Question about Carrier 38CKC024 Air Conditioner
My air conditioning system isn't blowing cold air
  • Dan Webster
    Dan Webster May 30, 2010
    Go outside and see if the fan motor is turning on the condenser.
  • 33 Answers
The air filter could be dirty or the a-coil which is located it the ductwork just above the furnace is dirty.
Posted on Jul 23, 2010
Air conditioning system, when you turn on the air conditioner the drivers side blows cold air and the passengers side blows hot air? What causes this problem?
The most common cause of this is that you have a stuck air temperature control blend door, this can be a motor actuator issue or a jammed door or both (common). To replace both parts you will need to completely remove the dash from the car to access the blend door.
Jul 02, 2016 | 2010 Ford Flex Limited
Why is my dodge Dakota air conditioning compressor cycling on and off all the time? No cold air blowing
Possibly an faulty thermostat in the system or a blocked TX valve. have an accredited ac specialist shop test the operating pressures of the system
Sep 11, 2014 | Cars & Trucks
Compressor isnt getting single to turn on
Yes , usually the PCM / ECM - engine computer gives the relay a ground . But the PCM needs to see the correct inputs from the high an low pressure switches to do that ! You could have a bad switch . Look on the A/C system pipes for switches , with two wires each ! One side should have 5 volts , an the other side i'm not sure .
Apr 08, 2017 | 1992 Nissan NX
Air conditioner isn't blowing out cold air
might need to be recharged and might have a leak in the system. take it and get it checked
Mar 16, 2013 | 2001 GMC Jimmy
Air conditioning blows hot and cold air
You will need to know if the compressor is working when it blows hot air to proceed. It could be an electrical problem, a blend door problem, or the a/c clutch on the compressor.
Jul 02, 2012 | 1999 Honda Civic
My A/C in my 2004 Mercury Monterey isn't blowing cold air
Have the refrigerant pressure checked at an automotive repair shop or purchase a can of 134a refrigerant w/ a hose and pressure gauge included from your local automotive store (Walmart) and follow the directions on the can. It really is easy to check and recharge your air conditioner. Remember to wear safety glasses.
Jun 14, 2012 | Air Conditioning and Heat for Mercury...
When your heater blows cold air
flush the cooling system, probably clogged. happened to me a bit ago with a 99 cherrokee. hope it helps ya.
Dec 18, 2011 | 1999 Ford Taurus
The air conditioning system will only blow cold air. Regardless of the mode, I can only get cold air. Can you give me an idea on how to fix the problem? Thanks Don 615-653-3834 drcamp117@comcast.net
The air conditioning is supposed to blow only cold air. Are you trying to get the heater to blow hot air? Make sure the temperature selector is in the hot position.
Dec 19, 2010 | 2002 Buick LeSabre
Air conditioner starts out blowing cold air,apparently actuator sticks causing the system to blow very hot air. Hours later a/c blows very cold air again, only to blow wry hot air again after about 30...
1.)If your System is OVERCHARGED this Will Occure due to the EVAPERATOR FREEZING UP
2.) Also if your HVAC Control Modual is Malfunctioning this will Aslo Cause this Condition, It Controls the BLEND DOORS that OPEN for COLD or HOT AIR Look Into these Items and Also Look Into wethrt the A/C Compressor Cycles OFF when it GETS OFF this Will POINT at the HVAC CONTROLER if it Cycles Off When Set For A/C or COLD Air
Aug 19, 2010 | Chevrolet C1500 Cars & Trucks
Air-conditioning
Low refrigerant charge or a sticking blender door. Check the suction line for temperature. A cold tube means that the charge is fine.
May 12, 2009 | 2000 Pontiac Montana
Carrier 38CKC024 Air Conditioner Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
