Question about Garmin GPSMAP 392 GPS Receiver
I have a marine unit model 392. it won't turn on. i confirmed that it has power bit it does not turn on. it worked last season and was stored in a dry environment in my home. help please
  • marshman99 Jun 03, 2010
    I have a Garmin GPSMAP model 498 GPS/chartplotter. This unit worked last season but when I put it in this year, it won't turn on. I have confirmed that there is power getting to the unit. Do you have any thoughts on what to do? I wrote to one of the other experts who told me to press the reset button but there is no reset button. Help, please. Thanks.
  • marshman99 Jun 05, 2010
    I have a Garmin GPSMAP 498 chartplotter. This is a gps, depthfinder, chartplotter for use on a BOAT. It worked last season and now will not turn on. I have confirmed that there is power going to the unit, but it won't go on. THIS IS NOT A GPS FOR USE IN A CAR, so please dod not respond with information about those units. Also, I do not see an external reset button.
My new 392 gpsmap will not show the correct mph.?????
Posted on Aug 29, 2010
    President:
  • 4,070 Answers
Hi! The board of the unit may just be dirty. Try blowing compressed air to clear out the dirt on the board. This can resolve the problem. Hope this helps and have a good one!
Posted on Jun 05, 2010
    Brigadier General:
  • 3,917 Answers
Thanks for contacting Fixya.com
Try to hold reset and then press power to reset software. This would reset the unit and restart.
Let us know if you have something more to know else please accept the suggestion.
Thank You.
Posted on May 31, 2010
  • marshman99 Jun 01, 2010
    my bad. the model that i have is the GPSMAP 498 and I don't see a reset button. thoughts?
  • 4,924 Answers
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted.
There are three steps to take to get your Nuvi 265W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
Posted on Jun 03, 2010
  • Catalin Turcu
    Catalin Turcu Jun 03, 2010
    try first to reset from a button that should be hidden for protection on a side womewhere in a hole that fits a pin or a ballpoint tip..also may try remove power and battery todo that ..sometimes it is enough ..if not read the post on the links ..to see how to do the hard reset ..it needs connected to the computer ...and download that tool to connect after that you will have to log inand see the right firmware for your exact model..it is available on their support site...Remember that will mess up the presets ..and you will have to set it again like you need..
Why doesn't it turn on?
Check all wires and connections. If u confirm power reaching the innards of unit then there is an issue with the power supply of printer.
Mar 12, 2016 | Canon Pixma MP500 All-In-One InkJet...
My Humminbird fishfinder 525 won't power up. I checked the power going up to the unit and I have a 12.5 dc volts read. What else can I do or check? It's not under warranty...
You have sufficient power for your system. Do you have your power cable mounted into the factory gimble bracket? If not then it is possible to have your power cable pushed into the receiving port on the head unit reversed. This can only happen if your power cable is not in a fixed position. The reverse polarity of the battery will be sensed by the unit and it will not turn on. IF your system has worked without issue and now does not it is possible the head unit is fried and unrecoverable or if you live in a northern latitude and did not store your unit indoors last winter due to the Arctic cold temps we experienced last winter you may have frozen your liquid crystal display and if so your unit is toast. Unfortunately if it's not a power issue you are going to be reinvesting in the spring.
sorry I can't givery you better news.
Dec 02, 2014 | Boating
Jabsco toilet fails to fill
Was the toilet "Winterized" last fall? If so, have you assured that any plug in the clean water intake has been removed? If NOT -- are you sure the pump has not been frozen and internally damaged by ice? The pump is a simple device which rarely fail unless its inlet is blocked, or the pump seals or body are damaged - usually by freezing.
May 10, 2014 | Jabsco 29120 2000 Marine Manual Marine...
Simrad Shipmate CP32 Chartplotter won't turn on - any suggestions
bad key pad rick or power on and off switch
Jun 11, 2013 | Boating
I have a convection bread maker. I made one loaf of bread tonight and i unplugged the machine. 30 minutes later, I tried to make a second loaf ant the menu select wouldn't work but the start and mix in...
Cuisinart has many different bread machine models. Next time you ask a question, please include a model number. Thank you.
Here's my generic best advice for you dear:
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source you're accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on toggle power switch. Turn it to the ON position.
    2. Some models confirm power by making and audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press and hold the Select button down until the unit powers up.
    5. Some models require you press and hold the Start button down until the unit powers up.
    6. Some models require you select a mode first by pressing the Select button.
    7. Some models require you press and hold the Stop button down until the unit powers up.
Were you able to confirm that your breadmaker is receiving power?
No. Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or simply discard it.
Yes, Fantastic! Now reboot the breadmaker's electronics by pressing and holding down the Stop button down until you receive a visible and/or audible confirmation, usually within 1 to 5 seconds. Note: Some models require you press and hold the Start button. Others require you press and hold the Select button.
Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics.
All breadmaker use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn when it's supposed to, your belt is probably broken. You'll need to disassemble the breadmaker to visually confirm.
Jun 13, 2011 | Cuisinart Kitchen Appliances - Others
I have a 10-year old Carrier Gas pack Model #48GS024060301. Turned on the heat for the first time this season and the unit did not turn on. I was able to turn on the house circulation fan and since it...
If the induction motor ain't going I would look for a blown 3 amp (purple) fuse on the control board. If that was good I would check if any of the roll out switches were tripped. If a rollout switch was tripped check or air restrictions somewhere.
Oct 17, 2010 | Heating & Cooling
Repeated transponder issues with the lowrance 320c fishfinder
Reading the manual it does say that there is a temperature range for these. I"m not sure where you live but it might be cold enough that it is damaging the transducer in the off winter months.
Jun 01, 2009 | Eagle Fisheasy 320c Fishfinder
When turned on, the unit sounds like it will start then turns off within a minute.
Presently according to my information there is no recalls for Fedders products at this time for this model type.
May 27, 2008 | Fedders A&B Chassis A1A07W2B Air...
Garmin GPSMAP 392 GPS Receiver Logo
116 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
