Question about Sony Playstation 3 (PS3) Console
After restore factory default settings controllers won't connect
The back of the controller has a little hole next to the screw in the middle. With your system on, use a pin and press the button in while you are plugged to the PS3 via usb. Press the PS3 button and boom, you have just reset you controller to factory sync with your unit.
Posted on Nov 04, 2010
  • shane mooney Sep 13, 2013
    i've tried that and still not working. any ideas why?
Reset HP 226dw
estore the factory-set defaults
Restoring the factory-set defaults returns all of the product and network settings to the factory defaults. It
will not reset the page count, tray size, or language. To restore the product to the factory-default settings,
follow these steps.
CAUTION: Restoring the factory-set defaults returns all of the settings to the factory defaults, and it also
deletes any pages that are stored in the memory.
1. On the product control panel, press or touch the Setup
Open the
Service menu. button. 2. 3. Select the Restore Defaults option, and then press or touch the OK button.
The product automatically restarts.
Jan 11, 2018 | HP Computers & Internet
How to reset to factory default
Restore the factory-set defaults
CAUTION:Restoring the factory-set defaults returns all of the product and network settings to the
factory defaults. The procedure then automatically restarts the product.
1.
On the product control panel, press (X451 Series) or touch (X551 Series) the Setup
button.
2.Scroll to and press or touch the Tools menu button.
3.Scroll to and press or touch the Restore Factory Defaults button, and then touch the OK button.
Jul 22, 2014 | HP Officejet Pro X451dn Printer
Reset nvram
http://www.support.xerox.com/support/phaser-3300mfp/support/enus.html
Solution : Clear Memory and Restore Default Settings on the Machine NOTE:Clearing memory on the machine will remove information from the machine and restore factory default settings. Make sure that all fax jobs have been completed before clearing the memory, or jobs will be lost.
To clear the machine memory and restore factory default settings:
  1. Press the [Menu] button (located below the Display Screen on the Control Panel) until "System Setup" is displayed on the bottom line of the Display Screen.
  2. Press the [Enter] button.
  3. Press the left or right [Scroll] (arrow) button until "Clear Setting" is displayed.
  4. Press the [Enter] button.
  5. Press the left or right [Scroll] button until the option to be cleared is displayed. (Refer to the table below for additional information.)
  6. Press the [Enter] button. "Yes" will be displayed.
  7. Press the [Enter] button again to confirm.
  8. Repeat steps 3 through 7 to clear additional items.
  9. Press the [Stop / Clear] button to return to Standby mode.
Clear Memory Descriptions Options Description All Settings Clears all of the data stored in memory and resets all of the machine settings to the factory default settings. Fax Setup Restores all of the Fax options to the factory default settings. Copy Setup Restores all of the Copy options to the factory default settings. Scan Setup Restores all of the Scan options to the factory default settings. System Setup Restores all of the System options to the factory default settings. Network Restores all of the Network options to the factory default settings. Address Book Clears all of the fax number and e-mail address entries stored in memory. Sent Report Clears all records of sent faxes and e-mails. Fax Rcv Report Clears all records of received faxes. New Scan Report Clears the information about network scan sessions in memory.
May 21, 2014 | Xerox 3300MFP/X new 3300mfpx [a51t732]...
I have been able to connect to Xbox Live for the past month and a half without any problem... Now it wont connect, but it says that it has internet access. All of our computers and our Wii gaming system is...
I have trouble connecting from time to time, and when I do, I restore the network configuration to the factory settings. To do this, go to My Xbox -> Network Settings -> Wired/Wireless Network (whichever you are using) -> Configure Network. Go to the Additional Settings tab, and then down to Restore to Factory Defaults. Click "Yes, restore to factory defaults." Note that it won't touch any of your game data, only the network settings, so the warning it gives is nothing to be concerned about. This may or may not work for you, but it's definitely worth a shot. If all else fails, just call Xbox (1-800-4-MY-XBOX [US]) and they should be able to sort you out.
Hope this helps!
Sep 13, 2011 | Microsoft Xbox 360 Console
Reset hp 1515n
? Restore defaults-used to reset all customer-accessible menu settings back to the factory default
settings (except language) via the control panel or software
NOTE: This service menu item does not reset factory-settable settings, including formatter
number, page counts, factory paper settings, language, and so on.
NOTE: Before restoring defaults, print a menu structure report and a configuration page. Use the
information on these pages to reset customer-specific settings.
CAUTION: All HP Jetdirect settings are also reset. Be sure to print a configuration page before
restoring defaults. Make note of the IP address that is listed on the Jetdirect configuration page. You might need to restore the IP address after performing a cold reset.
Restore the factory-set defaults on the (HP Color LaserJet CP1510 Series Printer
1. Press OK to open the menus.
2. Use the Left arrow or the Right arrow button to select Service, and then press OK (Select).
3. Use the Left arrow or the Right arrow button to select Restore defaults, and then press OK.
Jul 13, 2011 | HP LaserJet CP1515n Printer
How to cold reset the hp lj m1120 printer
No cold reset for this model.
