Question about Jandy Air Energy Heat Pump - 115,000 Btus - Chiller Model
High limit light on. does not head
Jandy LAARS- LT
  • 17,970 Answers
Several things there:
  • The thermostat may be set too low
  • Inadequate gas supply
  • Malfunctioning thermostat
  • You are losing heat faster then you are adding it. (If the heat loss in the pool is greater than the heat input, the heater might be too small or you may need a thermal barrier). Use a thermal barrier to help prevent heat loss
Keep that the heater should resume heating automatically if the timer turned off the system.
Its possible that you need the User Guide like reference:
- Link 1
- Link 2
Check you troubleshooting items in Support link.
Posted on May 30, 2010
  • 1 more comment
  • 7toledo May 30, 2010
    I have a Jandy Pool Heater LAARS LT low NOx gas heater.
    I appreicate your response, but I do not know what I am supposed to do with that information. Specifically, what should I do to check those things?
    I went to link 1 and link 2 but those were different heaters than I have.
    thanks
    Steve
    I did go to the user manuel for my product.
    I looked up trouble shooting .
    I found Hi Limit isue. there were 2-3 suggestions that ended in refer to an expert.
    My goal was to see if there is anything I can do.
    thanks
    steve
    can you help me further?
Jandy Lars LT fans doe not turn on and error flashes hi limit
check safety circuit and see if high limits are corroded also see if fusible links are tripped
Nov 27, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Laars LT - "red" light
means calling for heat if heater doesn't come on check safety circuits
Feb 12, 2011 | Jandy Laars LX Pool Heater / 400,000 BTU /...
How much time would a technician need to replace a high limit switch on a Jandy Pool Heater?
Thank you for posting your question here on Fixya.com.
It should only take a few minutes to actually replace the part; quite a bit longer to diagnose the problem depending on the way the switch failed and overall condition of the heater. It would not be unreasonable to get a bill for an hour to troubleshoot and repair a heater with a defective high limit switch.
John
Sep 21, 2010 | Jandy Laars Lt 250,000 Btu Heater
Where is the hi temp limit switch located?
where is the high temp limit switch located on my laars 44000 pool heater
Jun 02, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Jandy LX250 LT Pool Heater High Limit Switch
Jump the High limit switch. If it fires the switch is bad
Jul 16, 2009 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
Laars Lt heater will not start- pressure switch light
it is time to check your filter make sure is not dirty and if your filter is clean and still doing this then the problem can be with one of the safety sensors they do have 2 hight limit switch located in the heater heather they re round with two wires on each one turn power off to heater and get a voltemer reader and check the hight limits for continuty they should read zero on your metter it can be your temp sensor heaters are so complicated that it is always good to have a pool tech service it I was a pool tech in california but now I am located in georgia
Jun 13, 2009 | Jandy Laars Lt 250,000 Btu Heater
Hi Lim SW fault when trying to heat pool.It is a Laars lx 400,000
heater over heated check gas pressure then replace high limits also make sure chemicals in balance
Jun 06, 2009 | Jandy Laars Lt 400,000 Btu Heater
Jandy Air Energy Heat Pump - 115,000 Btus - Chiller Model Logo
23 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
