Question about Freezers
Cold tech commercial reach-in freezer
A customer has a coldtech freezer that will not start the compressor or
condenser fan motors. the control board has power on the supply side but
not on the outlet side. when power is supplied to the condenser by-passing
the board, the circuit breaker trips not from a short circuit but what seems to be an overload. the start capacitors, relay, and compressor where all checked. the compressor ohms out fine,but i do think it is stuck. this compressor has an internal overload that is not open. the compressor on the condenser appears to have been replaced once.
my formal training tells me that this system is in need of a microprocessor and a compressor. the owner said the system stopped working after a storm.
    President:
  • Freezers Master
  • 2,651 Answers
Sounds like an issue witrh the microprocessor to me as well, although you tried bypassing it it still didnt work its quite possible that the fan aand compressor are runnig on different voltagfe the 110v , new energy effient compressors are starting to run w/ 220, an inverter built into the circuit board could be steppin up power,
Posted on Apr 09, 2008
Arctic air freezer
motor humming is from 2 things
start / run capacitor is failed
compressor is seized and the motor is not turning
call in an technician for a proper diagnosis and quote
Jul 08, 2016 | Artic Air Arctic Air F22CW12 Commercial...
We have a Bosch upright freezer GSN32A20GB. Recently we got the AL code and whislt the fgreezer seems cold I am not sure it is working properly. The compressor is very warm to the touch but I...
See if you have a condenser fan near the compressor if you do it should run when the compressor runs. You may have a fan inside the freezer behind the rear wall if so it should run when the compressor runs also.
The frost on the coils could be a problem if it builds up and block the air flow between the fins.This would be a defrost problem.
Sep 12, 2011 | Bosch Freezers
Compressor motor not working
Check to see if you have voltage. Check starting components (relay,overload, capacitor)
Feb 06, 2011 | Coldtech 40 cu. ft. Commercial Freezer...
Coldtech freezer door reversal
http://www.ascendmfg.com/PDFs/CT/hdmanual.pdf
start at this web site and see if this manual will help. It has phone number on last page if you need to call them.
ColdTech is now Jimes Corp. Just Google you unit if what I have does not help enough.
Good luck to you.
Oct 21, 2009 | Coldtech 21 cu. ft. / 595 liter Commercial...
Fan in freezer not working
It runs when the compressor runs except when it's in the defrost cycle. If you have an electronic control instead of a defrost timer the control could be the problem since it runs the fans. You can test the evaporator fan. See how here> How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Arctic Air 22 cu. ft. Commercial Freezer...
How long should a Coldtech 3 door commercial freezer take to get to optimum temperature? Should fyou feel heat on the exterior?
I tell customers to plan on a full 24 hours to get to optimum temp. And yes, there will be heat on the exterior.
Jun 14, 2009 | GE 13.7 cu. ft. General Electric Upright...
Coldtech 65slc-lh-may compressor cycling on overload. does it have internal overload?
Typically, I know all AMERICAN MADE fractional horsepower compressors do not have internal overloads.
I just was not sure if this MADE IN CHINA compressor might have a different internal winding design that included an embedded winding overload. Upon further testing, though, it seems that the start components and overload are external.
Thank you,
Jerry Bullock
Apr 05, 2009 | Coldtech 12 cu. ft. / 340 liter Commercial...
Freezers Logo
134 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
