Question about HP LaserJet 3055 All-In-One Printer
Does HP LJ 3055 printer scan over the wireless network?
I have a small home office network. I have 3 laptops. 2 laptops with WIN XP and 1 with Win Vista. I have a Printer HP LJ 3055 also in that network. It is connected to a hub directly and hub is connected with the laptops through wireless network. Now the problem is I can not scan when the printer is in wireless network. But when it is connected on wired network, it scans properly. But if I set the resolution to 100 dpi and b/w scan, it scans properly , but If the dpi is increased to 150 and greyscale , it scans 3 pages and then stops. but if I keep the dpi to 150 and but in color, it says connection lost.
I am using Netgear router and helskins . Happned with both the routers.
How can I scan via wireless network using all the features , i mean using 250 dpi and color features with out losing connection? Does it support wireless connection ?
  • 1 more comment
  • Anonymous Apr 29, 2008
  • lindykid Oct 07, 2008
    connection lost.
  • Anonymous Jan 18, 2009
    my brand new MacBook Pro laptop is flawless, but HP's 3005 can't scan wirelessly. HELP!
  • 47 Answers
Scan over wireless network is not supported with this printer. You can try set it up and get scanner to work with usb and then change port from usb to HP standard TCP/IP for the device, but I don't think it will work.
Posted on Nov 27, 2008
Cant find the HP LaserJet driver on Windows 8
Go to this link, pull down to get to the WIN 8 OS that you have, and download the driver.
HP LaserJet 3055 All in One Printer Drivers
Dec 23, 2014 | HP LaserJet 3055 All-In-One Printer
HP Laserjet 3055 driver
Good day, driver are provided with the links below.
Drivers and software MAIN
Drivers and software Win7 32 bit
Drivers and software Win7 64 bit
Drivers and software Win XP 32 bit
Drivers and software Win XP 64 bit
Just click the link and click download button, hope this helps.
Thank you for posting.
Jul 05, 2011 | HP LaserJet 3055 All-In-One Printer
I want to share an HP 7760 on an XP with Win 7
To get ahead of myself and answer your question first, your Win 7 machine may automatically load a driver for your shared printer.
Please have a look at the procedure below: (these instructions assume that your XP machine is sharing the HP printer and that your Win 7 laptop can "see" your network and the shared printer connected to your XP desktop computer)
On the Win7 machine, follow these steps:
1) In "Control Panel" click "Add local printer"
2) Create New Port > Local port
3) Port Name is "\\xpcomputername\printername" - without the quotes
(insert the XP's real network name and your printer's real name in the above location)
4) Click <OK>
5) Windows 7 should automatically load a driver allowing you to print on the HP connected to the XP from the Win7 laptop.
I hope this helps!
Mar 07, 2010 | HP PhotoSmart 7760 InkJet Printer
I need a 64 bit Canon D780 printer driver...where can I download? I went to canon, but their drive is only a 32 bit
Okay so this may not help you now, but I just got a hand me down D780. After much frustration and research here's the solution that I was able to work with. It isn't perfect; but it's something....
So here are the steps for network shared installation; assuming your D780 is installed on an old xp desktop and you're using a Win-7 laptop. If you're using the printer directly on your Win-7 machine, just use the local printer installation after the XP mode has been installed.
1) You'll have to install WinXP mode on Win-7 using the steps listed on this link. If you have a genuine Win-7 copy installed, this download and installation is free, courtesy Microsoft.
http://windows.microsoft.com/en-us/windows7/products/features/windows-xp-mode
2) After installation, you'll have to change network settings for your virtual pc. This step is necessary if you want to be on the same home network and want to see the printer! Never mind if you don't understand this logic. Just follow the steps and you'll do just fine. To change the network settings in vPC: click Tools; click Settings; select Network from left; then for Adapter 1 choose the actual network adapter connected to your router (simply put: select the wireless adapter or wired adapter you're using to connect to your actual router or home network. You can find that from Change Adapter Settings in Network and Sharing.) Click Ok.
3) Now add the printer as local or networked following your usual XP steps. You should be able to see the printer. If not, open a command prompt window, check your ip to make sure you're on same network. If not, or if you don't know how to do that, just type in ipconfig /release enter and then ipconfig /renew enter. Try to connect to the shared printer by pinging the ip of the host computer. If the ping works, you should be able to see the printer then.
Connect printer and use in XP mode. Not the best solution, I know. But it's free and at least lets you print from your laptop, given the circumstances.
Feb 21, 2010 | Canon imageCLASS D780 All-In-One Laser...
My printers that are on my wireless network won't print
Did you define the printers and printer ports to the laptops?
On the XP laptop go to network connections in the control panel and use the network setup wizard.
Jan 01, 2010 | NetGear WGR614 Wireless Router
Five computers networked with Linksys WRT320N router. Operating systems: Win 7.0 on 3 computers (two hardwired)(one laptop - wireless), Snow Leopard 10.8 on 1 (wireless), and XP on one (wireless). Also...
Sometimes this problem occures when you install a later model wireless router.
Try installing the latest Wireless card driver on the XP computer and the LAN card drivers on the other computers except the MAC.
Dec 31, 2009 | HP LaserJet P2015n Printer
I got a Netbook, I have been using wireless internet in my home for years but cannot connect to internet with new computer.
In order to connect with the wireless router u need to scan for the available wireless networks in the range .
So if u r using Win XP ,
1. Rightclick on the wireless network connection.
2. U will see view available wireless networks..
3. u will see ur network name
4. enter ur security key
5. Connect
Or if u r using win vista :
1. click on start
2. Connect to wireless network.
5. Connect
In case u need further help , feel free to get in touch .
Nov 24, 2009 | Computers & Internet
HP LaserJet 3055 All-In-One Printer Logo
2,151 people viewed this question
Ben Johnson
