Question about Amana Refrigerators
Fan is not coming on without help - Amana Refrigerators
  • 2 more comments
  • Dan Webster
    Dan Webster May 30, 2010
    which fan?
  • kuffed58 May 30, 2010
    the fan on the bottom of the refrigerator.it keeps the freezer from freezing when it isn't working
  • kuffed58 May 31, 2010
    the model number is thi212w
  • Amana Master
  • 8,220 Answers
Most common ice boxes use a 2 watt 115 v cw motor. A fairly easy fix. Post your model number so I can see what you have porvavor?
Posted on May 30, 2010
  • Dan Webster
    Dan Webster May 31, 2010
    What did I tell ya? I looked up the model. THIS is what ya need!!!!
How do I turn on without the remote control
If it came with the remote & there are no pull chains on the fan, then you probably can only use the remote. Probably needs a new receiver. What make/model of fan is it?
May 18, 2014 | Dryers
Why doesnt cooling fan come on with heater on but comes on with defroster on a 1996 ford thunderbird
The cooling fan should come on when the coolant temp reaches around 200 degrees F. regardless of what position the heater switch is in.
The fan comes on when the defrost is on because the defrost automatically turns on the A/C. The A/C dries the incomming air to help clear the windshield.
Aug 21, 2012 | Ford Thunderbird Cars & Trucks
Fan stopped working
Without knowing the model, I would first check the fan motor for seizing, then if not seized, I would replace the fan capacitor. (Available at most appliance parts stores or
HVAC parts stores). If this is a motel type PTAC unit (through the wall) I would be looking
at the control panel as the third item to check, as these fail often.
The fan capacitor is a small cylinder with usually 2 wires coming to it and at least one of them come from the fan and has its values stamped on the side.
Hope this helps.
Jul 17, 2011 | Heating & Cooling
How to install the ceiling fan, asahi brand, i just want to know how to install my ceiling fan without any technechians help
If one switch works fan and light put the black wire and the blue wire together on the fan and connect to black wire coming from cieling and connect white wire from fan to white wire from ceilling
Jun 21, 2011 | Heating & Cooling
I have done replaced the radiator the thermostat but its still running hot what else could it b
I'd check the fan clutch. If it wears out then the fan will free wheel without drawing enough air through the radiator. If you have electric fans, you want to make sure they are coming on. If they don't come on you will overheat in a hurry. Hope this helps. Good luck :O)
Feb 19, 2011 | Oldsmobile Bravada Cars & Trucks
THE FAN IS NOT KICKING ON WHEN THE HEAT IS TURNED ON. COULD THIS BE DUE TO A FAULTY THERMOSTAT? DURING THE SUMMER IT WOULD NOT TURN OFF AND ON AUTOMATICALLY NOW IT WILL DO NOTHING. THE FURNACE COMES ON,...
yes it could be due to a bad thermostat. What I would try is to turn The thermostat to fan on setting and see what happens.On this setting the fan should come on and run non stop. If the fan does not come on but the main burner will I would suggest that you change fan motors. I hope this helps. If the main burner is coming on and then shutting off without the fan coming on it is probably going out on hi-limit. Thank you
Nov 29, 2010 | Weather King 10AJA3601AH Air Conditioner
Fan not coming on with or without aircondition and
Engine fan will only kick in when engine is hot and needs extra help in cooling down, If it doesn't come on so long as engine temp remains ok i shouldn't worry about it too much..
Jun 22, 2010 | 2001 Volkswagen Golf
Faulty Fan in Rinnia 2000 gas heater
You are right
The gas valve has to come out to remove the fan.
Get a gasfitter to do it.
Jul 08, 2009 | Heating & Cooling
System fan does not come on.
if the out door unit has been working carefully jump red to green the fan should come on if not problem is bad fan motor or capicitor or fan relay hope this helps
May 24, 2009 | Heating & Cooling
The rad fan is loose, how do I tighten it
Hope your fan has not fallen off.
There is two posibilities I can think of.
The fan is bolt to a fan-clutch, these bolts rarely come loose without help.
The Fan clutch can come loose but it too usually needs help from some one to loosen.
I think you should have a technician look at it to make sure what is causing this.
If on the other hand you have had recent work done, the fan clutch may have been left loose.
Good Luck
Dave
Mar 13, 2009 | 1998 Chevrolet S-10 Pickup
Refrigerators Logo
43 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
