Question about Zanussi TC7114W Electric Dryer
How to put a new belt on a condence dryer do you take the back off or the front
How to replace veebelt for zanussi tc7114w?
Posted on Jun 12, 2010
    Top Expert:
  • Zanussi Master
  • 76,682 Answers
Go to the web link below for instruction's that work with all dryers
http://repair2000.com/wpoolbelt.htm
Posted on May 30, 2010
Good Morning: I have an older Kenmore Dryer with the serial # of : 77982600 and the belt broke. I can get the new belt but am wondering how it goes on. Do I have to remove the felt belt on the backside?...
dont mess with the felt on the drum... pop the top of the dryer. 2 clips hold it down.. use a screw driver to pop it. then take out screws on the front and bottom to remove the front part of dryer with the door . now put the belt around the drum put front on. then comes the fun part feeding the belt through pully tensioner good luck remove back to get to belt pully /tensioner
Aug 16, 2010 | Kenmore Dryers
How do i fit a new belt to my white knight cl447 wv dryer
Pop the top (spring clips) remove the front - use care with the wires. Find the belt tensioner on the floor of the dryer. Do a complete cleaning of the inside. Put the new belt around the drum get an assistant to help you hold the drum while you thread the belt through the tensioner and place the tensioner in the tensioner holder slots sin the floor. Put the front back on, snap the top back down.
Allow 2 hours for this job.
Feb 17, 2010 | Dryers
I need to replace the belt in my GLER341AS2 model Frigidaire dryer. How do i open up the dryer to do so?
Unplug the dryer and using a 1/2 inch pait scraper locate the spring loded clips holding the top down to the front of the cabnet. They are located about one to two inches from the front corners of the dryer.
Lift the top and rest it on the wall behind the dryer.
Looking inside the dryer locate the screws holding the front panel to the cabnet and remove the screws.
Mark the wires to the door switch and remove.
Remove the front panel.
Go behind the dryer and remove the small rear panel near the bottom of the dryer.Observe how the belt is attached to the pulleys.Release the tention on the belt by moving the belt tentioner and sliding the belt off the motor pulley.
Go to the front of the dryer and grab the belt on the top of the dryer drum. Holding the belt lift the drum straight out holding the drum with the belt.
Check to see if all the rollers are in good shape and rotate freeley. Oil if needed.
Check to see if the teflon gliders located on the front panel that hold the drum are in good shape. Replace if needed.
Vaccum the inside of the dryer.
Put the new belt over the drum and line the drum up and install back into the dryer.
Put the front panel back on and reinstall the two screws.
Replace the door switch wires.
Make sure the grooves on the belt are flat to the dryer drum
Put the top down and go behind the dryer'
Locate the belt.
Pinch the belt and insert it under the tention pulley and slide it over the motor pulley. Make sure the belt is positioned straight and located where the old belt was positioned on the drum.
Jan 03, 2010 | Frigidaire GLER341A Electric Dryer
Need help with installing belt in Maytag Electric dryer
if not able to remove rear panel,you will need to start,like most models,take top cover off and hinge back to wall then remove frt cover including door as a whole assy. lift up drum put new belt on drum ( and position in same area as old belt,it will have marks on drum from where original belt was on drum) then put rest of belt over mtr pulley and then idler pulley, turn drum by hand to align belts and put it back together in reverse order
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
Putting the belt back on this dryer
Hello Friend, Replacing a dryer belt is very simple. Just remove front of dryer cabinet. unplug wires from dryer door switch. Just slide a new belt over the drum with the belt grooves facing to the inside. Underneath drum you will see a tention wheel next to motor. Install belt around tention wheel and around motor shaft pully. Re-install front dryer cabinet. Make sure to plug in the wires to the door switch and make sure that the drum is re-inserted back over the felt glide on inner cabinet front. Happy to help, Tim.
Jun 26, 2009 | Hotpoint Dryers
Can't Put Belt On
You have to remove the front of the dryer to
access the drum. First unplug the dryer.There are screws at the bottom of the front to remove the lower section. Once you remove that you can get to the screws for the door section. The front of the drum rides on the inside of the front panel so when you remove the panel the drum will drop down. Try to keep the drum in place with something to hold it up. Remove the old belt and place the new belt around the drum. Slid the belt back to where the belt used to ride and then loop the belt around the motor and the tension wheel. Make sure the tension wheel is tightening the belt. Hold up the drum and put the front panel back on. You may need a helper to hold things while you do this. Rotate the drum by hand and make sure it moves smoothly. Plug it back in and give it a try. I hope this helps. Any questions feel free to ask. Please rate me so I know if I'm Helping. Thanks.
