Question about Acer AL1717 17" LCD Monitor
Moniter has flickering and moving stripes
Moniter has flickering and moving stipes. installed updated drivers but problem still the same. please help
  • 11,361 Answers
You may have power supply failing, but try this monitor with other PC first, if it still does not work then you will have to open it up.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 30, 2010
My dell moniter 2010f flickers all the time. I have another moniter on that uses the same card by does'n flickers. I also pugged the dell in by its self and it still flickered. l also down loaded...
Sounds like an issue with the backlight in the monitor. Usually the backlight is built in to the LCD panel so there really isn't a way of fixing this unless you replace the panel.
Please rate my solution to show your appreciation!
Jun 02, 2011 | Dell ST2010 20 inch LCD Monitor
Black static lines and static clicks when I move my mouse[wireless mouse] also sometimes a small part of a picture about 1' will show and flicker a while. also a static click when I move the mouse can you...
If you let me know which type of mother whether CRT or LCD, it would be better for me to give the specific instructions. Well, before you start troubleshooting internally, please check the connector and make sure it's correctly and firmly connected to the Vga port. Now, after that, update the drivers. Again check for the refresh rate, sometimes very high refresh creates the display to flicker. If you recently installed driver for the monitor, please uninstall it and again reinstall. Still having problem? Please let me know. I am here to assist you further. I only provide the nearest solutions. Good luck.
May 23, 2010 | Computers & Internet
Action replay ds acting CRAZY!!! HELP ASAP HELP!!!!!!
try putting the code in a couple of times then try without the - and then put the id code in fully with the - and hopefully it works
May 31, 2009 | Datel Action Replay for Nintendo DS
Overall pink cast and pink stipe at top of all images taken.
Never had that camera, however, had the same problem -- the pink stripe and pink cast. Turns out the lens cover was slightly cracked and not opening and closing properly. Thus -- the pink cast.
Mar 26, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
when it is loading press a b start and select at the same time then let go when it starts after that update you action replay and all the games come back
Dec 06, 2008 | Datel Action Replay for Nintendo DS
Stripes on Display, is there a way to repair?
If you have tried to reload the drivers and the same thing you still have stipes on the display... uuum i sugest change your screen.. normaly when LCD gets stripes no option but to change it.
cheers
Aug 27, 2008 | Fujitsu LifeBook T4210 Tablet PC
G Flatron L1515S 15" LCD
monitor display center line problem
Aug 14, 2008 | LG Flatron L1515S 15" LCD Monitor
My LG Flatron L1515S Lcd moniter is Flickering
i am having also same problem...
Reddy - 9700704407
Flickering Moniter
take the monitor to a mates house and test it out their, then post here the outcome and i will go into loads of deatil. good luck.
Oct 09, 2007 | ViewSonic VX2245WM LCD Monitor
Acer AL1717 17" LCD Monitor Logo
237 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
