Question about Breville Conical Burr Coffee Grinder - Stainless-Steel
The burr grinder does not worked
I bought the Breville burr grinder two years ago. I have been using it pretty often (to have freshly ground coffee). A few days ago it stopped working. I cleaned it's parts very carefully, put them back. It worked a couple of times and stopped again. Do I have to change or sharpen the burr? How can I do that? Thanks.
SOURCE: grinder blades dull
I may be having the same problem. My coffee grinder has had more leftover beans in it more and more this week, until finally today, possibly a quarter teaspoon passed through to the filter basket and the remaining beans were still very much beans. My first assumption was the blades.
Posted on Dec 25, 2007
SOURCE: CCM-16 Series Cuisinart Supreme Grind Automatic Burr Mill (Coffee Grinder)
My CCM grinder eventually stopped working altogether and I had to throw it away. Amazon comments says this is common. But while my grinder was working, it gave the same symptoms. This problem was caused by beans getting jammed and the outlet from the burr wheel being clogged. If that's the problem, cleaning it out is simple.
Posted on Jan 04, 2008
SOURCE: Breville cafe roma
Obviously the problem is with your grind, not the Breville. SImply adjust your grind to finer.
Posted on Jan 07, 2009
EsWorld
  • 1618 Answers
SOURCE: severe clogging
Try using long grain white rice works better than minute rise, if that does not help, then the burrs need to be replaced on grinder.
Posted on May 14, 2009
SOURCE: Breville expresso filter
Put the coffee filter in the oven (yes the OVEN) and run a auto-clean cycle, it will turn all to hashes. Run a clean water cycle after to clean it.
It may discolor the filter a bit, but this is only cosmetic.
It happened to me because the grinder at the grocery store had trouble without anybody noticing it. It's then I decided to buy my own grinder.
Good luck,
JF
Posted on Oct 17, 2009
My Breville BDC600XL grinder appears to be clogged and would put ground coffee into the basket. The grinder also slows almost to a stop. How do I fix it?
if this isa bed-bath and beyond unit?! take it bak!. and try the Braun coffee grinder. I hav had mine for 10 years and nevr a problem.
Dec 31, 2014 | Breville Bdc600xl YouBrew Drip Coffee...
Where does the water go
This is a COFFEE GRINDER. Designed to grind coffee beans to into a powder . This powder is then put in a coffee machine or a coffee peculator to brew coffee. DO NOT put water into the coffee grinder !
Dec 19, 2010 | Breville Conical Burr Coffee Grinder -...
My Breville BCG450 coffee grinder won't turn on and i have the bowl in place. Can you help me?
I sometimes forget there's an on/off switch on the back of the thing, since I mainly use the button on the side.
Dec 28, 2009 | Breville BCG450XL Manual Burr Grinder
The on/off button comes off consequently machine isn't working
if you are handy the switch needs to be replaced. Soldering may be rquired and there is very little wire to pull. You can get a rocker switch at radio shack plus you need a triangular driver bit for base screws, It's really a poor design on a good grinder. You actually NOT have a switch and just hard wire it. I fixed mine for 3 bucks and an hours time
May 24, 2009 | Breville Conical Burr Coffee Grinder -...
Severe clogging
May 12, 2009 | Breville Conical Burr Coffee Grinder -...
Why is the grind from my Breville BCG450XL in the finest position coming out like a drip grind with a fair amount of dust mixed in? I have an old Solis with exactly the same conical burrs which is grinding...
The Breville was designed to be used with Pressurized Portafilters, which most Home Espresso Machines have. These filters use a courser grind, so when it says Espresso on the Breville, it's really closer to Drip. The Turkish setting is barely fine enough for Espresso. There is a limiter on the Breville that prevents the user from going any finer, if you crack it open and remove the limiter, you can go as fine as the Solis. Becareful though, the burs can come so close to each other that they can chip and break.
Feb 20, 2009 | Breville BCG450XL Manual Burr Grinder
KitchenAid coffee grinder
Apparently we must be the only two people on the planet with this problem. I have a Breville burr grinder that I received as a gift, and it magnetized the grounds directly out of the box. I am considering opening the casing up and grounding the motor through the plug. I would need to replace the 2-prong plug with a 3-prong plug. The casing is made of plastic and stainless steel, so they wouldn't need to ground the chassis, but if the electric current running through the motor or the burrs (attached to the motor) are the root cause then I would think that grounding the metal chassis of the motor through the plug/outlet should do the trick.
Jan 10, 2009 | KitchenAid Blade Coffee Grinder by
Gaggia MDF Electric Burr Grinder
It could well be gummed up with years of coffee bean residue
Very simple to take apart. There are two screws holding the cannister. They are hidden under 5mm round rubber covers that you have to pry off. Then remove the two screws holding the plastic cover. Mark the position of the numbered dial relative to the brass burr assembly then remove it. Once exposed, you should be able to figure out why it is locked. Scrape away as much gunk as you can.
Aug 18, 2007 | Gaggia MDF Electric Burr Grinder
Breville Conical Burr Coffee Grinder - Stainless-Steel Logo
62 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
