Question about Cosco Baby Gear
I cant get the cosco play yard pack and play to latch
I cant get the cosco play yard pack and play that i just got to latch on the bars so it can stand up... I have held down the button as hard as i can and yanked it straight will all my strength and i cant get it to stay or even latch at all. Please HELP ME!!! The model information on the product is COSCO Funsport Play Yard Pack and play Model Number 05038AAC
5 Suggested Answers
Chummy_57C
  • 6 Answers
SOURCE: Folding up Cosco play yard
My wife and I have the same model for visits by our granddaughter. She was having the same trouble as were you and, like you, we did not have instructions.
I'm happy to share with you what I found to close the model up for storage. It may not be the same as what the manufacturer envisioned but it worked for us.
-- With the pad removed from the inside of the Pack n Play, pull up on the red handle so as to loosen the legs;
-- Next, you will find there is a big button in the middle of each of the long sides of the Pack n Play. Start with either long side. You will have to press very hard on either side of that button; I found it helpful to use both hands, one pressing on the outside of the playpen, the other hand pressing on the inside of the playpen. Pressing these together will loosen the long support arm at the open top of the Pack n Play.
-- Do the same for the opposite long side.
-- You will also do the same, one button, one side at a time, for each of the two short sides of the Pack n Play.
-- Now pull up on the red handle in the middle, and guide the four corners so they meet and close.
-- Cover.
I found the buttons may not have fully allowed the support arms to collapse, thus blocking the Pack n Play from folding down completely. If so, try pressing the button again (both the outside and the inside at the same time).
Hope this helps!
Posted on May 22, 2009
SOURCE: cosco playard playpen
hey guys, wat you have to do is keep the middle of the playpen up, the very middle thenyou lift up all the sides until they click...once all 4 sides have locked you press the middle of the play pen down and put the mat on top :) hope this helps
Posted on Feb 21, 2010
SOURCE: Play yard assembly COSCO Funsport L-3
for Model Cosco Funs Port Play Yard
Just pull the cord in the middle of the upward and straighten out
each poll one by one. If you have someone that can help you
open the play yard pull lightly up the four sides and while you're holding them up, pulled the middle strip that located inside pull it up it will lock all four sides at the same time.
I don't have childred, but it drove me crazy that I couldn't do this
until my wife said maybe this is how you do it, I tryed it and it worked. I hope this helps everyone. Regards,
Frankie.
Posted on Mar 09, 2010
Thank you, Frankie! We could not figure it out for the life of us. We had moved the play yard upstairs and could not figure out how to re-assemble it! My grandson was loooong overdue to be put to sleep for the night so we were anxious to figure it out. You were a life saver! Thanks!
P.S. we couldn't believe how simple it was to figure out once we knew what we were doing!
Posted on May 31, 2010
How to fold down the cosco funsport play yard.
There is usually buttons under the cover in the middle of each side? Squeeze this and the side should collapse, then usually a pull up in the middle which reduces the cot right down. Hope it helps
Apr 16, 2012 | Cosco Juvenile Cosco Funsport Playard
Can you send me the directions for setting up the cosco playpen
Try this step by step instructions Hope it help you
Instructions
1. Unfasten the floorboard from the folded play yard frame by loosening the hook and loop tabs holding it in place.
2. Unfold the play yard and set it upright with its four legs on the floor. Pull out on opposite corners to spread the legs of the frame.
3. Pull up on the plastic handle in the center of the floor of the play yard to unlock it fully.
4. Pull up firmly on the center of each of the four side rails until they click into place, while continuing to pull up on the center handle.
5. Push the center lock down until it clicks all of the legs into place.
6. Place the padded floorboard into the play yard.
7. Locate the two hook and loop tabs located on the underside of the floorboard and pull them through the slots in the bottom of the play yard frame. Secure the tabs underneath the play yard.
Jul 02, 2011 | Cosco Juvenile Cosco Funsport Playard
How do you disassemble the Cosco Funsport Play Yard?
Steps to disassemble.1) Pull up on the loop in the center.2) Flip the Funsport upside down3) Pick a side and pull the corners up slightly while pushing the center down. Sides can only move up about an inch.4) Press the release catch in the center of the bar.5) Pull the center of the bar up while holding the release catch in. Sometimes you have to wiggle the catch in and out to get it to release.6) Repeat for each side.7) After each side is collapsed squeeze everything together.8) Place the cover on the floor black side down.9) Put the Funsport on the cover with the plastic corners flush with the edge of the cover. The wheels should be sticking out the bottom.10) Wrap the cover around the Funsport and secure the velcro straps.
May 16, 2011 | Cosco Beatrix Potter Playard Crib
Locking the top of cosco playpen
How do I set up the costco play yard; I cannot make the side bars lock -- and there are no instructions with it.
Jul 01, 2009 | Cosco Beatrix Potter Playard Crib
-- Cover.
Hope this helps!
Jan 06, 2009 | Cosco Beatrix Potter Playard Crib
Frankie.
Jul 11, 2008 | Cosco Beatrix Potter Playard Crib
Cosco playard playpen
May 31, 2008 | Cosco Metal Crib
you also need to hold one of the middle indicator tabs on the longer side..because if you don't do that it will not shut... and make sure the 2 legs go inside with the center of the play pen
Dec 03, 2007 | Cosco Beatrix Potter Playard Crib
Baby Gear Logo
60 people viewed this question
Top Cosco Baby Gear Experts
Jennifer Rock
Jennifer Rock
thegtw
noel
noel
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
