Question about Dometic Heating & Cooling
I have a Duotherm/Dometic RV rooftop Air Conditioner model # 620215.321 series I need a wiring diagram for. I'm missing the electronic controls and want to convert it back to mechanical controls. It has the optional heat strip.
  • mrbenz7 May 30, 2010
    This is helpful1 I believe that I have enough here to rewire this unit for Mechanical controls, thank you!
  • 857 Answers
Go to this link It may be very helpful for you this is the link for the entire manuel :
http://www.bdub.net/manuals/DuoTherm-Quick_start3102904.020.pdf
Posted on May 30, 2010
I have a Dometic DuoTherm ac/furnace unit in an rv. The thermostat got knocked off the wall and now the ac nor the furnace will work. Fan works in manual position only. What could be wrong?
When the thermostat was knocked off it may have damaged the wiring. I would start by checking continuity of all wires from thermostat to unit.
Feb 15, 2015 | Dometic Rooftop RV Air Conditioner
I have a Dometic DuoTherm AC/furnace in my RV. Thermostat got knocked off the wall. Now only thing that will work is the fan in the Manual mode. Heat nor air will come on. What could this be.
If you have properly re-attached all the wires to the old or newly installed thermostat, then I would suspect that one or more of the control wires to the heat pump have either been severed or pulled loose from the heat pump.
Thermostat wiring diagram for Domestic RV rooftop AC
go on internet look up troubleshooting dometic rv a/c's
Feb 13, 2015 | Dometic Rooftop RV Air Conditioner
Does the fan shut off on dometic ceiling cover control model
that would depend on the fan setting of your thermostat
Jun 18, 2014 | Dometic Rooftop RV Air Conditioner
DuoTherm mark 2 rooftop ac 620426-321
need to see if drain pan stopped up or fan blowing water off coil
Jul 11, 2013 | Dometic Rooftop RV Air Conditioner
Rooftop RV Air Conditioner: my duotherm rv ac rooftop 15,000 btu the free...
If it's the pencil type, it just pokes into the fins (carefully)
If you look real close with flashlight you should be able to see where it poked in before, usually a couple of inches up from bottom. If it's the little round disc, it snaps in down in bottom corner, there should be a small hole for it in the frame.
May 17, 2010 | Dometic Rooftop RV Air Conditioner
DuoTherm Model 59516.331 needs heat strip added
MODEL SERIES: 579XX, 590XX & 59516 (60XXXX, 61XXXX ON PAGE 2) ALL MODELS ARE PREWIRED WITH A POWER RECEPTACLE IN THE ELECTRIC BOX FOR EAS Y INSTALLATION
USE PN 3101121.030 HEAT STRIP,FOR NON-DUCTED MODELS
Dec 12, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
79 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
