Question about Dell Dimension 8250 PC Desktop
When my PC is booting up it displays a warning about 'low voltage'. It is a Dell home computer that is several years old but has been excellent. Do I have to replace something electrical?
  • stns440 May 31, 2010
    Not sure where to go to thank you for advice about my dell 8250 problem but I really appreciate your advice. Thanks Brixter0614 !
    Scholar:
  • 47 Answers
Hi! If you are using a surge protector, try to plug the machine directly to the wall then check if you will get the same error message. If yes then try to check if the cmos battery is securely placed on the motherboard, if yes then try to reseat the cmos battery. If all things fails try to call dell support and ask for a cmos battery replacement if your system is in warranty then they will replace it.Hope this helps...
Posted on May 30, 2010
Dell inspiron said battery low plug into charger, when plugged in charger light goes out and laptop will not power on, why?
Remove the main battery from the laptop and try power, if it works the battery is bad, if no change the charger needs to be checked for proper voltage. Since your laptop is less than a year old you should have warranty for up to the year, check this asp and find your paperwork should verify.
Mar 24, 2012 | Dell Inspiron N5030 Notebook PC
Vista incompatability ?
Try to un-install the driver first of the printer, after you do this Install again the printer driver..
Thank you
Jun 04, 2008 | Epson Stylus 2200 InkJet Photo Printer
Dell computer does not boot up - I have a Dell
First I would press (I think) F11 for the boot device. In the Dell boot menu, you will have the option of running diagnostics. Try that.
You can see the Dell splash screen on startup and you can see the options letting you choose what to do. So, you can be pretty sure your CPU. motherboard, and video are OK. The next suspect might be the hard drive or the files on the hard drive. But if you don't get a "no boot device" message, it sees the hard drive. I've also experienced a booting problem if the CD goes bad. So--first run the diagnostics. Then open the case and disconnect the cable from the CD and try booting.
I am assuming (perhaps incorrectly) that you have pushed F8 key after computer startup to see if you can start the computer in safe mode.
Aug 06, 2010 | Dell Computers & Internet
Can not display this video mode
If it is possible to boot this machine in safemode, you can boot it and change the resolution to low mode, and reboot the machine
Oct 14, 2009 | Dell E152FPb 15" TFT LCD Flat Panel...
My several year old PC will not. Display powers
I just went through this thursday with a Dell inspiron. I was in the middle of a system restore and it just shut down before it even had a chance to begin the restore. I unplugged it and removed the battery the harddrive and the processor heat sink. I cleaned under the heat sing on top of the processor and the bottom of the sink itself. I reassembled the unit and it came back to life. Give it a shot. Try the battery and unplugging a couple extra times if necessary.
Sep 06, 2009 | Biostar U8668 Motherboard
Low battery warning
That is because while a computer is in sleep mode, it is still using power to keep the memory. The battery is only used when the computer is turned off. You should replace the battery as soon as you can in order to keep your computer running properly.
Jun 29, 2009 | Dell Dimension 2400 PC Desktop
Dell Inspiron 9400 display goes blank after a few minutes
If the issue occurs in the safe mode, then I'm suspecting a failure of the LCD backlight. (It warms up and quits) Also see if video stays on using an external monitor. If it does, then the LCD is most likely failing.
If video goes out on an external monitor as well, then the Video card is failing due to overheating. Make sure all vents are free of dust (Clean with canned compressed air) and the all fans are functional (Run the fan test in diagnostics) If fans check up, then video card is failure point. If fans fail diags, replace affected fan 1st
May 21, 2009 | Dell Inspiron 9400 Notebook
Lost display suddenly on inspiron 1721 (dell)
maybe youre graphics card as gone down. try replacing it.
Feb 18, 2009 | Dell Inspiron 1721 (dndwna2_7) AMD Turion...
Dell computer not working windowsXP
Hurm.....it could be hardware or software issues....firstly try to clean up the fan's heatsink...overtemp is not good for ur machine....during power on(right after memory checks), hit the F8 button few times until it display safe mode selection...choose 'safe mode' and enter...system will load all neccessary drivers.........see if winxp able to boot as normal?
Sep 20, 2008 | Dell Latitude D600 Notebook
Dell Dimension 8250 PC Desktop Logo
132 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
