators guide in glove box.
3: lost engine compression. 1 or all cylinders.
4: lost spark. (or timed wrong, early cars have distributors)
5: bad fueling. too much or too little
when the engine runs , does the MIL, CEL glow running
btw the CEL also glows, at all stalls. the lamp only means.
I HAVE ELECT power, now.... only.
Sep 11, 2013 | Honda Cars & Trucks
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
I have a Nordictrack C2200 treadmill that I haven't used for a while. I went to use it again and the motor starts then stops almost immediately. Lights are on and incline works. If I push STOP and...
hi,
You have to check the Driver circuit board for the motor. There is motor control IGBT Insulated Gate Bipolar Transistor) in this board .If the IGBT is short then the treadmill will try to run at high speed without setting any value or witout pressing the start button and will shut down . You have to check the OHMS between the seocnd and third of lead of the IGBT. If it shows less than 100 Ohms then the IGBT is short and you have to replace the same. Also you have to check the connection to the control pannel. Is there is any loose conatct. Remove the connection in the motor control board which go to the control pannel and reconnect it. Also check the speed sensor. In most of the treadmill you can find the speed sensor near the motor pully. Remove the speed sensor and clean it and the refix it. Remember one thing remove the power of the treadmill and leave it for 30 minutes then only oppen the treadmill. Because there is high voltage storage capacitors in the motor control board which will hold charge for some time even after the power is disconnected. i have added the picture of IGBT for your refference.
OK
Aug 18, 2011 | Exercise & Fitness
My question is, last night, I set the speed to 5mile/hr, the treadmill automatically stopped after 12mins( the belt stop, power was on). and I can not restart it immediately, Then after 5 mins, the belt...
A treadmill will shut down from to much friction which is due to high motor current because the walkbelt and deck are not properly lubricated. I would recommend replacing the motor controller,walkbelt,deck and applying .5 oz of lubricant on the deck every 3-6 months or 100 hours of use. This will extend your treadmill's life many years.
Jul 08, 2010 | Nordic Track /proform Treadmill...
My 2002 jetta tdi works great on highway until i kick it down to speed up , then it seems to lack power and if i shut it off and restart the engine it works fine again till i get up in the high rpm, is...
Could be the filter or carbon build up, which is common on the mk4 1.9 tdi's. These engines need to be driven 'briskly' to stop low quality NA diesel fuel from cloggin up the engine.
Mar 28, 2010 | 2002 Volkswagen Jetta TDI
Kenmore 800 dryer shuts down after running down to 40 minutes on the timer. When I restart it at that point it runs for about 30 seconds and shuts down. If I turn the timer back to 90 minutes it runs down...
Sounds like you may have a bad motor. If the motor is overheating it will shut down on its overload.
If its a shorted contact in the timer you could mark the spot where it stops and restart it again. It should stop exactly at that point.
Jan 22, 2010 | Kenmore Dryers
My 97 jimmy sometimes dies while driving and idling. no lights come on, fuel pump is working, is not overheating. once it dies, it starts up again immediately.
Here is the common cause of surges, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Aug 12, 2009 | 1997 GMC Jimmy
T6420 E-Machine won't/Reboot W/O F8 Key
No sync means no video signal to the monitor. The rest sounds like a corrupted OS. This could be from a number of reasons, including a virus. If you have NORTON or MacAfee, Your open to a lot of attacks. Get AVG free, and use Mozilla instead of IE.
The reason the fans come on full speed is the MB senses a high temp on the CPU, until the bios fan control takes over after POST. This is normal on most systems.
Aug 22, 2008 | E-Machines eMachines Desktop PC
Epic 425 Mx Treadmill EPTL88105 ! Logo
440 people viewed this question
Top Epic Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
