Question about Home
Glacier bay gal toilet.
Glacier bay flaperless 1.28 gal toilet. On the flush, water splashes off the bottom of tank and comes out over the lip on right hand side of tank .
    New Friend:
Buy American!
Posted on Apr 02, 2013
  • 349 Answers
Does the tank lid have a seal on it to keep water from coming out?
Posted on Jun 01, 2010
I just installed a new glacier bay dual flush toilet. The tank won't fill unless I lower the fill valve by hand. Then it overflows the intake tube.
Make sure that you have installed everything correctly. Have someone else go over what you did because returning that thing is a PIA!!!!!!!!!!!!!!!!!!!
Sep 16, 2017 | Glacier Bay Home
Where can I get a replacement handle/flush lever for a 2006 Glacier Bay 1.6 gallon toilet?
Glacier Bay Toilets are made in China by "various manufacturers" a local plumbing parts supplier is your best bet.
Jan 11, 2016 | Home
HOW TO SET WATER LEVEL GLACIER BAY TOILET
There should be a adjustment screw at the top of the fill valve, screw it up or down to adjust the tank level.
Sep 13, 2014 | Fluidmaster Glacier Bay Flapperless Toilet...
I have both a dual flush and a conventional high eff. toilet. the water level on both are set on maximum. but the dual flush won't flush toilet paper in a single fluh. can i change out the complet
Why do you want to change it out just because it doesn't take paper out ? The problem is in your trap. Don't change it unless you just want to. I don't think you can change it over anyway due to design differences.
Feb 23, 2013 | Home
Where can I find replacement parts?
home depot etc, most hardware stores.
Mar 30, 2012 | Home
I have a Glacier Bay dual flush toilet that makes hissing noises sporadically. How do I make it stop?
I have a glacier bay dual flush toilet. I have had it since 2009. When it started the hissing noise I tried diff things to fix it. New water valve, new washer from tank to bowel.
The food die in the tank showed water was leaking into the bowl. As a result the water would try to keep filling the take every time a little water escaped making it hiss. Sound familiar?
Finally I contacted someone on line home depot and the glacier bay manufacture was the main people. You need a silicone washer that goes in the main center piece mechanism that lets the water into your tank. You need to remove the center main piece in your tank. at the bottom inside the mechanism itself is a washer the size of a coffee mug top circle.
You can only see it if you take apart the two pieces. Once this goes inside your problem WILL BE SOLVED. The manufacture sent it to me for free. She knew right way. What causes the problem is cleaner tablets in the tank or bad water. So that's it folks
Jan 28, 2011 | Home
I recently bought a Glacier Bay 303-635 All-in-One toilet. It was installed just fine, however everytime I flush the toilet the tank fills up to the water line, but the spout over the water line tube keeps...
Try adjusting the water level down about a half inch or so and see if that helps. It could just be siphoning. Otherwise the valve may be defective. Hope this helps.
May 11, 2010 | Home
Home Logo
892 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
