Question about Troy Bilt 5.5hp Self Propelled Mower
Put to much oil in lawn mower and now it won't start. how do i fix it? lawn mower is a troy bilt model TB836E
  • 10865 Answers
SOURCE: Its starts but will cut off
The problem you are having is due to dirt and gunk in the carbeurator. Spray a carbeurator cleaner into the air chamber [remove the air filter] and run it a couple of times then let it sit for two hours while the carbeurator cleaner does its job of dissolving any debris. Then start it up. IF this does it, great, if not repeat the cleaning technique.
If all of this doesn't do it, then the carbeurator will have to be removed and either replaced or rebuilt.
Posted on May 06, 2009
SOURCE: Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Posted on Mar 21, 2009
#1 Taper
  • 1041 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
SOURCE: My lawnmower won't start
my lawn mower has a new battery but will not start
Posted on Nov 02, 2009
RonInFla
  • 86 Answers
SOURCE: where is the oil plug located on a troy bilt mower?
Tilt it over so the oil cap is on the bottom...it'll rest on the handle and hang there...put a container under the oil fill pipe...something shallow like a glad sandwich container works perfect...get a paper towel, and reach under an unscrew the cap...all the oil runs out into the container...it'll fit !!
Wipe the dipstick off clean, and put it aside...take this time to look at your blade on the other side...it "should look" similar to wood chisel at the last 5 inches of the blade on both ends followed by a wing under it...BTW: their $12 bucks new...and worth it !!
Go back and look at the container and be sure the oil is finished draining...take the lid for the container and snap it on and move it out of the way (no body likes an oil spill)...wipe off the oil fill spout, and re-fill...takes about a half a quart, so don't over fill it !!!
your done...
Posted on Apr 17, 2010
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Troy-bilt 550 series mower won't start. I've only used it twice.
does it crank over?did you leave the blades on?are you pushing on the brake pedal
May 25, 2012 | Troy Garden
What Oil do I put in a Troy Bilt xp series mower
They recommend using only SAE 30 oil or 5W-30 if you choose to use synthetic. Be careful. Most smaller mower engines only require about 20-21 oz. The Honda engine may use more. See gauge on side of oil bottle.
Jul 05, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Changing oil in a troy bilt squall 5521
To change oil in a lawn mower you will need to acquire a fluid evacuation pump. Remove the dipstick and with the pump evacuate the old oil into a suitable container. Check your owners manual to determine how much oil to put in DO NOT overfill or the mower will not work. Make sure the old oil gets recycled.
Oct 27, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Clean air filter and replace spark plug. If it is wet when you pull it out let it sit and dry out before putting new one in.
Jun 23, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Changing oil
is the drain plug on a troy bilt 6.5 hp ontop of the blade in the right hand cornor
Apr 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 5.5hp Self Propelled Mower Logo
438 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
