Question about Whirlpool 1.6 Cu. Ft. Over-the-Range Microwave
Turns on and rotates, does not heat the food. noisy hum
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If it’s a loud hum/buzz sound then 90% it’s usually a bad magnetron and other times it’s a bad high voltage diode. However, from what you have described it seems to be the magnetron. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 02, 2010
3 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave turns on and rotates
With these symptoms,you probably have a shorted high voltage rectifier diode or a bad magnetron.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting & testing.
We\'re happy to help you with free advice and we\'d appreciate your thoughtful rating of our answer.
Posted on Sep 09, 2008
bestdarngood
  • 3037 Answers
SOURCE: Microwave will not heat food and is noisy
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on Apr 29, 2009
GE microwave occasionally buzzes loudly.
make this test and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Nov 14, 2013 | Microwave Ovens
Made a grr noise then shut off will not turn back on
follow this test and fix it. God bless you
Nov 06, 2013 | Emerson MWG9111SL Microwave Oven With...
Gh5184xps3 microwave
this cause noise ; God bless you
  • MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  • Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  • Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  • Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replace
  • Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2ZPm395lp
    Jul 18, 2013 | Whirlpool Microwave Ovens
    Microwave makes sound like something moving inside
    follow this steps and use the VOM , and fix it. God bless you
    Jun 18, 2013 | GE JVM1490 Convection/Microwave Oven
    I have a 2001 GE Spacemaker #JVM1840CD001 that does not heat anything, but runs. What's wrong and how can I fix it?
    If your microwave oven "works" meaning that your display, cooking tray rotates, and the light turns on when you open the door, but does not heat the food, the problem usually is with the magnetron circuit. If you hear a loud hum when you try to heat something in the oven usually means that the magnetron has failed. The replacement magetron is about the same price as a new oven, so you are better off buying a new oven.
    Feb 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    GE Spacemaker XL1800 hum/buzz noise but heating works
    the magnetron needs replacement my friend, although you can still heat up food but eventually it will soon fail.
    appreciate your kind comment
    Apr 12, 2009 | GE XL1800 1100 Watts Microwave Oven
    Microwave does not heat food or liquid
    I hate to tell you this but your magnetron may be shot. Its the part that actually makes the microwaves. The best thing I can recommend is get a new oven, magnetrons are expensive and not easy to replace.
    Mar 20, 2009 | GE JVM1650 1000 Watts Microwave Oven
    GE turn table microwave stopped warming food
    my microwave 1640GB from GE suddenly cannot heat food and make some noisy sound. as it is mounting in the closet, it is not easy to replace. any solutions or suggestion
    Mar 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    Whirlpool 1.6 Cu. Ft. Over-the-Range Microwave Logo
    119 people viewed this question
    Top Whirlpool Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Jaime Hernandez
    Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
