Question about Garden
Simplicity mower runs for a few minutes then shuts off. let it sit for a while then does same thing
  • 66 Answers
It may be a coil or fuel issue. I have seen it both ways here in the shop. Fuel issues is that it can become vapor locked, fuel filter partially plugged or float acting up.
I am leaning more toward the coil with the time and heat/cooling down issue. www.nnyparts.com
Posted on May 31, 2010
When I am cutting the grass, when I try to go uphill the machine stalls . I am able to start it up again but a few minutes later the same thing happens.
Check the oil level...some engines have a low oil shutdown float inside the crankcase ..going up hill for an extended period of time allows the oil to flow to the side of the crankcase activating the float and tricking it to think the oil is dangerously low and shut it down...if it does it should have a small wire on the side of the crankcase..try operating on hill for shorter times..and make sure your crankcase is full...good luck..
Aug 01, 2015 | Simplicity 42 Toro Timecutter 20hp Kohler...
Simplicity regency 12 hydro sucking oil into carburetor. what could be the problem?
blown head gasket... it pressurizes the engine causing oil to blow out...
or
oil is WAY to full
should of mentioned the engine brand because simplicity doesn't make it !!!
Oct 18, 2014 | Simplicity 2691011 - Regent 42" 21HP Lawn...
Simplicity riding mower with 16HP Kohler engine stalls after about 15 minutes. Acts like it isn't getting any fuel, but it will run again later.
I have seen this problem a few times and this may not be the solution however, check the fuel filter. It may have melted and partially closed off the fuel supply. The routing of the fuel hose will cause the inlet end to bend slightly if it gets too hot under the hood.
Aug 24, 2012 | Simplicity 44in Broadmoor Lawn Tractor...
Simplicity not charging. Just shuts off while cutting grass after a while
there is a connector on the side of the engine that comes from the generator that is under the flywheel see if it is putting out power to there if so trace it back to the loss
May 22, 2012 | Garden
Simplicity zero turn electrical problems
charge the battery not hooked up to the mower let it sit overnight and try again the battery might just be died they only last a couple years put a volt meter on the battery when off then start it and watch the battery voltage should be around 14 volts running the pto clutch draws the most thats why it shuts off first the ign doesn't take any the carb needs very little
Apr 22, 2012 | Garden
My husqvarna 61 inch lawn mower will not stay running
Did you check the oil? Some engines have a low oil shut off switch to prevent the engine from running out of oil and burning themselves up. If it is low in oil and all the oil is up in the engine to lubricate, then the switch may be setting itself off. After a few minutes, the oil comes back down to satisfy the switch and it starts back up, but only till the switch is activated again. Might do it???
Dec 27, 2011 | Husqvarna Garden
Simplicity regent mower electric pto suddenly stops working but will work again later.
I have the same problem with my regent. Sometimes i just ride around a few minutes and it suddenly engages. I have no idea why.
Aug 19, 2009 | Briggs & Stratton Garden
After about 30 to 40 minutes of use (varies, the
I have a 7 year-old craftsman mower with a 22 HP Briggs engine that has the same issue. After about an hour, the mower acts as if it is starving for fuel and then stalls. Then after about 5 minutes of sitting, it will run for a little while longer.
If your engine is similar to mine, then its carb has a fuel shut off solenoid which shuts off fuel to the Main Jet when Voltage is removed to prevent backfiring when the key is shut off.
Unfortunately, this solenoid can also cause the carb to starve for fuel when not working properly. In my case, when I cleaned the solenoid and the solenoid's connections, the tractor had no problem after that.
Hope that helps,
Steve
Jul 25, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
B&D CMM1000 Mower
convert your mower to cmm1200. you needs parts 905058-81 to convert it.this to elliminate the circuit board & it's easy to install just follow the instruction. circuit board was on recall depend on the date code of the mower it is also no longer available.
good luck.
Jun 02, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
364 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
