Question about Canon PIXMA MP620 All-In-One InkJet Printer
I have a print job on hold and cannot resume it or delete it
  • 428 Answers
May be a print spooler problem Try restarting it. Start -> Run Type in services.msc and hit enter Check the print spooler service. If disabled enable it. Else if stopped restart it. Or restart the service.
Posted on May 30, 2010
Documents in printer que, but does not print
If a print job get hung up in the print que it may stop and not be able to be deleted, this will also block other print jobs from printing. Here is a link to an article that shows how to clear the print que and purge the stuck print jobs so printing can resume. I hope it helps.
http://www.ccl-la.com/blog/index.php/how-to-delete-print-jobs-that-are-stuck-in-your-print-queue/
Dec 10, 2012 | Sharp Mx-2310u Color Copy/print/scan
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
I stopped a print job and do not want it to continue.
Well, go on to print que on the bottom right side corner and look for the Printer Icon when found it double click onto it and delete the one you would not like to print..!
All the best..:D
Feb 13, 2010 | Brother HL 1440 Laser Printer
My Deskjet 5740 has Resume light blinking, all other lights off. Will not print. Won't let me cancel printer queue. If I push the Resume button, the printer feeds a sheet and halfway through the next...
Sounds like it is expecting a different size paper than you have in it. In the item that you are trying to print confirm the page size. If it is a document that you download or someone sent you it could be in a different page size. To cancel it you will likely have to go into the printer settings and delete it from there then power off the printer and power it back on, this should clear the job. Windows will keep trying to print the job until it is successful or deleted. To see the print jobs double click on the printer icon then just highlight and delete it.
Jan 19, 2010 | HP DeskJet 5740 InkJet Photo Printer
How to delete past jobs?
This is the method to delete print jobs in the Queue by Microsoft.
If this is not working, then try this method.
Press Winkey+r
In the run dialog write msconfig
An other dialog-box will appear, there you will see many tabs (Click Services)
In the list find "Print Spooler" (UNCHECK it)
Click Apply,
Restart Your PC, and turn on the service again by Checking it (It may Start Automatically)
Another Method:
Open your C:\ Driver
Goto Windows folder
Then System32 folder
Goto spool folder
In the spool folder there will be a folder named PRINTERS
Delete all the files in that Folder.
You are done.
Hopefully, one of them will work, Best of Luck.
Regards,
Waqar.
Aug 20, 2009 | Canon PIXMA iP90 Mobile Printer
Cannot delete print job
Follow these steps in the order presented to resolve the issue. After you have resolved the issue, you do not need to complete any remaining steps. Step one: Check the USB cable
  1. Disconnect the USB cable from the product, and then disconnect it from the computer.
  2. Wait 10 seconds.
  3. Reconnect the USB cable to the product, and then reconnect it to the computer.
After you connect the product directly to the computer, the product should start printing the jobs in the print queue. If the issue continues, proceed to the next step. /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
Nov 06, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Dell 924 Printer
Delete All has worked for me.
Aug 12, 2008 | Dell 924 All-in-One InkJet Printer
Error in Print Jobs in the Queue
The use of a Print Buffer will help, the problem happens when there is a buffer overflow. Reboot the printer and let the print queue to resume will fix it every time, a print buffer will help with the overflow, try get one with a fair bit of RAM
Jul 15, 2008 | Zebra Z4M Printer
Can't print
I would check out the paper pickup roller (and any other rollers. They may be dirty or jammed. Also, blow out the inside with low pressure compressed air and clean with a papertowl and 90% isopropyl alcohol. Most problems I have encountered like this are little bitty ink soaked pieces and paper "dust" gumming up the works. 90% of most problems in anything like this is paper "dust" and dried ink. You should wear latex "medical type" gloves when performing this. If you get ink on your fingers, a 50/50 solution of bleach and water will get it out.
Jan 28, 2007 | HP DeskJet 3820 InkJet Printer
Canon PIXMA MP620 All-In-One InkJet Printer Logo
139 people viewed this question
old marine
old marine
