Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
Kenmore Powermate power head not working
I have a Kenmore Powermate vacuum. The power is turning on, but for some reason, the ?power head power is not coming on. I pushed the reset button, but nothing happened. Prior to this, I had tried to open the unit to check the bag. The power cord at the front (where it opens) did not detach itself, so I manually unplugged it and then plugged it back in after checking the bag. The suction unit on the handle works, but the main vacuum doesn't. Help! (Thanks!) Vacuum is a ten year-old Powermate.
  • 2walls May 03, 2011
    Thanks, I appreciate the input, and I think you are right that it was from the design, as it quit working after being opened to change the bag. I'll confess that I took the money I would have invested in repairs and parts and just bought a new vacuum. We still have the old one, so I might tell my friend who does electrical tinkering about your idea and see if he would like to have it. Good luck w/ your repair!
I've got the same problem. Try checking out the electrical connection where the hose attaches to the canister. The hot male terminal is corroded and the female socket is burned out. Its an unfortunate design flaw that every time you open the vacuum to replace the bag the electrical connection disconnects and reconnects. Not sure if I can find replacement parts for a 10 year old vacuum or if a home-made re-wiring job is in order. Will find out tomorrow.
Posted on May 02, 2011
  • Rozz May 02, 2011
    Parts cost: female wiring harness $21.99, male wiring harness $21.99, hose swivel with electrical contacts $46.95 (probably don't need this last part unless more burned out than just at the contacts). A bit pricey. For that kind of money, I am considering a simpler solution:
    - sand down the male contacts (assuming in not too bad shape). Do the same for the female contacts but use wirebrush in the holes. If in too bad a shape, then cut harness open to expose contact and clean. Just cut a small **** in the plastic so you can easily (and safely) cover the **** with electrical tape after repair. If it's really bad, you might have to cut it clean open and actually solder the connections together.
    - cut female end of harness as to splice in another 10-12" of wire (use same or heavier gage of wire, preferably a length off a scrap extension cord).
    - the intent is to permanently connect these the male & female harness connections and the extra length of wire will allow for the compartment to open to replace the bag. This approach would avoid future poor connections and burning/corroding of terminals to happen again.
    Good luck.
    Thanks for the info. I think you are totally right about design causing the issue, as mine quit working after I had opened it. I decided to take the repair money and invest in a new vacuum. I still have the old one, so I might ask my friend who does electrical tinkering if he would like to have it and pass on your suggestions. Good luck w/ your repair!
I have a Kenmore 116.27814702 canister vacuum where the powermate power keeps cutting off when turned certain angles. What part do I need to replace?
#1 Sounds like it might have a loose wire connection; #2 may be s bare wire touching inside and causing a short. Turning at angles may be causing the on and off of the power. Hope that helps
Feb 04, 2018 | Vacuums
POWER HEAD DOES NOT WORK
Hi, I have one of these. There are 2 possible reasons. 1. The fuse blew....in your manual you will see that on the power head is a button...press it is with an object like a paper clip. It resets the power head. 2. There is thread tangled in the brushes, keeping it from moving.
Make sure all is connected properly.
Jul 25, 2011 | Kenmore 23913 Progressive PowerMate Bagged...
Burning smell. i think the belt is broken. how do I fix it?
Turn the power head over and you will see (2) screws. Remove the screws and the top cover will come off and you can get to the belt. Here is the belt you need:
Kenmore 23812 Belt
Feb 06, 2010 | Kenmore 23812 Progressive PowerMate Bagged...
When using the vacuum (25812) with the powermate, the power shuts off - now it just stays off. The PM Jr. works.. could this be a problem with the wand rather than the powermate unit?
Check your lower and upper wand connects for pinkish or blackened evidence of burning. All connections should be shiny clean brass. Polish with wet dry # 600 paper or a scotch abrasive dish pad.
If the junior runs, with its tighter, cleaner less used connections it is very likely the wand connections and mating component, either the hose handle or power head elbow are also burned or badly worn. On a Kenmore, due to the weight of the head and mediocre design they wear in pairs and should be replaced in pairs. You can get some electrical parts thru a Whirlpool FSP parts center or a Panasonic dealer if you take in the matching pieces for clarification
Nov 01, 2009 | Kenmore 25812 / 25813 Progressive Bagged...
Power head for Kenmore Canister Vac
Another potential problem for the increase in difficulty in turning the beater bar (drum) could stem from extremely dirty bearings, located at each end of the beater bar. I've seen hair knotted up to the point it chokes the bar and significantly reduces its ability tpo turn.
Mar 11, 2009 | Kenmore Whispertone 29512 Vacuum
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
2,344 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
