Question about Acer X203H bd Monitor
My cursor and some programs keep going off the screen on the right hand side. How do i fix this? Please be specific because I do not know anything about it.
  • 54 Answers
Perhaps your display resolution is set too high. Goto Start->Control Panel->Display, then lower the display resolution. Use the Apply button to see the result before closing the the Display setting screen.
Posted on May 30, 2010
How to tighten wheel that keeps coming loose
knowing the type of vehicle would be nice
nuts that keep coming loose indicate the hubs are side specific with left hand and right hand threads
if you have a left hand side hub on the right hand side or vica versa , that will be the reason
next check the rim stud area
square shouldered holes in aluminium wheels require a steel washer first and rims that are tapered at the studs require tapered nuts
Oct 26, 2017 | Cars & Trucks
My Mother was given an asus computer to find anything you have to run cursor around edge of screen can it be changed so you can click on start and list menu appears in lefy hand side
I am thinking that the start menu is on the side of the screen. I used to play tricks on my co-workers with this. when you pop the bar up. left click on it and drag it to the bottom of the screen. this should fix the problem.
Jul 12, 2014 | Computers & Internet
How can i capture screen with visible mouse cursor in windows-7 ? is it need any software ?
Hi.
You can capture a screen shot with the mouse cursor there by pressing the Prt Scr key. It should be on the top right hand side of the keyboard. Create the screen you want to capture and then hit that key, then open Paint which you will find in Start menu>All Programs>Accessories and then paint. Once you have opened paint up click on paste on the top left hand side and you will see your screen shot appear in the paint window. To save the picture click on the little floppy disk icon at the very top left of the paint window.
If there is anything else please post back.
Regards.
Apr 27, 2011 | Computers & Internet
Hp pavillon tx1000 12.1 inch touch screen cursor stays at bottom left hand conrner
Clean the screen with a clean soft cotton cloth is the step #1
Step 2:
SEE FULL instruction HERE
Calibrate the touch screen
The command buttons and fields are displayed on the screen image at specific pixel points. To initiate a response, the touch screen interface needs to recognize exactly where a fingertip or pen touches the screen relative to the pixel position of the display. Each user has a slightly different hand-eye coordination response. Calibrating the touch screen allows the interface to compensate between where the program is expecting a touch and where the touch actually occurs. To calibrate the touch screen, place the tablet notebook in the desired orientation and do the following actions.
  1. Click or tap Start > Control Panel > Tablet PC Settings to open the Table PC Settings window.
  2. On the General tab, select the option to display the menus in either the Right-handed or Left-handed position.
  3. On the General tab, select the desired screen orientation from the drop-down menu, and click or tap Calibrate . Follow the instruction to touch the screen at the specified points. Repeat this calibration action for all four of the screen orientations, then click or tap Apply .
  4. On the Handwriting Recognition tab, select the Use the handwriting personalization option.
  5. At a later time, you can return to review the Go to Pen and Input Devices and Go to Input Panel Settings options to make using the touch screen to control programs and input text easier and more accurate.
Compare your version of the firmware to the latest one at HP offical site HERE
Always get the latest firmware to avoid problem.
Always keep the screen clean!
Jul 11, 2010 | HP Pavilion TX1000Z 12.1" Touch Screen...
Extended desktop
display properties change labtop to default monitor
Jun 17, 2010 | AOC 193P+ 19" Monitor
No cursor/hand appearing on Choose Language screen
Are you sure you have put that "bar" included in the box above your tv in the middle, and fully wired? Because that is what you need to be able to have your cursor on your tv screen when your wii is on. Stupid or not, also make sure the batteries are put in it the right way, that you get blue light flashing out.
May 24, 2010 | Nintendo Wii Console
Original remote lost. have universal remote. cannot program TV
On the right hand side of this television there are panel buttons. It appears that your son in law knocked the tv out of the correct input. Press the input button in order to cycle through the 5 inputs. Typically pressing the input button on the side panel of a television and pressing it again and again and again will make it change inputs. Universally the buttons on the tv panel function as follows: Channel up moves the cursor up. Channel down moves the cursor down. Volume + moves the cursor right. Volume - moves the cursor left.
Hope this helps
Apr 28, 2010 | JVC LT-42E478 42 in. LCD Television
I cant choose anything on my WII homepage;no cursor
OK the problem is your censor. (if you dont know, its that long thin bar that comes with your wii.) there is really 3 things that could fix your censor: 1. move it because the censor cant read the controller, make sure the censor is plugged in, or get a new censor since its probably broken.
Dec 26, 2009 | Nintendo Wii Console
Acer 5315 goes to black screen with cursor
If it's only 5 months old, then it's still under warranty. Right now, I'd advise taking it back to have it fixed instead of taking it apart to replace hardware and possibly voiding a warranty.
Feb 15, 2009 | Acer Aspire 5315 Notebook
Acer X203H bd Monitor Logo
208 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
