Question about Roper REX5635E Dryer
My Roper REX5635EW1 simply will not start whenever I press the start button. I have checked the breakers and everything seems to be fine. What do you think the problem is?
5 Suggested Answers
SOURCE: Roper Dryer
You may have tried this but every time mine has ever stopped and refused to restart was because I forgot to clean out the lint in dryer screen.
Posted on Aug 10, 2008
AlmostBob
  • 550 Answers
SOURCE: No heat
The most common cause of no heat to an otherwise functioning dryer is failure of the thermal cutout.
As well as the electric line fuses in the circuit there are devices that look like this 13889aa.jpg or this 284f4e0.jpg screwed to the exhaust air duct with wires to the terminals
, inside the dryer. If there is a lint blockage in the duct or fan or outside vent hood, the air tempoerature rises and melts out this thermal cutout (also thermal fuse, heat protector, heat cutout & any other names different makers use) before causing a fire.
Test with an ohmmeter or battery and lamp bulb, conducts good, no conducts fail-replace.
Despite the number of models of dryer there are only a few thermal fuses, and the local parts guy WILL have the blown one on the shelf, as GE if not as roper part.
Whil the dryer case is opened is a good time to vacuum out the exhaust vents, fan impeller, and vent hood. ounce of prevention and all that
Posted on Sep 06, 2008
aasc
  • 1606 Answers
SOURCE: MY ROPER DRYER QUIT HEATING STILLS WORKS NO HEAT
The thermal cut-off , which is the small t-stat looking piece located at the top of the element housing ( on vertical mount elements ) or the far front of the element housing ( on horizontal mount elements ) , is usually the cause for no heat .
Posted on Aug 02, 2010
  • 113 Answers
SOURCE: I have a roper dryer
No, reset button on these. It may be the lid switch or the thermal fuse. This is what I find most of the time. Check out the diagram on apwagner.com and you'll see the parts locations. Oh, if it's not the thermal fuse of the lid switch it may be the timer. I've seen this a couple of times.
Posted on Oct 24, 2010
My roper dryer worked fine yesterday. It won't work today
remove back cover then locate the blower housing in the back,its round on this is a thermal fuse appx. 1" X 1/4" with 2 wires from it,this is the thermal fuse test it,if its open on continuity its bad and the dryer wont operate the pat number is FSR# 3392519
May 21, 2012 | Roper REX3614KW Electric Dryer
Dryer was working fine. Finished one load. Second load, pressed the start button, it wouldn't start. Thought door didn't close all the way so I opened/shut it, pressed start. Nothing. Is it time to spend...
a simple solution could be take a pencil and push the door switch in and out if it clicks its probably wrking if not replace also check your breaker hope it helped and make sure your timer is on a cycle
Feb 27, 2011 | Roper Dryers
I have a roper dryer that was working fine than all of a sudden just stopped turning. I've checked everything I know circuit breaker. Does the roper dryer have a reset button???
Oct 24, 2010 | Roper RGX4634KQ Gas Dryer
My Roper dryer Model #RGS7648E will not start
Here is a tip that I wrote that will give you a list of things to check...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 05, 2010 | Roper RGS7648E Dryer
My Roper dryer suddenly won't start. Was running
Is it gas or elec?
Have you checked the breakers?
Does the outlet have power?
Model# ?
Try setting timer in a different cycle.
Make sure door is completely closed.
Push door switch in manually does it click?
Please update lat me know what else I can do to help.
Ken
Mar 17, 2010 | Roper Dryers
Won't run
ensure your door switch is working then move into timer.
May 05, 2009 | Roper RES7646KQ Electric Dryer
Dryer suddenly stopped working completely
FUSE!! LOCATED ON THE BACK OF THE DRYER IS WHITE AND OBLONG SHAPED
Apr 27, 2009 | Dryers
Cartridge message
There is some problem on the sensors or on the firmware of the product.
try to reset the printer by:
> unplug the power cord without turning off
> try to press and hold the power button without the power cord
> then press and hold the pound key "#" and the number 3 key at the same time while plugging in the power cord.
> dont release buttons yet, release it when you are prompted on the display like "Partial NVRAM Reset"
> then after doing all of the steps, try to print or copy and check if it would still prompt the error message
Aug 25, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Roper Dryer
Jun 29, 2008 | Roper REX4634KQ Electric Dryer
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Dryers Logo
22 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
