Question about Sony KWP-65HD1 TV
Picture is starting to double from left side of screen to right
Is there anyway of correcting
    Novelist:
  • 144 Answers
That doubling from the bottom is indicating a defect in the Vertical Output section. It's most often an Electrolytic Capacitor that contains an electrolyte which is drying out because of a failed seal at the component.
Usually it's only one Capacitor that causes this defect. If you are capable of replacing a circuit board or can find that defective capacitor (sometimes they give them self away as a bulging envelope of the capacitor and replace it then you are needing a qualified technician to make a house call.
Zashiban
Posted on May 30, 2010
Sony kdl52xbr4 tv has double vision on right side of screen perfect picture on left side is this a timing control board issue?
Fault with its T'Con board itself. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 14, 2015 | Sony Televison & Video
The top of the screen is slanted while the sides of screen and bottom are even, causing the right hand side of screen to appear smaller than the left. Anyway to fix this?
Sounds like a "keystone" problem. Your projector needs to be oriented to the screen in an exact manner. Manufacturers provide "keystone" correct to adjust for mis-alignment. If proper orientation is impossible, use the keystone correction of the unit to adjust your edges.
Aug 14, 2010 | Hitachi Cine Master PJ-TX200 Multimedia...
Blurry picture on left side double image right side is ok....
Ur convergence is dead,need convergence kit.
U know how to solder right?Tries these websites for convergence kit.Tv Repair World.com,Shopjimmy.com,Ebay.com or Partstore.com
Sep 25, 2009 | Zenith IQB50M90W 50" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Samsung SlimFit TX-S3082WH Blurring on Left and Right Sides
your picture tubes is going bad. i've had 5 yes 5 of these tv's replaced by samsung/bestbuy. i've kept buying the PSP (product Service plan) now my most recent tv is doing the same. samsung no longer makes the picture tube for this model. i've already called them. it was a nice tv. i've gotten about 6 months out of each model. I'm moving on the LCD, nice rca 32 inch HDtv model at walmart for less than 500.00.
Dec 28, 2008 | Samsung SlimFit TX-S3082WH 30" TV
Akai pt5598hdix convergence problem.
go to the following link and click the contact link on the lower left side and tell them your model they will email you with the correct convergence ICs that you need for your model. they also provide free installation instructions with pictures and free tech support when you order the replacement ICs.
http://servicemanuals.vstore.ca/
Apr 22, 2008 | Akai PT5598HD 55" Rear Projection...
Installation
the cd that came with the camera is not compatible with vista
anyways thats just a editing software...you can download the picture using the plug and play...
turn on the camera
plug the camera to the computer
select connect usb to computer
wait for the screen of the camera to fade black
wait till there pop out a screen if not try to go to my computer and look for the removable disk storage device..
double click the drive then you will see a dcim folder
access that you will see another folder 100sscam
double click it again then you can see the pictures that you tooked
to transfer it copy and paste it to a specific folder...
copy and paste....
highlight the picture..all of them
right click select copy
then go to a specific folder that you want to save it into
double click the folder then right click
select paste then its good..transfer complete...
Jan 12, 2008 | Samsung Digimax S500 Digital Camera
The screen picture bulges inwardly on the right and the left
you have defective horizontal linearity! replace the capacitor at the hot side mostly 160uf 180V or 160uf 160V.
Oct 02, 2007 | Recoton Advent Advent Q2035A 20" TV
Sony KWP-65HD1 TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