Only Restore default Option.
Restoring the factory-set defaults returns all of the settings to the factory defaults.
1. On the product control panel, press Setup.
2. Use the arrow buttons to select Service, and then press OK.
3. Use the arrow buttons to select Restore defaults, and then press OK.
Jul 08, 2011 | HP Office Equipment & Supplies
I cannot connect to the internet using my netgear n150 wireless router. The internet light is orange but the modem is working fine and I can connect to the router itself.
When the router is turned on, the Internet light turns amber for about 20 seconds and then turns green. If the light does not turn green, the router has a problem. If the Internet light is still amber 1 minute after turning on power to the router: a. The Internet is not accessible. Confirm that you have the correct internet setting. b. Clear the router's configuration to factory defaults. This will set the router's IP address to 192.168.1.1. c. Turn the power off and back on to see if the router recovers. If its still not working, reset to factory defaults. You can restore the factory default configuration settings that reset the router's user name to admin, the password to password, and the IP address to 192.168.1.1. To restore the factory default configuration settings: 1. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings button, located on the rear panel of the router, for about 5 seconds, until the Power light begins to blink (see "Back Panel" on page 4). 2. Release the restore factory settings button, and wait for the router to restart, and for the Power light to stop blinking and become solid green. The factory default settings will be restored so that you can access the router from your Web browser using the factory defaults.
Jun 06, 2011 | Computers & Internet
My default IP ADRESS is192.168.1.1, and am trying to change my router password for wireless connection
If you ever lose your settings or if your settings are changed and the router is not functioning properly, you can come to this area to restore your saved settings from the backup file you created. Click Browse to locate the backup settings file you previously created. When you have located it, click Restore and the settings saved within this file will be applied to the router. If you did not create a backup file, you may need to restore the factory default settings.
device3.gif Factory Settings If you ever want to erase all personal settings of your router, come to this area and click Reload to restore the factory default settings. All the current settings will be lost. If you change the router's configuration and it stops functioning properly you can reload the factory settings to fix it.
device3.gif The other method to restore the factory default settings is to press in and hold the RESET button on the Wireless MAXg Router for between five and ten seconds. You will lose all of your personal settings if you restore the factory default settings. You might need to do this if you are unable to access the Web User Interface or have forgotten your password.
Nov 07, 2010 | U.S. Robotics MAXg USR5461 (738168036790)...
I have hp 1522nf printer & it is showing memory low. It is continously showing error 49
Hello ! you can try doing the following:
1. Please ensure that the printer is directly connected to wall outlet.
2. Print a configuration page and check the firmware datecode. If possible update printer firmware and check if the issue occurs.
3. If the issue occurs, please perform a restore factory defaults. Restoring the factory-set defaults returns all of the settings to the factory defaults, and it also clears the fax header name and phone number.
a. On the product control panel, press Setup .
b. Use the arrow buttons to select Service, and then press OK.
c. Use the arrow buttons to select Restore defaults, and then press OK. The product automatically restarts.
4. If the issue still persists, perform a NVRAM initialization. An NVRAM initialization will return the following device settings to the factory-set defaults:
a. Turn off the product.
b. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
c. Wait until the message Permanent storage init. appears, and then release the buttons. When the NVRAM initialization process finishes, the product control panel shows the Ready message.
Jul 02, 2010 | HP LaserJet M1522n MultiFunction Printer
Forgot password to acess< and or its still default setting. could you tell me what the wireless 700 routers default password is
Restore Factory Default Settings When you restore factory default settings to the base station, you clear your Internet connection settings and any special base station configurations that you have established. After the restore is complete, you will need to reconfigure your base station settings or restore these settings from a backup file. You should restore the original factory default settings only under the following circumstances: O You are experiencing serious problems with your base station, and resetting the base station does not fix the problem. O You cannot remember your base station password. In this situation, you must restore the factory default settings by using the Restore button on the base station, and then use the default password admin to log on to the Base Station Management Tool. To restore factory default settings 1. Open the Base Station Management Tool, and then click Management. 2. On the Management menu, click Back Up and Restore Settings. 3. Under Restore factory default settings, click Restore Factory Default Settings. While the original factory default settings are being restored to the base station, the Power light on the base station turns orange. When the light is solid green, the settings have been restored. If you want to open the Base Station Management Tool after the settings have been restored, type admin as the password on the Logon page. Do not attempt to log on to the base station until the settings are restored and the Power light on the base station is solid green. After you restore the factory default settings to the base station, you should navigate to each page of the Base Station Management Tool and reestablish the network settings you want, or restore the base station settings by using a backup file. For information about creating a backup file of your settings, see the following section. Be sure to establish your unique base station password as soon as possible after restoring the factory default settings to prevent unauthorized users from logging on. For more information, see “Change the Base Station Password.” please rate this answer, thanks
Jan 30, 2009 | Microsoft MN-700 Wireless Router
Sony Playstation 3 (PS3) Console Logo
172 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
