Water only gets warm on s plan system? - Heating & Cooling
  • Heating & Co... Master
  • 2,840 Answers
Valve could be jammed on water side thus not getting heating
Posted on May 30, 2010
Home comfort protection plan
Direct Energy knows that maintaining your Texas home is essential to your family's well-being. You can't afford to put off protection until disaster strikes, so we've created protection for your home's electrical, plumbing, and heating and air conditioning systems.
Our home protection plans deliver security by combining preventive and repair services for your home's most fundamental systems, including:
Electrical wiring
Plumbing lines
Priority scheduling with us for all appointments
Surge protection
Heating and cooling systems
Our home protection plans remove the anxiety of unanticipated costs, while our certified technicians are ready to assist you with respectful, professional service and high-quality equipment. Because we view the money you spend on home service improvement as an investment in your home and your comfort, we're committed to helping you make it worthwhile. You can choose from our plans for Heating and Cooling systems, Electrical wiring, and Plumbing lines. Direct Energy's Repair & Maintenance Essentials Plan provides annual features to catch small service issues before they become critical, $500 insurance for every repair job*, emergency customer support any time you need it, service visits with no charges and no deductibles, and so much more.
if you want protect your roof leaks so you can apply EPDM Coatings :
Watch Corporate Video
Jan 20, 2014 | Audio Players & Recorders
Www nokia repair com
If you have an accidental damage protection plan with your carrier, you can get your phone replaced. If you don't have any replacement plan, you'll probably end up having to replace your phone. Phone's don't like to be dropped in water. If you have a memory card with data on it (pictures, videos, contacts, address books, etc...) you can remove the memory card from the phone and keep your data; most memory cards are forgiving of water immersion.
Jul 27, 2013 | Cell Phones
How do I know whether a thermoelectric cooling system is better for me than a compressor?
This depends on several factors: how much wine you keep on hand, where you will be putting the cooler (cool/warm room in the house) and if you are buying a freestanding cooler/built-in. If you never have more than two cases, plan on keeping the cooler somewhere it won't get too warm and you want a freestanding cooler, you should look into purchasing a thermoelectric cooling system.
Jul 31, 2012 | Furniture
How to design and calculate the solar heat panel for hot water system for the concentrated 100 nos. staff toilets and changing rooms of commercial building in Beijing. What is the basic and ancillary...
Usually toilets do not require hot water.
Is the plumbing divided into hot and cold water pipes?
If toilets are hooked to hot water, how many flushes and how many gallons per flush per day.
What is the expected consumption per each worker?
What is the latitude from equator, and expected solar input. Further north, and hazy atmosphere reduce input. Beijing has smog I believe.
How often is the solar panel going to cleaned of smog and dirt for maximum collection?
If the area has hard water, then the entire system is prone to sediment build-up and failure unless water is artificially softened.
Solar water heater temperatures can exceed 180 degrees at times. This temperature will damage storage tank that is not made for that temperature.
Most solar water heater systems have pressure regulating valve and expansion tank to accommodate occasional high temperature and pressure.
A good fellow to contact might be at following website:
http://www.builditsolar.com/Projects/WaterHeating/water_heating.htm
Solar collectors are usually connected to a circulating pump, and then the heated water is stored in a tank.
The pump circulates water continually from solar collectors through a storage tank.
This type of system would use ordinary tank-type water heater for storage.
Most of these systems also utilize a back-up heating element inside the tank.
More complicated systems circulate special liquid through spiral tubes inside the water heater.
This type of heater would be an indirect water heater.
Indirect heaters are used for solar collectors, and used with boilers, or any outside heat source.
http://www.bockwaterheaters.com/Products/products_coil_tank_water_heaters.html
http://www.hotwater.com/products/residential/cirrex_solar.html
http://waterheatertimer.org/images/solar-water-heaters-on-roof_lbiRv_5784111-500x282.jpg
Oct 05, 2011 | Water Heaters
I have a 2000 nissan xterra my heat dont warm up i change my thermo stat if i get my heater core flush what are my chances of it working what are the major problem with the 2000 nissan xterra i done...
forget all the above items you mentiond,the heater metrick/core should be ok if you put a cooler flush through the system,im looking at the thermo switch mounted on the top of the water system it will have two wires on it and tells the engine when to let hot water through the core,also if its not working the engine will not perform great so try this and forget about new spark plugs/wires/coil pack ,as these are nothing to do with heating.adrian,,,
Dec 31, 2010 | 2000 Nissan Xterra
My Brada washing maching keeps displaying "NF" in the middle of every load..what does this mean and how do i fix it??
NF means "No Fill".
I was getting that code too, but we only had the cold water hooked up. I hooked up the hot water and I have not received the error since. I still only wash with cold, which is strange.
Aug 10, 2010 | Washing Machines
2000 JETTA OVERHEATING AT FIRST IT WAS LOSING WATER SO WE REPLACE THE HOUSING PIECE ITIS PLASTIC AND WAS CEACKED. nOW ITS JUST GETTING HOT NOT LOSING WATER
Your water pump impeller has probably come apart, you will have to do a timing belt job to get a new water pump in there. If you are not comfortable with that, take it to a shop. But yes, to check for water flow, pull the return line on the coolant bottle (little one on the top) and hold it so any water that would come out would go into the bottle, and start the engine (the engine has to be cold to try this test) there should be an almost immediate flow of water, if no water comes out, even if you give it a little gas, (should be a decent flow, not a trickle) than your water pump is in fact dead, very very common problem on 1.8 & 2.0 Jetta's, Beetles, and Passats.
Jul 07, 2009 | 2000 Volkswagen Jetta TDI
Whats a y plan when plumbing?
s plan is upstairs and downstairs theromstats
more valves
y plan just 1 three port valve
Dec 12, 2008 | Tomtom GO 510 GPS Receiver
Steamer on gaggia titanium
a. Possible air in the system. Switch to hot water iso steam, let warm water pas for a minute by turning the knob fully open. Stop tapping warm water (close the knob) and switch the machine to steam iso water. Try to get the steam by fully opening the knob (pump should start running).
b. Solidified milk in the system blocking internal tubes. To avoid this always purge the system (shortly open the steam to an empty cup or a towel) after you steamed milk to avoid milk being sucked back into the system due to condensation of steam (this creates a vacuum and reverse flow). To resolve the blocked tubing: clean the nozzle and try flushing the system (tapping warm water).
Aug 24, 2008 | Gaggia Titanium Espresso Machine
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
