Question about Whirlpool Washing Machines
I need to remove the top of whirlpool washer lsr8233jqo and can't figure out how to get it off to replace lid switch
  • Whirlpool Master
  • 8,220 Answers
Behind the control panel is a screw on each end you remove with a long slender phillips head screwdriver. You can then flip the control panel up and get to the innards. Pop the S-clips, remove the lid switch quick connect and tip the case forward. You can now replace that lid switch.
I have a couple of vids I spyed on line. One is lidswitch replacement and the other shows how to get into numerous styles of these sweet machines and I have a 3rd one on how to replace the pump and more here
Posted on May 30, 2010
I need to replace lid switch on Whirlpool Thin Twin washer/dryer unit. How do I get the switch out and the new one in
The 3 screws across the front of the slanted panel need to be removed, then the panel. At the left and right rear of the main washer top are 2 5/16" screws, these need to be removed, there is a loose fitting steel clip through a slot on the main top these are holding down, when the 5/16" screws are removed slide the entire top forward and it will release from the front fixed clips. Unplug the lid switch unit and the main top can be set aside to replace the switch. Pleazer Appliance...
Jan 14, 2015 | Whirlpool Thin Twin Washer and Electric...
Washer lid switch replacement
there is a screw right on the edge of where the clothes go in the washer on the right side,remove the top cover ans unplug lid switch harness, remove lid switch and then replace lid switch and reverse the procedure
Oct 28, 2009 | Sport & Outdoor - Others
Lid switch replacement
Some washing machines have the bolts that hold the top down situated behind the front panel but you have to remove the panel to gain access.
There may be 3-4 screws at the bottom of the front panel, remove the screws and the panel should come out.
Hope this has helped
Jun 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
Replace lid switch
remove the screws on the control panel
pull the panel forward to unseat it then under it pop the clips that hold the top to the back of the washer the rest is self explanitive
May 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Top Load Washer LSR8233JQO no spin & no drain
The symptoms you describe are typical of a lid switch malfunction. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at searspartsdirect.com. Just type in your COMPLETE model number and look under the "Top and Cabinet" heading. The lid switch is listed as item number 11 (part #3949247) and the lid strike will be listed as item number 20 (part #358684). If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
PS This is a common problem experienced by this line of washing machines. To prevent future failures, do not slam the washer lid or place anything heavy on the lid. Repeatedly slamming the lid to get it to work, or manipulating the timer can can more potential problems.
Oct 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer repair
on rear of console remove the 2 screws 1 on each corner..console lifts and rolls backif switch on right under lid remove clips on each side cabinet then lifts from back to front and lifts off if switch ic under left side of lid at rear make sure hinge scres are tight on left hinge and lid hinge is striking switch solid if not push hinge at curved section toward back of washer
Jun 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Leaking
the head where timer is will lift up there might be 2 screws on each side.unplug lid switch, remove brackets on each side case will pull out toward you. You need to bypass lid switch with jumper wire to get unit to run without case.
Nov 29, 2007 | Whirlpool LSR5132PQ Top Load Washer
Replacing lid switch for whirlpool washer LSR5132JQ0
U WILL NEED TWO TOOLS TO DO THIS JOB.A PHILLIPS AND A FLAT SCREW DRIVER.YOU NEED TO OPEN THE LID AND REMOVE THE TWO SCREWS THAT ARE LOCATED ON EITHER SIDE OF THE LID SWITCH OPENING.YOU THEN NEED TO LOCATE THE TWO SCREWS THAT HOLD THE CONTROL PANEL DOWN.ON THE SOUTH AFRICAN VERSIONS OF THE WHIRLPOOL TOPLOADER THEY ARE IN THE FRONT OF THE CONTROL PANEL WERE ITS VISIBLE ENOUGH TO YOU.REMOVE THEM AND LIFT THE CONTROL PANEL UP AND BACK.YOU WILL NOTICE TO CLIPS ON EITHER END OF THE TOP REMOVE THEM WITH A FLAT SCREW DRIVER ALSO REMOVE THE WIRE LUG ON THE RIGHT SIDE.YOU WILL THEN NEED TO REMOVE THE CABINET BY OPENING THE LID AND PULLING IT TOWARDS YOU IN A SLIGHT UPWARD POSITION.NOW THE DOOR SWITCH IS LOCATED ON THE CABNIT IT SHOULD BE SMOOTH SAILING THEREAFTER.TO PUT THE MACHINE BACK ITS THE SAME WAY YOU REMOVED IT.AS FAR AS A PICTURE THERE IS NOT MUCH AVAILABLE.GOODLUCK.MOHAMED
Oct 07, 2007 | Whirlpool LSR5132J Top Load Washer
Washing Machines Logo
132 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
