Question about Whirlpool Refrigerators
We have an Estate Whirlpool Side by Side Fridge and the water filter is leaking. Should we change the filter? When we remove the filter the dripping stops but as soon as we re-install the filter and twist it into place it drips thru a hole in the housing unit.
    Novelist:
  • 77 Answers
You have done some good work, and you are right on the money. Yes you need a new filter. There are o-rings that seal on each filter. These wear out but when you replace the filter you naturally get new o-rings and they seal better :) These seals used to be in the housing, but you can see the problem with that. Once those wear out, you have a much worse problem replacing those then with a filter. It's perfect really, you change the filter because you have too, and get a new seal at the same time!
Posted on May 30, 2010
Water dispenser dripping
Sounds like you have a bad water valve, it is located in back of refrigerator where your water line comes in. Change that and you will stop the leaking.
Jun 27, 2015 | Whirlpool Refrigerators
My fridge just started running water from under,not just a Lil drip,I even have to shut the main water line off....what do I do now?.
My refrigerator did this when the fridge temperature control door got stuck open and froze everything in the refrigerator. I tracked down the problem to a connection in my water supply filter. I just removed the filter and spliced the line. I doubt the same thing happened to you but you can probably find the leak by tracing the water supply to the ice maker/water dispenser.
Feb 21, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
We are getting an overflow of water in the pan in the bottom of the refrig. What causes that and can the pan be removed to empty?
This may sound strange, but the cause of your problem may be your icemaker. The fill tube may be leaking before it gets to the ice maker and causing the pan uner the fridge to fill up too much. try turning your ice maker off for a few days and see if the issue stops. Or you can see if the tube is loose or iced up. If it is iced up, you may have a bad water valve. If you need more assistance, let me know. Hope this helps!
Dec 10, 2009 | Whirlpool ES5FHAXS Side by Side...
My fridge is leaking because the drip pan is overflowing
I had this problem and it turns out that the filter cartridge had a leak and a constant drip into the drip pan. The drip pan is designed to capture the runoff from the self defrost but not a constant drip. The first thing you should do is remove your water filter cartridge - this will stop the drip until you can get a new cartridge. If that doesn't work just turn the water supply to the fridge off. You won't have ice but you won't have a leaky fridge either.
Aug 27, 2009 | Whirlpool ED2FHEXN Side by Side...
Ed25rfxfw01 whirlpool fridge water dispenser ...I have a slow drip from the dispenser hose. I assume I need a new water inlet valve. How do I access the inlet valve for replacing?
It should be on the right hand side in the back take off the compressor cover on the back should be 8 or so 1/4 screws nutdriver type and then two more hold on the water valve. If you have a RO system hooked up to refrig you may need to change the filters on the ro or just change the filter on the refrig. those two will also cause the water to drip thru the valve allowing it to drip on the front
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I BELEIVE THAT THERE IS WATER DRIPPING FROM HOUSING FOR FILTER
I opened up the housing and saw that when I removed the water filter that the water didn't leak out . I also turned the ice macine and water dispenser off.
Feb 11, 2009 | Estate TS25AFXK Side by Side Refrigerator
Wirlpool fridge leaking from filter
filter housing or the lines that are connected to the housing
have had a few of the lines that split i know it is hard to see under the fridge but you can remove the filter housing and unbolt the water valve from the rear of the ref and wangle thelines and housing to the rear of the ref to see where the leak is at
Apr 11, 2008 | Whirlpool ED2FHEXN Side by Side...
WHERE IS THE WATER COMING FROM UNDER MY FRIDGE?
very odd that there would be an influx of water to that pan, especcially enough to overflow it. a bit of a pain in the butt to remove that pan, try soaking some water out if it. and see if you can see where water coming from, id be willing to bet that the water filter housing right next to it is leaking and happens to be filling your drip pan, did you replace water filter recently?? perhaps its not seated properly.(regardless removing the water filter should stop the leak)
Mar 04, 2008 | Whirlpool GC5SHEXNS Side by Side...
Water leaking at filter
If this is a Pure source 2 filter in the upper right hand side of fridge, Purchase an Electrolux filter bypass, P/N 241944302. This is a empty cartridge that lets water flow without water drip when filter is clogged. Fridgidaire/Electrolux made no bypass in these filters, so when clogged they leak. Plus they NEVER last more than about 30/60 days. If you use the bypass, you will need a separate filter elsewhere such as in water line under sink or behind fridge. Call me at 816-560-8545 if you need more info.
Feb 26, 2008 | Refrigerators
Refrigerators Logo
105 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
