Question about Troy Bilt 5.5hp Self Propelled Mower
I have a troy push lawn mower with a Honda engine. I have had it for 4 years now. The problem Im having and been going on for a couple of months, It wont start. Sometimes it will but i need to use carb cleaner, I also just put in fresh gas, when i put the fresh gas in it started, and ran for a few minutes acting like it was fixed. 3 days have passed and Im back to squire one. what should i do now
  • Troy Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 30, 2010
What year is a Troy bilt 13an77kg011 serial 1b129b80291
Im gonna say 2012. You can reinforce that by checking the first two numbers of the 'code' on the motor. Not the chassis numbers under the seat but the engine numbers on the engine?
Aug 26, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt lawn mower
This is not a common problem. The bolts are at fault. You can replace them and it will work but make sure they are the right bolts and you put them in tight.
Jul 13, 2013 | Garden
Looking at a Troy Built with a Honda engine. Is E85 (ethynol) gasoline a problem with the Honda engine?
85% ethanol is a problem for ANY lawn mower engine!
There isnt a single piece of lawn equipment made to run on any amount of alcohol. Let alone run on something with 85% ethanol in it!
You should drain the tank and carb and put in clean, fresh, non-oxygenated alcohol-free fuel.
Ethanol and methanol ruin a lot of the materials that lawn mowers are made out of. So you might be stuck doing a carb replacement along with changing out all the fuel lines and related items.
Jun 17, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Where do we find the honda engine model number on our Troybilt lawn mower?
a small flat surface...usually near the governor arm...the letter/number combination is "dot" stamped into the aluminum and kinda small....there will be a 4 letters and 7 numbers in a row...thats serial number...right above the 4 letters is 3 or 4 more, know as orientation numbers, that identifies usage...
Apr 18, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt lawn mower used months 2009 will not
stale gas in carburator...take the screw out of the bottom of the carb and let the gas run out...
Apr 17, 2010 | Garden
Troy built lawn mower (riding) won't go full
I did not know riding mower had a gas pedal. I know if you leave the throttle control up all the way the engine will choke out. The pedal you are pushing, I think, is the forward/reverse hydrostatic transmission. You may need a new drive belt. The one you have now may be stretched out.
Good Day.
Oct 07, 2009 | Troy Garden
Oil drain plug
Drain plug is not necessary. Remove the dipstick and tip the mower to the side the dipstick is on and use the dipstick tube as a drain.
Apr 20, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Oil drain plug
may be under the blade plate under the mower, usually a plug with a quarter inch square drive, you can use a ratchet to loosen it if it is quarter drive, maybe a half inch drive
Apr 20, 2009 | Garden
Troy Bilt 5.5hp Self Propelled Mower Logo
385 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
