Question about Goldstar R1203 Air Conditioner
Is it good to close the vent or have it open - Goldstar R1203 Air Conditioner
    President:
  • 949 Answers
The vent will bring in outside air while running. If you are use the cooling keep the vent closed for the best performance.
If you are just using the fan only for air circulation and it is mild outside you can open the vent for fresh air to be pulled into your home.
Posted on May 30, 2010
What does the diagnostic code P0446 for a 2001 isuzu rodeo mean?
Hi, your vent valve has malfuntioned. The vent valve is near the tank, and has a hose to the tank and a solenoid to close it. Check the wiring/connector. If OK, try applying 12 volts directly to the solenoid. If it does not click when voltage is applied, replace the solenoid/valve.
P0446 Evaporative Emmission Control System Vent Control Circuit OBD-II Trouble Code Technical Description
Evaporative Emission Control System Vent Control Circuit Malfunction
What does that mean? Evap vent valve has only one purpose. It closes in order to seal the vent so the EVAP system can pressurize and ensure there are no leaks. Evap vent valve is usually supplied Batt. voltage with key on. The ECM's driver controls the ground, and when grounded, activates the valve (closing it). If the ECM detects a short to ground, and open,or a short to battery voltage on the control circuit, P0446 will set. Code also may refer to ECM detecting that EVAP system is unable to achieve or maintain vacuum during test.
Symptoms There will be no obvious symptoms to driver, other than MIL illumination.
Causes A code P0446 could mean one or more of the following has happened:
  • Faulty vent valve
  • Open, short or excessive resistance on Vent valve control circuit
  • Blockage of vent valve
  • Bad PCM
Possible Solutions With a P0446 OBD-II trouble code, here are some things to try:
  • Replace Vent valve
  • Repair open, short, or resistance problem in control circuit
  • Repair open, or short, or resistance problem in power circuit
  • Replace PCM
May 14, 2011 | Isuzu Rodeo Cars & Trucks
Heat will come out of the defrost vents but not out of the dash or floor vents. The car has a new 190 degree thermostat in it.Any help greatly appreciated. thanks, dave j.
there is door actuators that open/close vents to allow air to be move to the area selected. If your able go to the car turn car ignition to accessory turn fan speed all the way up then move selector to floor or face wait a few seconds and you should hear the vent doors open and close if you dont hear them that will be a good place to start.
Jan 10, 2011 | 1997 Oldsmobile Eighty Eight
Where is the vent on my Friedrich AC unit? I don't know how to close or open it.
the fresh air vent open close tab should be located somewhere along the vent louvers look at the bottem of them starting from right to left its their use a flashlight to see it good luck ..let me know /joe/
Aug 25, 2010 | Friedrich QuietMaster RS10J10 Air...
Open vent or closed vent
The vent open draws in a small amount of fresh (outside) air to mix with the air being recirculated in the house to provide an air exchange. The vent closed will circulate the air already in the house.
In most cases its a good idea to leave it open unless you have a drafty house or find it difficult for the air conditioner to keep up.
Jun 01, 2010 | Heating & Cooling
03 Jeep Liberty Sport sunroof wont close.
03 Jeep Liberty sunroof wont close. I have 4 sunroof buttons; Open, Close, Vent and ASC. Open and Vent buttons are working fine. Close button is not responding. ASC button is flashing red and green but does nothing when pushed. I have no way to get it closed
May 08, 2010 | 2003 Jeep Liberty
Jenn-Air Microwave vent grill opens and closes
I have this same problem occasionally. Pull the vent grill open and look for a white cam that rotates when the microwave is on. To the right of that cam, there are two gray switches. The bottom switch should have a red tab that pops out. When the vent grill opens and closes continuously, the red tab is stuck in. Take a flat screwdriver or tooth pick and push gently in on the red tab to release it. It must get stuck due to grease or dirt accumulation. Good luck.
Apr 20, 2010 | Jenn-Air JMV8166B 950 Watts Convection /...
Cooking a whole chicken / lamb roast
Good Evening, I love cooking with Charcoal/Wood. The bottom vents will adjust the temp, closed the coals burn slower and cooler. The top vents also control the temp, however more importantly the flavor by keeping the smoke in or out. With a roast you want low heat so I would close the bottom vents 1/2 way or so and since i like a smokey flavor of Hickory would keep the top vents closed. The key to a good Barbeque none the less is slow cooking. It also takes fine tuning, wind, breezes all effect how fast/hot the coals burn. Don't be afraid to add more coals as needed as well. Good Luck and have a great cookout. Thanks for using FixYa. Jeff
Apr 20, 2010 | Weber One-Touch Gold 18.5 Grill
Active vent keeps opening and closing though fan is off.
When the unit begins the never ending opening and closing cycle, turn the vent fan on for a few seconds and then turn the fan off. This seems to stop the active vent from opening and closing. If this is GE quality, this is the last thing that I am going to purchase. GE refrigerators are garbage and now I am having problems with a new microwave oven.
Apr 27, 2009 | General Electric PVM1870SMSS Microwave...
Should i open or close
Close the vent for maximum cooling. When you open the vent it opens a panel to the outside air and the unit cools less efficiently.
Aug 04, 2007 | Danby DAC5020 Air Conditioner
Goldstar R1203 Air Conditioner Logo
205 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
