Question about Canon PIXMA MP160 All-In-One InkJet Printer
Printer the paper is put into the feeder correctly but when it's fed through it pulls to the right and ends up jamming very aggressively. it worked fine and then all of a sudden it began doing this
  • joann colwell Apr 10, 2008
    thanks everyone for helping me fix my printer. there was something lodged inside the paper feeder that I couldn't see but I tilted the printer and it fell out. everything is working great.
    from mojo4
  • ad-tapia Sep 23, 2008
    We can't print the paper folds on the left hand side and then it goes back up.
    Scholar:
  • 29 Answers
Don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
someone replied to my problem, i tried it and it fixed 1st time. seems to of worked for others to, not always 1st time but it seems to reset the sensors or something
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
let me know how you get on, Garty
Posted on Apr 10, 2008
Paper jam paper not being fed into the printer
open all access panels and check for paper jams....
Sep 06, 2012 | Lexmark X6675 All-In-One InkJet Printer
The paper will not feed properly into my mx320 canon printer. It pulls the paper in on the left side but not the right side. I can see no paper stuck anywhere on the rollers. I have removed and replaced...
The mX320 being a rear sheet feeder model can suffer the problem of something falling into the feeder and causing the paper to jam on entry.
To find what has fallen in your will need to gently pull back the fed paper and look at its leading edge. This will show a heavy "Nick" in the edge. observe where the nick is in relation to where the paper is fed and that will indicate where the obstruction is in the feeder. Use a bent paper clip (L shaped) and see if you can feel and dislodge the culprit. Remove the ink cartridges and turn the machine upside down and give it a good shake. hopefull the drawing pin/paper clip/notice board pin will fall out and the world will be at peace once more.
Good luck.
Aug 07, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Paper jammed while trying to fax through the feeder. Help
turn it off slowly work the paper out by pulling it slowly from the direction you fed it or by whatever direction you find it will come out the easiest. If it tears you be patient and work out pieces you aren't the first person that ever jammed paper in a fax just take patience to get it all out.
Jul 04, 2011 | HP OfficeJet 7310 All-In-One InkJet...
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Top feeder jam
    Yes. When removing a jam, it is never wise to "aggressively" remove the paper, as it can break switches, gears, etc. maybe any switches or gears had damanged, need replacement of that parts.
    Feb 25, 2010 | Samsung SCX4824FN Mono All-in-One Laser...
    Canon mx300 printer feeder pulls unevenly causing paper jam
    the left side of the printer pulls the paper causing the printer to jam when trying to print
    Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
    MP390 paper jam at feeder
    First thing that comes to mind is that SOMETHING you (or someone) fed in, had a paper clip, staple, crinkle or some other unnatural thickness on one side of the paper - and it's stuck inside the feed mechanism.
    I had the same exact thing with the feeder on my shredder. You have to get right inside you printer to find the problem.
    Watever it may have been probably got stuck in the paper path so EVERYTHING from that point on gets skewed as it gets sucked into the printer and jams.
    Can you get "IN" to clear the path?
    Mar 30, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
    Hp officejet 7310
    please check gear train and confirm no broken one-check of selonid not working in a right way and no foreign object droped inside(like pins).-check of smoth actuation of paper present detector.(in place and movement when you put papers
    Mar 01, 2008 | HP OfficeJet 7310 All-In-One InkJet...
    Paper will not feed
    These are basically throw away printers. But you might try checking the paper path. There are small plastic "arms" that guide the paper as its picked up and goes throught he printer. Sometimes one of these may get stuck in a position that makes the printer think there is paper in the path somewhere.
    Mar 19, 2007 | Apple Epson Stylus Color 777i InkJet...
    Canon PIXMA  MP160 All-In-One InkJet Printer Logo
    46 people viewed this question
    old marine
    old marine
