Question about Mantis 2-Cycle Tiller
Starts hard; won't stay running
I have to pull many times to get it to run even a little; has to be choked heavily. When I do get it running, I have to run it partially choked and keep it running wide open or it will quit running again. I have exhausted myself over this thing! I noticed there are air bubbles in the see-thru bulb. Don't know if that is significant or not. It just seems it is not getting the proper amount of gas to start and stay running. I have not used it much at all. It is like new, but it is 2 years old. It ran good when I first got it, but each time I had more and more trouble starting it and keeping it running. I just gave up trying.
  • 857 Answers
There are 3 things that you need to check with any 2cycle machines. 1. Spark Plug - Make sure that it is clean and dry...Buy a box of what type you need and change them fairly often. 2. Fuel Filter - Keep of couple extras on hand, it doesn't take much for them to need changed also.
3. Exhaust port... Pull the muffler and make sure the exhaust port is clean on both the engine and muffler.
Buy a can of carb cleaner to spray out the carb and exhaust port every now-n-then. Put in a new fuel filter and plug...should start right away and run very healthy.
Posted on May 30, 2010
  • 2 more comments
  • djb514 May 30, 2010
    I can change the spark plug and I can change the fuel filter; BUT...the machine is very new. It has only one and one half tanks of gas run through it. Like I stated earlier, it has to run on partially choked, which has nothing to do with a spark plug. And it only runs wide open (using the most gas) and it will not idle at all. So if it doesn't idle but will run wide open, the fuel filter should not be the cause either. As for the muffler, it is still so new there cannot be enough carbon buildup there to cause a problem. So I believe the problem runs deeper. Do the air bubbles in the primer bulb, while it is running, concern you at all?
  • Jayant Jha May 30, 2010
    I think it's the carb(?) that has 2 "straws" going from it into the gas tank. One short, one long. There are holes in the bottom of the carb and these straws appear to push in to those holes snugly and just stay in there. Every time the tiller dies, you should take this all apart and find the longer of the two and check straws has fallen out of the hole.
    Getting it corrected should fix the problem.
    There ARE 2 straws; only one goes to the bottom of the carb, the other is like a dead end, which is attached to a little white cap of some sort and is positioned up in the engines plastic cowel. The one that is attached to the carb is attached to a plate with 4 screws in it and appears to have a gasket or diaphram under the plate. What would be under this plate that might cause a problem that I discribed?
    Sounds like a thorough carb cleaning is a logical next step. Hope there's nothing major wrong, like leaking crank seals or poor compression. You might want to check the carb/manifold/engine connections, because anything loose there will cause an air leak that could give similar symptoms.
Won stay running
Needs a carb adjustment, cleaning, or possible rebuilt. Try adding a little seafoam and running at half choke for about 5 mins or longer this may clean it up nicely. also check the spark plug.
Nov 09, 2013 | Poulan WEEDEATER FEATHER LITE 1500 GAS...
Crafsman 25cc weedwacker won't stay running
You probably have a bad hose or a bad hose connection that is sucking mostly air instead of delivering full fuel to the carburetor!
Apr 19, 2017 | Craftsman 25cc Gas Line Trimmer
My brand new UST 1200W generator engine start OK (single pull) when choke on but won't stay up when choke is off. I changed oil after the first 4 hrs of use. Has this to do with the gasline I used?
It is possible that it may be having trouble if you have some bad gas but I would be more inclined to check the float to make sure it is not hanging up and allowing to much gas to get to engine. I would adjust idle and fuel mix screw all the way shut and then start opening them up about 1/4 turn at a time and try to start and run between adjustments.Only try to start it once or twice in between adjustments to avoid flooding. If you can get it to run good then turn screws one more time or until engine starts missing a little then slowly close until it runs smoothly.Hope this helps you. Thank you.
Aug 29, 2011 | Gentron 1000w rated 1200w peak portable...
Engine starts but won't continue to run. Choke doesn't stay closed after starting. will stay running only if I hold choke closed manually.
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Aug 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
I have had my mantis for five years. It has always been hard to start. From the very beginning I had to move the choke in and out after it started to keep it from dying after it started. Each year it has...
I feel it might be time to overhaul the carburetter. Clean out all the passages and jets, especially the little screen that is pressed into a hole under the one diaphragm. Clean out the recess for the needle and seat and replace all the gaskets, the valve plate and the primer bulb. Also check the fuel tubes and the filter at the end of the intake tube (if it has one). If there is too much wear on either the choke shaft or the throttle shaft, it may just pay you to replace the carb completely.
Mar 17, 2011 | Mantis Garden
My 1998 Suzuki gsx 600 only starts ion full choke and won't stay running off of choke unless I run it about 20 min. Even then it dies off of choke what could be the issue?
What you have here is a fuel to air ratio issue. You are getting to much air to the engine and that is causing it to die when the choke is off. There is a screw that you can adjust for the air mixture, and this may take a little time to correct as it is a trial and error thing. All bikes are going to be a little different, even if they are manufactured by the same company. I hope that this information was useful as that is my goal.
Jan 18, 2011 | Suzuki GSX 600 F (Katana Motorcycles
I cant start my leaf blower
I would suggest a new plug and fresh gas and oil mix.push the primer bulb 8-10 times and turn choke to full.pull cord about 4 or 5 times until it starts.if it don,t stay running turn choke to half and pull cord until starts should stay running.let run for about 10 seconds then turn off choke.Almost forgot that during this whole process you hold throttle wide open.
Dec 08, 2010 | Garden
18"poulan chainsaw
Start at 1.5 CCW form lightly seated then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
I think your starting procedure may be the cause of flooding. Flooded is the #1 cause of hard starts in 2-cycle engines. Read carefully the recommended start in your manual. most miss the second note. It should be similar to this (read 3, read it again):
Warm start in the manual says 1/2 choke BS. Close choke, (sets fast idle) open choke, pull rope.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts (usually first pull).
If you still have trouble reply as you did before. I will get back to you. HTH
Lou
Feb 18, 2010 | Poulan Garden
Stihl ms-250 won,t start , and gas leaking from under the exhaust manifold , also plug seems not to be spaking even when dry . every time i try to start engine it floods . ?? the saw is only 3 mths old ....
You may need a carb rebuild kit. they are thin rubber diaphrams and will harden up and warp if not used regularly or if the fuel is improperly mixed.
These are easy to flood if you pull them too many times on choke. Pull it on HALF choke until it pops. then turn the choke off, into the run (I) position and pull it until it starts.
If it's flooded, remove teh plug under the cover, blow off the sparking end and pull the engine a few times without the plug. this will empy the cylinder. WATCH YOUR EYES!
Jul 03, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Need carb h/l ajustemts and idle controle ajustment
This does take a little time to get it just right. Start at one full turn for the h and l. Work on the high first and after you get the H running work on the Low. They have to work together. So if you get it to idle and run at full throttle but it hesitates when you pull the trigger just adjust the low a little higher.
May 02, 2009 | Poulan Pro Chain Saw 46cc 20"
Mantis 2-Cycle Tiller Logo
133 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
