Question about Health & Beauty
I recently bought a pfaff30; I am currently unsuccessful at winding the bobbin. At this point I have: disengaged the wheel placed the bobbin on the traverse spool pin passed thread thru lower eyelet and thru tension discs engaged bobbin winder by depressing lever(5) in manual when motor is on, nothing moves --not engaging by pulling tread off spool and onto bobbin ??? Karen
  • kako8640 May 30, 2010
    The reply to my Pfaff 30 questions was quick and accurate;really helped me get through my start-up questions. Getting such professional response on the Memorial Day holiday weekend was a very pleasant surprise; will recommend this website to my friends. Go Guru Halbrook !!
  • 560 Answers
Your description is correct.
When the sewing mechanism is in engage position, does it move?
Posted on May 30, 2010
  • 6 more comments
    Yes, the machine powers the needle when engaged.
    I have continued to look for a simple answer--seems like I just missed something in the manual-- I just got it to wind---U have to be very careful to find the tiny slot in the side of the bobbin to match with the raised notch on the threader, then the bobbin is locked in place and the disengaged motor quicklly winds the bobbin--past this one!!
    Do you know if there is an ON/OFF swithch to this model; I can't find any reference in a reproduced copy of the original Pfaff manual?? !!
    Karen
  • Liza Halbrook
    Liza Halbrook May 30, 2010
    The original machine is operated manually. Modified machine usually doesn't come with power switch. Once you plug it in, its ready to go.
    That makes sense why I can't find the switch!!
    I put the machine on a surge-protected extension cord with an on-line switch-- I guess that will be
    sort-of an "ON/OFF" switch .
    Does it make sense that when I switch the power "on", the engaged motor makes the needle go 100 miles-an-hour??; seems like I can't sew with a controlled speed??
    Karen
  • Liza Halbrook
    Some machine has a "low and high speed" switch. If your machine doesn't have one then it is always set to high. But even with high speed, you should be able to control the speed from maybe 40miles per hour by softly pressing the pressure pad. Its like driving a car, except you don't get 1st and 2nd gear but the gas pressure works the same. If you get a steady 100miles speed no matter how much pressure you applied, there has to be a problem on either your pressure pad or the motor.
    You can ask your local sewing machine repair shop if they can modify your machine and install a speed switch so you can have low and high speed mode.
    Sort of like a dimmer switch??
    I think that sounds like what I need!!
    Thank You sooo much for your support on this Holiday Sunday--really appreciate the input; very "on-target"
    Karen
  • Liza Halbrook
    Yes, works like a dimmer switch but has 2 stages only. Mine has a turtle and a rabbit to indicate low and high-speed switch :)
    You're welcome and have a great day. Good luck finding the switch so you can enjoy relaxed sewing mode.
    I always loved the Fable of the Tortoise and the Hare---we turtles have to stick together!!
    Thanks for your encouragement--I bought this Pfaff 30 to make purses with leather and fur; was told this machine is a "heavy duty" that could take it; we'll see how that goes. Since I have very little sewing experience( just an avid interest ), I am pleased to find your Website to be so quick to help a beginner like me.
    I don't know where in the USA you are based, but from my home near Milwaukee,Wisconsin, my air conditioned sewing space suits me well on this very hot,sticky holiday weekend. Hope yours is a pleasant one.
    As I progress through my first project of a lap top carrier cover, I hope I won't need to "bug" you with too many problems.
    Thanks again,
    Karen
  • Liza Halbrook
    I'm glad to help. Good luck with your projects and thank you for using FixYa.
The foot pedal is not moving the machine but still makes a noise
A: You said, "The your foot pedal is not moving the machine, but still makes a noise". . . . I'd suggest checking if the sewing machine has a disengaged or broken drive belt, gear or linkage; if not the problem, may just be that the Hand-Wheel clutch mechanism (on the left center of the Hand Wheel) is in the Bobbin-Winding position. If so, it allows the machine to cycle, operating the Bobbin-Winder without the needle moving up or down. Older Brother machines, like many other brands, used a large flat shiny Screw Knob in the center of the Hand Wheel to engage or disengage the Bobbin-Winding feature, newer models use a plastic teeter-totter switch located in the same place, to do the same thing. Keep tinkering, you'll will resolve it.
Sincerely,
-- Amender (2016 FEB 23)
Feb 03, 2016 | Brother Sewing Machines
My Janome 3018 will not wind a nice tight bobbin. They are loose and spongy. This machine is brand new. I have double checked that it is threaded properly and the thread is in the correct place and
You are not exactly threading the machine when you wind the bobbin. So follow the directions for winding the bobbin, make sure the thread fits under the little revolving wheel, and make sure that the stitch part of the machine is disengaged.
Jan 01, 2015 | Janome Sewing Machines
The machine will not turn the spindle to wind cotton onto the bobbin.
What model Bernina is it? Most operate on a simple system where a rubber wheel on the bobbin winder comes into contact with the handwheel (under the cover) ... the handwheel is disengaged so the needle has no drive.......
Apr 13, 2014 | Bernina Sewing Machines
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
My Model # 1120 Singer sewing machine needle will not go up and down when motor is pressed. The bobbin winder, however, spins.
It sounds like your machine is set to wind the bobbin right now, so the drive is disengaged. That would explain why the bobbin winder pin is the only part moving. Check your manual for how to reset the machine when you are finished winding the bobbin.
Most machines have a way to disengage the drive for the needle while filling the bobbin. Then once the bobbin is filled, you re-engage the drive. Some machines have a separate, smaller hand-wheel that turns and clicks into place. Some machines automatically reengage the drive once the bobbin pin snaps into place away from the drive belt.
I hope this helps!
Mar 29, 2011 | Singer 1120 Mechanical Sewing Machine
Needle not going up and down but power getting to the machine
Check your manual for the bobbin winding steps for your particular model.
On some machines there is a knob in the center of the hand wheel that is loosened for bobbin winding - this also disengages the movement of the needle. Tighten for sewing.
There may be an additional step, such as moving the bobbin winding pin to the right or the bobbin winding wheel to the left.
Apr 06, 2010 | Bernina Sewing Machines
How to put thread on a bobbin of a Kenmore Sewing machine
I could not find a guide for this model.
If there is a knob in the center of the handwheel, it needs to be loosened.
Take the thread from the spool around the first guide and then to toward the bobbin winder.
Run the end of the thread through an opening in the side of the bobbin spool.
Hold onto about 5" of the thread and place the bobbin spool onto the bobbin pin and move the pin to the right or the winding wheel to the left (depends on how your machine is designed).
Holding onto the thread end, press the power pedal.
When you cannot hold onto the thread any longer, stop the machine and cut off the thread end and then continue to wind the bobbin.
Disengage the bobbin winder (move the pin or the wheel back into place) and tighten the knob in the center of the handwheel before sewing.
Mar 24, 2010 | Kenmore 12912
Just bought my used Bernina 1010;it was sold to me
Heat the wheel with a hair dryer to loosen. If this does not help, you will need to visit an authorized Bernina dealer.
Jul 21, 2009 | Bernina Sewing Machines
Winding the bobbin?
Most of the entry level machines will have either a clutch knob or an automatic release when the bobbin winder mechanizm is engaged (put a bobbin on and more the unit to you right). If it does not disengage the clutch automaticly then either loosen the clutch wheel by turing or pulling. Sometines you have to grab the whole clutch wheel to disenage the mechanism to free wheel while winding the bobbin. Now press you foot control to wind the bobbin.
SewTech
Apr 21, 2008 | Janome Mini Compact
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