Dec 30, 2008 | Frigidaire FEQ1442ES Electric Dryer
Need to know how to replace the belt on my dryer
Take off front and put belt over drum. Reinstall front. Take small access panel off back to install belt on motor. Idler pulley pushes against belt to tension it. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Frigidaire FDE336RE Dryer
Clothes get lodged between dryer barrel and dryer frame
you need a new rear bearing kit and a new top front felt yes this is something you cand yourself. Frist unplug the dryer, with a stiff putty knife releace the clips on each side of the top at front to pop open the top. next on the inside of the front cover on each side is a philips head screw remove both screws ( I find it easier to use a #2 square head for this ) now remove the front panell diconect the door switch.now reach under the dryer drum behind the motor and release the belt by removing the tention on the idler pulley and slipping the belt off the motor shaft (you may be able to do this better fromt the rear of the dryer. there is an access panell remove the two screws and you can see the belt and idler pulley ) now using the belt in one hand and the front of the drum in the other lift up on the rear of the drum ( you are lifting the bearing out of the scocket you will feel it pop out ) now slid the drum out of the cabnet. Now you can repace the bearing put a piece of duct tape over the clip on back center of the dryer ( on the outside ) now remove the two 5/16 screws holding the bearing cup on remove the tape from the clip put ne clip on tape in place set new steel ball in cup i put a dab of the greace supplyed in the kit to hold it in put cup on new bracket. set in place and put screws in you may have to reach around the back to line up the clip teghten screws snug. now in the center of the drum is the bearing on the inside are three philips head screws remove all three some timse you can use a #2 square headi lossen all the screws frist almost completly the remove them one at a time or you will have to hold the bearing with one hand to keep it from spinning. Putting the new bearing on you have to put the screw in one hole hold it with one hand and line the bearing up with the other or get some one to leand you a helping hand makes it alot easier.tighten all three screws good and tight now reinstall dryer drum besure to seat the bearing in the bearing cup again you will feel it pop in put the belt back around the drum. Now on the dryer front you will see the felt support the fron of the drum glides on pull it off just the top felt only with a putty knife clean off as much of the old felt as possable. Apply a genurious amount of the glue provided in the kit to the new felt i always put a good line of glue on the dryer front also press the new felt to the front (be sure if the new felt has plastic glides the overhang should be toward the front not the drum if the new felt does not have these glides you don't have to worrie) put dryer front back on when putting the drum back on the top felt you may need to hold the new felt to keep it from moving. reconect door switch put the two screws back in the front. now go back to the back and putthe belt back on the motor pull the idler to tighten the spring put belt around motor shaft and ease pulley back to belt. Put access cover back on and secure. close the top plug it and test don't let dryer run long just a few seconds I like to let the dryer set 24 hour befor putting back to use to give the glue time to set.
Nov 23, 2008 | Frigidaire FEQ332E Electric Dryer
How to open the dryer and replace the belt
all dryers open from the top so open the dryer door and look inside the top edge you will see two screws . remove the screws and lift the top panel . the front panel has two screws on the top one on the left and one on the right remove them both and lift up the front panel to remove it. the only way you can install the new belt is removeing the front panel because the belt goes around the drum from the front. once you remove the old belt out put the new one in . the belt goes around the drum from the front and then to the motor and idle roller . you can reach the idle roller from the front left corner or from the back of the dyer? i like to install them from the back cause its more easy. in the back of the dyer where the hose goes connected to the blower is the top with four screws remove the hose from the blower tube and remove the four screws. after you remove everything you should be able to see the dryer motor and idle rooler put the belt over the motor first then over the idle rooler .always make sure when you do this the dyer is unpluged and after your done plug it back and turn it on to make sure it runs correctly . if it runs ok put everything back together again.
Dec 21, 2007 | Dryers
Hotpoint washer dryer leaking water whilst drying
driers work by running cold water down the back plate of the machine so the hot damp air condence's on to it. It works on the same principle as your bathroom mirror, because its colder than the air around it the moistier in the air condence's on to it. Most machines use a seperate inlet valve from the cold water to do this, they are proned to rub against the back of the drum.Take the top cover off the machine and check the hose's from the cold inlet onto the back of the machine you'll probably find a hole worn in it.
Oct 21, 2007 | Hotpoint Ultima WD72 Front Load...
Zanussi TC7114W Electric Dryer Logo
394 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
