Question about Tec Patio II Grill
My TEC Patio II burners both will blowout once they are hot. Are the burners repairable or must they be replaced? How are they removed from the grill?
  • 6 Answers
SOURCE: Expensive TEC Grill Problem with Blowout After Ignition
HI nabber8391,
I have a TEC Pattio II. I have owned the grill for almost 10 years and TEC grills have a ten year warranty on many of the parts including the burners. The burners on my grill have a ceramic inserts. The pop and loud whooshing noises indicate the ceramic insert or the seal on the burner is "cracked". I have replaced both of the inserts and burners on my grill once about 5 years ago under warranty. I have one burner now that will not stay burning and I contacted TEC today regarding the problem, and I will replace the ceramic insert only under warranty. .
The newest TEC grills like yours have the TEC Radiant Glass Infra-red Cooking System with stainless steel burners with glass surfaces. I assumed this burner system had eliminated the problem of the burners going out with a loud boom.
YOUR ONLY OPTION IS TO CONTACT THE CUSTOMER SERVICE GROUP AT TEC. THE TELEPHONE NUMBER IS 1-800-331-0097. TEC IS LOCATED IN COLUMBIA SC. TEC HAS A USEFUL WEBSITE.
By the way, I paid $1400 for my TEC grill in 1999, but I believe the new TEC grills are better. I know I would not buy any other brand. One other thought, it is imperative that cleaning instructions are followed.
Posted on Jun 24, 2008
SOURCE: tec patio II--convert from propane to NG
You'll need part #P2CKLP-NT Now all you have to do is find yourself a local TEC dealer
Posted on Sep 24, 2008
SOURCE: Tec Grill Sterling Model won't stay lit
The dealer is right. The ceramic burner is cracked. It will need to be replaced -- pretty pricey. I have the same problem on my Sterling III. This DOES happen too often. My opinion is that this IS a manufacturing defect. I have called the company about it (they are in South Carolina) and they try to blame the user -- that would be us. Very unfortunate company chooses to act this way. You hear about this problem again and again and again -- it's their problem but sadly, they are making it ours. Remember that when you go grill shopping next time -- I know I won't buy a Sterling grill again. Ever.
Posted on Mar 01, 2010
  • 3315 Answers
SOURCE: Right side burner failure on TEC Patio II
the mesh could be split or blocked burner needs cleaning .
Posted on May 18, 2010
  • 54 Answers
SOURCE: Looking for a replacement burner screen for a
http://www.appliancefactoryparts.com/gasgrillparts/brands/tec/
Posted on May 30, 2010
When was my TEC II made
From various reviews from folks who own the Patio II, I'm guessing 1998-2000. I have a Patio I that was purchased in 1996. It just died and I purchased a used Patio II so I have been researching this model. Also, found some videos on Youtube from repairing/rebuilding to how to cook on one.
Jun 18, 2012 | Tec Patio II Grill
Has Patio II for Grills gone out of business? Need to replace our burner in ours. Any idea of where to get parts other than maybe ebay? Thank you so much
Assuming you are talking about the TEC Patio II grill. it is made by the Thermal Engineering Corporation of Columbia South Carolina http://www.tecinfrared.com/home.php. the burners are sold as complete replacment parts as well as pieces of the burner sold seperately. It has a ceramic insert as part of the infrared burner. You may replace just that portion if that is all that is bad. if this has failed on your grill I would highly suggest spraying the four bolts that hold it in place (visible from the top of the grill with grates removed) with a penetrating oil several times over several days before attempting to remove them. Mine came out just fine and the grill is 12 years old. I love this grill even though there is a built in 12000 dollar grill on my patio.good luck
Jun 10, 2011 | Tec Patio II Grill
May 17, 2010 | Tec Patio II Grill
I have a Patio 1. For the last couple of years,
It sounds like your ceramic elements are cracked and will have to be replaced. This can happen when cold juices drip directly onto the red hot ceramic elements. The cracks can sometimes be hard to see. The latest generation of TEC grills have done away with these ceramic elements.
Feb 23, 2010 | Tec Patio II Grill
I have a Patio II that is about 10 years old. The
you can order new ceramic plates from tec it is only clipped in they should be able to send instructions
Aug 10, 2009 | Tec Patio II Grill
Ignites, but flashes, will not burn steadily
It sounds like grease has dropped down and clog your burner unit. It should be cleaned and then the flames should be even once again. You would need to use a degreaser to clean the burner unit which is located at the bottom base.
Jun 04, 2009 | Tec Patio II Grill
TECH II CERAMIC BURNER PROBLEM
just removed ceramic burners on my patio II-had to grind heads off of stainless stee bolts[ 4 on each burner],bolts do not have nuts instead they have theaded collers which have deteriorated and turn when i turned the bolt.used a 4" angle grinder-remove gas cylinder before attempting this!
Apr 11, 2009 | Tec Patio II Grill
HI nabber8391,
Jun 23, 2008 | Tec RadiantWave Grill
Tec grill problem
If mositure gets into the ceramic burners, then yes it is time for new ones. Was your grill also converted over to accept the new gas? Or another thing it could be that spiders are clogging the burner orifice.. If you contact a local dealer on Tec gas grills or someone that can service gas grills. Might be able to help you.
Fireplacegirl
Apr 23, 2008 | Tec RadiantWave Grill
Tec Patio II Grill Logo
280 people viewed this question
Top Tec Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Tec Grilling Expert? Answer questions, earn points and help others
