Question about SanDisk Sansa e260 MP3 Player
The software on my sansa e260r is completely gone, when i start it up it reads" load main image failed, switch to recovery mode
  • 820 Answers
Firmware on the player can be reinstalled in 2 METHODS.
In both methods the player should be in USB connection mode MSC = recovery mode.
How to switch the player into MSC mode:
0. Player not connected to a computer.
1. When the e260R is not OFF, on the player press and hold the
Power/Menu button for 15 seconds to turn the device completely off.
2. Slide the Hold switch, so the orange portion shows.
3. On your PC, double-click My Computer
4. On your Sansa player, press and hold the REC button while connecting it to the PC.
5. Release the REC button when a 16MB-FORMAT drive partition appears under My Computer.
On a computer running Windows, you can use the Sansa Firmware Updater to get an automatic download of the firmware for the e260R.
How to use the Sansa Firmware Updater [METHOD 1]:
http://kb.sandisk.com/app/answers/detail/a_id/306
If not installed yet, get the Sansa Firmware Updater to download:
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
Right click the link above and Save target as... ; save the Installer to a location on your computer, install and run the updater on your computer. Select Firmware in the updater and Download Now, to start downloading the software for the player.
When you prefer to download manually or if you have another operating system, the firmware can be downloaded from the forums site [METHOD 2]:
http://forums.sandisk.com/sansa/board?board.id=e200R
Posted on May 30, 2010
When i power it up it is reading at the top of the screen load main image failed switch to recovery mode then it just freezes
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...Go to your start menu programs go to sansa choose Sansa updater follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......recovery mode lock the sansa hold center button in and push and hold the start/menu button until recovery mode....Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Dec 21, 2010 | SanDisk Sansa e260 MP3 Player
Not getting started..
Recovery Mode: download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa. http://www.youtube.com/watch?v=_95hLqZxCHc&feature=related here is a link to a kid showing you how to goto recovery mode.
Update software from this link..
and install the software before you recover
Jul 02, 2010 | SanDisk Sansa e250 MP3 Player
My e260 is saying "load main image failed switch to recovery mode" what that means
Load main image failed, this is a firmware error, (this does not have software like a computer)
Recovery mode, the player tried to recover from the error.
The player has firmware updates that where put out by the MFG because of problems.
You have to read the manual, carefully and follow it to the T.
because you need to update the firmware on the player.
This is there website.
http://kb.sandisk.com/app/home
Feb 08, 2010 | SanDisk Sansa e200 MP3 Player
Sandisk sansa e260r
if you still have the software that came with it (and installed) plug your sansa into your computer....the software should recognize it...then look for a button that says "repair" or "format" im not familiar with the exact program but i know your problem all too well...*shudder* what that will do is it will REMOVE all the songs from the sansa...but if their still on your computer you should be fine...then it reinstalls the firmware(the codes and software that make it work) then you just have to re-addall your music and your all set :) if this doesnt work feel free to repost here :P
Feb 05, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e280 Main Image Wont Load Problem, Plus firmware updater doesn't work
Do not worry! I had the same problem as you before and got it fixed perfectly! Go to this thread and read the instructions carefully.
http://www.anythingbutipod.com/forum/showthread.php?t=11233
Note that doing this will delete all files in your player, so I recommend you to save your files somewhere before doing this.
Dec 28, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e200 load main image failed
i'm thinking that it has too much info on it, so it ets stuck when you turn it on.
Jul 31, 2008 | SanDisk Sansa e260 MP3 Player
Load main image failed Switch to Recovery mode
Use the Sansa Recovery Tool on the Sandisk website
Jun 01, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
359 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
