Question about Dell PowerEdge 1800 Server
Dell poweredge 830 sever
Does not boot into windows. there is a blinkng amber light , should be blue. Over the weekend the server must have had a hickup. ive tried to swith slots and that does not work . Is it my hard drives, or mother board , or ??? help. Thanks Mark
  • 3 Answers
You must figure out if there is a harddrive controller running the drives. If this is a striped array I suggest calling support. Pulling all drives and it gets through the POST process the board is fine. Do not swap HDD slots unless you suspect a backplane failure. Most modern controllers support drive roaming, but why chance it....(if you have a hotswap bp)
Posted on Apr 09, 2008
Does anyone have the diagnostic code key manual corresponding to the A/B/C/D lights on my server tower? I can't find it anywhere online.
What Dell system do you have? The OptiPlex light diagnostics are given here: http://www.dell.com/support/article/us/en/19/SLN284978/en . Prior to 2005, they used the ABCD labels. This site, http://www.pctechbytes.com/dell/dell-diagnostic-lights/ , has some of the common codes. As far as I know, the Poweredge 830 didn't use these diagnostic lights.
Later, Dell switched to numerically labeled lights. For the T3610 and similar workstations, the lighting codes are given here: http://www.dell.com/support/article/us/en/04/SLN288973/en?c=us&l=en&s=bsd&cs=04 . For the R200, see http://www.dell.com/support/article/us/en/04/SLN293264/ . Scroll to the last section.
I hope these help. Otherwise, please post a comment your server model and the light combination that you are seeing. I may be able to assist you with the error code.
Feb 11, 2016 | Dell PowerEdge 830 Server
Complete backup of Dell PowerEdge 830
make sure to 'take ownership' of all files with your Windows 2008 account before transferring. (or your AD account if you guys use AD) note: you can only do this with an adminstrator account. Take Ownership of File or Folder
Apr 17, 2014 | Dell PowerEdge 830 Server
My dell poweredge 1800 doesnot boot, it gives an amber light after turning on . I have tried to remove the Ram but still the problem persists
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard.May also be caused by a defective card installed in the motherboard, i.e. video card.
Jan 31, 2012 | Dell PowerEdge 1800 Server
Dell poweredge 830 server orange flashing light instead of solid blue. No fault on screen. any ideas?
its the cover switch. there is a small push switch on the front panel that detects if the front cover has been removed, either the switch is defective, or the cover is not seating properly to close the switch.
Jun 09, 2010 | Dell PowerEdge 830 Server
Dell poweredge 1650 is beeping with blue flashing light
Flashing blue light is harmless - it simply means the Identify button has been pushed. There is a small button with a white, cursive 'i' on the front and back of the server - pressing this will make the light flash blue (or make it stop).
Go to Dell's support site and view the manual for the 1650 for an explanation of the beep code - identify the pattern of the beep.
If you are still able to get to Windows, use OpenManage Server Administrator to check the Hardware logs and RAID array.
May 20, 2010 | Dell PowerEdge 1650 Server
Will not complete boot up into windows 2000. Has worked fine for years, other day there was a power outage and next day we came in and the server was blinking at the final stage of boot process before...
I would recommend you boot to your 2000 CD, load the RAID driver for the CERC, and go to Recovery Console and perform a CHKDSK /R and FIXBOOT at the command line. Sounds to me as if Windows has been damaged. Is the power light amber or blue?
Apr 01, 2010 | Dell PowerEdge 1800 Server
Dell Poweredge SC1420 won't boot up
Amber lights are typically bad.
Good news, Dell has lifetime phone support for their servers.
Write down the Express Service Code and Service Tag number that is on the server chassis and call Dell.
This is the last number I used for server support: (800) 945-3355
If it doesn't work you should be able to find a valid number at support.dell.com
I hope this helps.
Jun 11, 2009 | Dell PowerEdge SC1420 (SC1420MIN) Server
Problem
This server direct not boot by windows cd....
and u any time install window u lose the all data....because they have scsi hard drive and configuring bydefault Raid 5 ......so plz make backup before u start this prosiger.......Dell providing u lots of cd's check it this cd "installation and server management" bootable cd put this cd into your cd rom drive...and i am giving u link that how to complete install window in this server.
http://rapidshare.com/files/175988908/how_to_install__os_-_window_storage.doc.html
Sep 18, 2008 | Dell 2.8 GHz Second Processor for...
Dell PowerEdge 1800 Server Logo
1,364 people viewed this question
Alun Cox
