Question about Coleman Mach 15 Air Conditioner
Bad capacitor? how do I know if the capacitor is bad?
    Guru:
  • 587 Answers
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the GreenCOLEMAN R.V. PRODUCTS
Bar.
You can get Service Support or Email address and Phone numbers.
Posted on Jun 01, 2010
Tv popped and went off, there are 2 circuit boards how can I tell which is bad, power board or audio video board,, no lights on tv work at all, complete zip
If you Heard a popping sound. Most likely it was a capacitor that went bad. Yahoo search capacitor to see a picture.
Usually capacitors swell when they go bad. if you Don't know How to spot it. Concentrate on the circuit board you plug connects to and check to spot the capacitor. You might not actually have a standard capacitor. So look for a film capacitor as well.
Good luck
May 19, 2016 | Vizio L32 32 in. LCD HDTV
How do I identify a bad capacitor on a Samsung LN55C610N1F power supply board?
you can tell by the top of them,when there bad they bulge ( as if there going to pop )
Nov 26, 2015 | Samsung Televison & Video
Wont power inverterit has power to the wall to the power board but the tv wont turn
google the manufacturer and model number and the words "bad capacitor" or "replace capacitor" and see if someone has photos of a retrofit for broken capacitors. You need to know your way around a soldering iron but there are hundreds of computers and flat screens that got bad capacitors installed. For someone who knows how to solder they can look at a photo with the bad capacitors circled, check their own product, pull the bad capacitors, replace and have a great TV again. I did this with a Sceptre Naga 3.
There was one year when perhaps 1/5th of the capacitors made were bad (one factory in china). Lots of manufacturers knew that they had problems but shipped anyway. At least one computer manufacturer has been successfully sued on this.
Feb 05, 2014 | Westinghouse 40" 1080P Lcd Hdtv
My TV goes off I turn it back on on it goes right back off.I have to keep turning it on for like 30 mins then it might stay on for a hour. the start all over
You did not give a model number. But, I do know what you are talking about. I have repaired many Magnavox and Philips TVs. There is, in this case a weak capacitor. A bad capacitor will rise in voltage and create a high voltage shutdown, in others a weak capacitor will not start up a TV. For some reason the 25 volt, 47 MF capacitor enters my mind( goes weak/bad in many of these). In any case there is a bad capacitor lurking inside. Thanks for asking and show all hands of support!
May 10, 2011 | Philips Televison & Video
POWER SUPPLY WENT OUT, IS IT WORTH FIXING THIS TV?
You may have bad capacitors on the power supply board.
If you know how to repair electronics (soldering etc) you can replace the capacitors.
Check to see if any of the capacitor tops are bulging up. If so replace ALL except for the Large one which should be good. BAD CAPACITORS ARE AN INDUSTRY PROBLEM SINCE SOME BAD ONES WERE MADE SEVERAL YEARS AGO.
Feb 13, 2011 | Philips Magnavox 42MF521D/37 Television
Green and red light flahing tv wont turn on
There is a problem inside the unit that is why you are having the blinking lights.
Blinking lights simply are symbols for you to know there is a problem with either one or more components in the unit.
Mostly, it has to do with power problems, either a bad ic problem, bad capacitor or bad power panel.
For bad ic you will have to assess all the panels in the unit to be able to detect the ic that is faulty, for bad capacitor you will have to assess all the power panel or the main board to be able to check and replace any bad capacitors, and if it is the power panel, all you have to do is to assess the power panel to see if it is burnt or have a bad capacitor, then replace the power panel or replace the capacitors.
Take care
Oct 23, 2010 | Toshiba Televison & Video
Goodman model F48F97A76 need to know what the
if your condenser fan motor is not bad. change out fan capacitor
Apr 08, 2010 | Heating & Cooling
Power bottom is blinking blue, monitor doesn't turn on ? Is this monitor death ?
Yes. Might be bad capacitors on the board. Bad capacitors bulge when they break. A repairman might be able to fix it. Although with the right knowledge and 30 dollars for solder, solder iron, and a couple of the right capacitor might do it for you if you know.are a repairman.
Mar 06, 2010 | HP vs17
TV won't turn on
If that large capacitors is defective, the TV should still power up normally but it might produce a humming noise through the speakers.
I would suggest to check very carefully the capacitors on the secondary side of the circuitry, specially the 1000uF that filter the 5vdc line.
Let me know if you require further assistance.
Dec 02, 2008 | TruTech PLV16320 Television
Gateway C51GU01 MOTHERBOARD (no video)
I supose you should test the capasitors one by one.
Faulty capacitors :
http://www.asti-usa.com/support/appnotes/65/2.jpg
if the capacitors arent flat they are possibly bad note in the picture the blue / black capacitors are flat. the black orange capacitors all seem bad. the two are bad for sure.
Apr 04, 2008 | Foxconn 865A01-PE-6EKRS Motherboard
Coleman Mach 15 Air Conditioner Logo
236 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
