Question about Schumacher & Fast Charge Starter Charger
When Charging a battery with charger do you set it on the 12 Volt 2amp or or 12volt,6amp My Charger is SE-82-6, H943
  • 843 Answers
For charging a car battery that is run down, use the 6 amp setting. The 2 amp setting is for smaller batteries (like a motorcycle or lawn mower battery) or if you are using it to maintain a charge on a battery that is used infrequently (like a boat battery).
Posted on Jun 01, 2010
What volt charger do i need to charg mower 12volt battery?
Doug, Any 12 volt automotive charger will work for your lawn tractor, the cheaper no frills chargers will work fine.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Battery Chargers Canadian Tire
Amazon com Battery Chargers Jump Starters Battery Chargers Portable Power...
Car Battery Chargers
Feb 27, 2016 | Cub Cadet Garden
I have shumacher se 82-6 battery charger and iam trying to charge my Chevy s-10 battery that is a interstate model mt-75 what setting do I put it in 6v 6a or 12v 2 a or 12v 6 a please help
12 volt 6 amps to quickly charge it from dead/flat or very low.
12 volt 2 amps as a trickle charge to maintain the battery when you are not using the vehicle for an extended time.
Nov 06, 2015 | Cars & Trucks
I WANT TO CONVERT MY SCOOTER FROM 36 VOLT TO 12 VOLT HOW CAN i CHANGE MY 36 V. CHARGER TP 12 VOLT
This will need a motor change as well which is a pity and pressume that you have looked into that already.
Simply if you already have 3 12volt batteries you can charge in series and use just one in scooter or you can purchase a ordinary car 12volt charger for a cheap price an there are advanced units that give good deep charge automatically
Nov 07, 2014 | Health & Beauty
Batteries run down within 10 minutes after full charge
Either the charger is bad or the batteries are too old. If the batteries are allowed to go dead completely the 24 volt charger will not recover. You'll need to seperate the batteroes and use a 12 volt automotive charger to charge the batteries. Make sure the 12volt charger is able to charge gell cell batteries. Not all will.
Aug 04, 2013 | Pride Jazzy 1113 Power Chair
I need to know how to wire the batteries together on my shoprider jimmie chair so they will charge
If the charger is 24 volts and you have 2 12 volt batteries they have to equal 24 volts , so wire the batteries terminals red to black and connect the charger to the other terminals red to red and black to black.
Feb 10, 2012 | Shoprider Jimmie Power Wheelchair
How long does it take to charge CCA 7000 battery ( car ) when I use SE-2158 battery charager wih 2 AMP/12 VOLT
2amp 12 volt is a slow charge it will take about 6 or more hours. when the needle on charger is down in green to full charge its fin. hope this helps
Sep 13, 2011 | SE3010 2003010 Amp Manual Starter and...
How do I know if my battery is bad or if my charger is bad? The red light on my charger no longer lights up when I plug it in. This is for my Black & Decker Firestorm 12volt drill. Thanks
With a multimeter set it to 12 volt dc and place the leads on the two parts that would be touching the battery. If you see voltage then it is a bad battery.
-David
Nov 08, 2010 | Black & Decker Black And Decker 12 Volt...
Meter Explanation
You are correct on all accounts. A high number means you dying battery is sucking more juice from the Schumacker. A low number means the battery is not as thirsty. That's how I always think of how to read the meter on mine. Slow charge is a better, deeper charge. The quick charge will get you going, but you should maybe follow it up using the normal mode - car alternator and prolonged drive time. I never use quick charge, personally.
Apr 26, 2009 | Jeep Grand Cherokee Cars & Trucks
I need to know what battery in float mode means on my battery charger. It doesnt say and its a smart charger 2amp 6amp and 12amp charger.
Float mode on a battery charger generally means that battery has been fully charged at a faster rate, and the charger is now maintaining the full charge, without overcharging the battery. You can usually leave the battery connected to the charger indefinitely - float mode will ensure it is always at it's peak charge.
Please rate if this helps :)
Mar 05, 2009 | 2003 Ford F150 Regular Cab
Schumacher & Fast Charge Starter Charger  Logo
755 people viewed this question
Top Schumacher Electrical Supplies Experts
D. E. Hev
Are you a Schumacher Electrical Supply Expert? Answer questions, earn points and help others
