Question about Dryers
The dryer tries to start but quits after a second
  • cheers697 May 30, 2010
    my drum turns freely,
    Thanks this is the second motor in 2 years. Will talk to the dealer on Monday
    President:
  • 949 Answers
Can you tell me a couple of things that will help me assist you please?
Does the dryer turn off as soon as you take your finger off the start button?
Does it make a loud buzzing or humming sound when first starting up?
When it stops can you start it back up right away?
What is the brand and model number from the tag just inside the door?
Thanks!
Posted on May 30, 2010
    The tag on the door is worn so I cant read it but my invoice says AEQ7000EG frigidare affenity
    The dryer makes no strainge noise and runs for a second the stops
    It will try again if you push the start
  • Philip May 30, 2010
    Thank you for the information. This problem is most likely the run winding on the motor being bad.
    This motor has a start and a run circuit internally. If the start winding is good and the run winding bad it will start but when it switches over to the run mode it quits.
    The motor runs about $120.00 for this model.
  • Dryers Master
  • 8,220 Answers
That could be the motor but then again something inside may be jamming the drum.The dryer tries to start - 0739055.jpg Bad rollers glides or idler. Reach inside the dryer and turn the drum. It should be very easy to turn. If it feels hard to turn then you need to open her up and take a look see.bc7e0d7.jpg All dryers work on the same princible:
The clothes are tumbled while heated air is forced through them till all moisture is removed. They vary in styles however. GE and Frigidaire use a center bearing in the rear of the tub while Whirpool and Maytag use rollers. If the belt is broken on some models when you release start it simply quits. a048464.jpgSome dryer motor's growl in pain if they are in their last death throws of life. The good news it all dryers aThe dryer tries to start - d6908d7.jpgrepair. d6908d7.jpgd8f8717.jpgMost just have quick connects on the motor so it is fairly easy to replace the motor. The hardesThe dryer tries to start - 98d19a9.gifng getting the blower wheel off which is backwards threads on 98d19a9.gifwhirlpool/Kenmore brands. Some dryers use 4 wheels others use glides ,slides, or ring bearings around the front for the tub to ride on. When these wear out they sometimes pinch or bind the drum overheating and shutting down the motor. I have videos, manuals,and more good stuff at my blog HERE
Let me know
    the drum turns easly
  • Dan Webster
    Dan Webster May 30, 2010
    You should NOT be having to buy another motor in 2 years time. That is absolutely crazy.
    Whats your model number? I may be able to give a better answer if I had something to work with .
    Thanks for the nice rating. Kids
Why does my dryer start but quit a second later
If it quits immediately after you let go of start button, then it isusually a bad timer or control board. The motor gets all its power during start from the start button or start relay, but once it is up to speed the motors centrifugal switch will flip, getting power from the run circuit. If there is no power supplied to run circuit (like when timer is off, or door is open) then the motor shuts off.
Jan 10, 2015 | Dryers
Whirlpool Dryer made loud humming noise and quit
Something caused the motor to lock up. The humming noise was the start winding in the motor trying to start rotation, but could not because of lockup. The humming noise stopped when the start winding burned out ( will only last 6 or 7 seconds). It will require a new motor, plus repair to whatever caused it to lock up in the first place.
Dec 22, 2013 | Dryers
Dryer won't turn on
turn the breaker on and off.If the dryer is electrical it should be a double breaker (2 switches connected with a small bar across)
Unplug the dryer and plug in after 10 seconds - might reset the electronics
dryer has thermal cutouts for safety so leave it unplugged for 1 hour see if that helps. If it starts and quits again calling service is best solution. We are talking lots of voltage here and fire is not an option
There are internal fuses as well If they blow you definitely have a problem
Todays dryers are more complex and they do need somebody qualified
to service them safely
good luck
Feb 06, 2012 | LG DLEX2901V Dryer
Roper dryer motor hums then quits after three seconds or so
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2011 | Dryers
Dryer has stopped running in all modes. Timer makes a ticking/pulsing sound in "timed heat". Makes no sound in other modes. Origianlly stopped working when it was very hot. Next few tries ran a...
heatman101
May 04, 2011 | Dryers
Dear Expert, When I went to turn on my Roper dryer it made a humming sound for a few seconds then quit, without out the dryer ever starting. I then had my wife depress the start know while I held the...
check and see if there is any thing in the dryer vent if not.open the door hold the door switch in like the door is shut.have your wife push the start switch in and turn the drum counterclock wise if it starts then the motor has gone bad if it hums still its still the motor.if it does start stop the dryer and try restarting several times sometimes they get a dead spot and it may work for years or may die tomorrow but these are a couple of things to try good luck
Dec 19, 2010 | Dryers
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
Sep 07, 2010 | Frigidaire Affinity AEQ6000WH Dryer
Light underneath dryer, right side, front
What you`ve ``just started noticing...`` is likely the ignitor glowing or the burner burning and is quite normal for a ``gas`` dryer.
Hope that answer`s your question. If so please take a second to rate the reply I provided to you here at fixya.
Thank you.
macmarkus :)
Dec 13, 2009 | GE DBSR453GBWW Gas Dryer
Dryer quite
my dryer worked fine before xmas but washed a load of clothes and temped to put clothes in dryer and put it on right settings and pushed button to start it and nothing. We tried the breaker and shut everything down for about 5mins. and started it back up and tried the dryer again and still nothing had friend look at it and looked online and I think it maybe the start button myself.
Dec 27, 2008 | Dryers
Dryer starts and then quits
You have a faulty heat safety switch. This switch prevents the dryer from overheating and causing fire. Some dryers have as many of 4 of these switches (seems redundant but it prevents fire) Depending on how confident you are with repairs the back of the dryer can be removed and the switches can be replaced. Most of them are circular and are found along the dryer exhaust area. I do recommend that this repair be done by a professional if you do not have allot of experience yourself because of the safety factors involved. Good Luck!!!
Nov 07, 2008 | Kenmore 63932 Electric Dryer
Dryers Logo
Top Dryers Experts
