Question about JVC AM FM CD DET FACE CAR STEREO
Upon installing my jvc stereo to my car dose the red and the yellow wires go to the same powerline?
    Scholar:
  • 110 Answers
Hello there:
the red wire is going to be a switched hot that turns off with the ignition key and the yellow is going to be a constant hot for you're memory for you're preset stations and clock you can run them together and make them both a constant hot you will just need to remember to turn the stereo off manually so it doesn't run your battery down... hope this helps you out
Posted on May 30, 2010
I need to know were the yellow wire gos dose it go to the red or blue for a pioneer car stereo?
The yellow wire on a car stereo head unit is usually the keep alive 12+, which allows the stereo's memory to be set and kept. It should be connected to a constant 12+ volt source.
Oct 07, 2013 | Pioneer Car Audio & Video
I have a jvc kd-r431 am having to keep setting my settings everytime I turn the car on, it's not holding its mem
Its the wiring of the JVC. I've had the same problem but now know the solution. Take out the stereo and disconnect the wiring from the car and the stereo. The connector has two wires Red and Yellow. Pull them apart and connect both as Red with Yellow (or other way round). Once your done all you have to do is reconnect everything and there you have it. Hope this helps
Jul 26, 2012 | Car Audio & Video
I installed an older used stereo. I found the red wire is power, the black is ground, What is the yellow wire with the 5amp in line fuse for
The Yellow is your Ignition wire, It controls the stereo power when the vehicle is on/off. It can be spliced with the red wire, however I wouldn't suggest it unless all other options have been used.
Feb 25, 2011 | JVC AM FM CD DET FACE CAR STEREO
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
Need info on wire color coding for jvc car cd player: JVC KD-G140
Try going to the crutchfield website and look for help installing stereo. they can get you vehicle specific wiring codes for free. Also, almost everey stereo has common color codes for wiring. red- switched batt. +, yellow-constant batt. +, black= ground, blue- power anrenna, etc.
Apr 12, 2010 | JVC KD-G140 Car CD Player
JVC stereo not working properly - 2001 Sonata
generally wiring from the car is as follows...
red = ignition controlled live
yellow = permanent live
if you want stations saved and manual switch off of uni connect radio's yelow and red wires to the cars yellow.
if you want stations saved and radiounit switch off controlled by ignition (i.e only when car is running) then yellow to yellow and red to red. anything else will cause issues...
Feb 21, 2010 | JVC KD-R200 Car CD/ MP3 Player
My jvc car stereo show eject in the panel a nd
Check wiring. Yellow to Battery, Red to ignition sw, black to ground. Confirm the functions. If everything is OK, then connect speakers, antenna, etc.
Dec 31, 2009 | JVC AM FM CD DET FACE CAR STEREO
Just installed jvc kd-s16 and it loses power after 5 seconds. Used proper wiring harness and installed in 1996 f150
Connect Yellow to Battery (always 12V), red to ignition, and black to ground. Disconnect all others. Check it. If the radio stays on and plays CD, then radio is good. You may check other wiring
Dec 27, 2009 | JVC AM FM CD DET FACE CAR STEREO
1986 NISSAN 300Z THE STEREO WIRE WERE CUT NEED COLOR CODE PLEASE TRYING TO INSTALLED A FTER MARKET STEREO JVC
i have attached the wiring info you requested. be sure to test all wires with a meter before connecting. also a link to metra's website if you need an installation kit
http://www.metraonline.com/fitl.aspx
Battery RED/BLACK (+) RADIO HARNESS Accesory BLUE (+) RADIO HARNESS Ground N/A THIS RADIO GROUNDS THROUGH THE CHASSIS MOUNTING BRACKETS. Illumination RED/YELLOW (+) RADIO HARNESS Dimmer N/A Power Antenna GREEN/BLACK (+) RADIO HARNESS LF Speaker (+) BLUE/WHITE LF Speaker (-) BLUE/YELLOW RF Speaker (+) BROWN RF Speaker (-) BROWN/WHITE LR Speaker (+) RED LR Speaker (-) GREEN RR Speaker (+) BLUE RR Speaker (-) PINK
Sep 02, 2009 | JVC AM FM CD DET FACE CAR STEREO
Doesn't keep memory
DIKA, first step - check your stereo batt backup wire , you must connect that direct or continues voltage from accu. Don't switch this wire, you can check if your car in off position , this  wire must still have voltage +12v - +14v if no voltage check your fuse near batt backup wire. Why that wire must have voltage,that's because the voltage used for backup your stereo memori. OK good Try , Fixya and Don't forget to vote me, thank's
Aug 21, 2007 | JVC KD-G420 CD Player
JVC AM FM CD DET FACE CAR STEREO Logo
399 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
