Question about PfaFF Creative 7570
Loops of thread on top of quilt when doing stippling embroidery
  • 201 Answers
Could be caused by any number of things, but I would make sure your threads - upper and bobbin - are threaded correctly. Most importantly, use the free motion (darning) foot and even more important - be sure to put the presser foot lever down, but not all the way - it should rest on the little "shelf" so that it is hovering above your work. If you push it a little towards the rear of the machine while you are lowering it, it will find the shelf. And drop your feed dogs. You need to open the bobbin cover to locate the sliding lever to do this.
Posted on Jun 02, 2010
Can I do stippling on my 400xl
This is free motion quilting. There are a ton of web sites and videos available. You'll need a darning or free motion quilting foot for your machine. Drop the feed dogs. If you are certain you want to do free motion quilting, a Supreme Slider helps you move the fabric.
https://www.amazon.com/Supreme-Slider-Motion-Machine-Quilting/dp/B007XGITA2
Learn How to Free Motion Quilt Stippling
How to Free Motion Quilt on Regular Sewing Machine
Free Motion Quilting for Beginners 10 Tips
Free Motion Quilting Beginner Tutorial 1 of 4
Mar 07, 2017 | Sewing Machines
I have a Pfaff hobby 1200. When I try to quilt ( it is on an Inspira frame) it sews fine on the top but the bottom side is all loopy. What are the correct tension #'s I can use? I use cotton thread.
It could be a variety of things. Be sure you are using a brand new sharp needle (try a topstitch, embroidery, or microtex needle on woven cotton). Be sure the needle eye is large enough to accommodate the thread weight. Different needles have a different scarf (the groove that is on the back of the needle that runs up from the needle eye). A larger scarf will protect the thread and keep the thread from hanging up on the fabric when the needle is withdrawn from the fabric.
http://www.schmetzneedles.com/all-about-needles/
Also, the upper tension may be too loose if it is still showing loops under the fabric.
Another cause is the fabric being stretched too tight on the frame causing trampolining.
http://www.kimmyquilt.com/tensioning-the-quilt.htm
Frame Quilting
Nov 25, 2016 | PfaFF Sewing Machines
Upper thread get s caught under the needle plate when free motion quilting. Forms a loop and the fabric can't move.
change the needle
clean under the needle plate & in the bobbin area for loose threads & lint
rethread the machine top & bobbin
Mar 16, 2012 | Husqvarna Sewing Machines
Why when i put the feed cover on i cant move the fabrice at all there is no room between the foot and the cover. i am trying to quilt together my quilts. thank you brenda g
I'm assuming your machine has a little plate you put over the feed dogs rather than a knob which disengages the feed dogs from moving to do free motion embroidery or something.
If this is the case there probably isn't enough room for your quilt sandwich under the foot.
You could try using a free motion embroidery foot rather than the regular foot with the feed dogs up and see if that allows you sufficient movement.
It would look like this:
It may take some practice still to get a smooth stipple if that is the effect you are going for.
You may find some other ideas on quilting websites to get around this problem or in a Yahoo group for quilters. I've only ever quilted in straight stitch using my walking foot so it feeds the quilt smoothly for me, never tried FMQ.
Oct 24, 2011 | Brother XL-5130 Mechanical Sewing Machine
Settings for stippling freesia 425
Lower feed dogs. Turn on Needle Down. Presser foot pressure on Darning setting. Don't forget to lower the presser foot lever. That's about it! Since you are going to be the feed dogs, it doesn't really matter if you have a stitch length set or not, but do have width set for "0". The spring loaded darning/embroidery/quilting foot is the best for stippling, but try it with any open toe foot you may have. Do a few samples first using the threads you intend using on your project because the tensions might need tweaking. Try to get the result you like by adjusting only the top thread tension. If you really have to adjust the bobbin too, put a small mark on the bobbin case where the "normal" position of the screw is so you can return to that when you are done quilting.
Jan 31, 2010 | Husqvarna Freesia 425
My machine is skipping stitches when I free hand quilt & the top thread is looping on both the top & the bottom
Make sure you have your thread through all of the thread guides, If I feel I need a little extra tension I loop my thread through the bobbin tension guide on top of the machine, especially if it is a fine or silky thread for decorative work. Make sure your bobbins are wound tight and also threaded correctly. When freehand quilting you should sew at a moderate speed and make sure to move your fabric smoothly with the speed at which you are sewing, you may just have to practice a bit like I did...If none of this works you may need to take your machine in and have the tension set on the bobbin housing itself..
Oct 26, 2009 | Singer 7436 - INGENUITY
Skipped stitches & looping on the bottom of Quilt
Try a different needle. Use a quilting or topstitch or even a metallic needle - one that has a larger scarf than normal. The scarf is the groove at the back of the needle where the thread goes while the stitch is being formed. Quilting threads often need more "room" there. I have been told that the Inspira quilting needles are good because they have a thread groove on the front and the back of the needle. Not tried them personally but might be worthwhile for you to consider.
For the looping, you could fiddle with your tensions a little either loosening the bobbin tension or tightening the top, or both. Only ever do this in very small increments. But the good news is that even the "professional" quilters do not have perfect quilt backs - just have a look at them at quilt shows!
Pam M.
Apr 27, 2009 | Brother LS-2125 Mechanical Sewing Machine
Free motion quilting skipped stitches, breaking threads
Might be that you need to lower the tensions quite a bit, you'll have to juggle with top and bottom tensions though, and experiment for just this operation with the Sensormatic.
Mar 27, 2017 | PfaFF Sewing Machines
Machine quilting
To stipple ,remove the ankle and foot, lower the feed dogs and, most importantly, lower the presser foot lever.
You can also buy a LOW SHANK darning foot which will help prevent skipped stitches. It must be screwed onto the machine instead of snapping on.
sewman7
Oct 29, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Free Motion Sewing
You need to set the stitch length to '0', use some stabilizer to help stiffen the material slightly (you can use it to trace your design onto as well) and try using an embroidery hoop this sometimes helps.
When you start you must push the needle down through the material and up again using the machines wheel and pull the bottom thread through from underneath. Do a couple of stitches to fix the thread and then go.
The most important thing to try and get right is the machines tension, this can sometimes be trial and error I am afraid. My machine tension works best on about a '3'.
Jan 13, 2008 | Singer 7436 - INGENUITY
Sewing Machines Logo
106 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
