Question about Toshiba Satellite A305-S6863 Laptop
How to find battery location inside computer
How do we find battery location inside computer to remove it in order to airblow computer?
    Problem Solver:
  • 7 Answers
The battery of a laptop pc is located on the bottom of the system and can be usually take out by pulling the cover that holds battery in.
Posted on May 31, 2010
Where is the battery located
Underneath the air cleaner housing. To remove and replace if you can start the car turn steering wheel fully to the right or remove tire. Open hood, disconnect remote battery terminals, remove air intake filter box, remove vented panel inside front of right wheel well. On these cars you will have to disconnect exposed positive cable battery terminal first. BE CAREFUL YOUR WRENCH DOES NOT TOUCH ANY METAL WHILE REMOVING TERMINAL FROM BATTERY POST. Loosen and remove the two bolts on the tie down that secures battery in place. Slide battery until the negative terminal is exposed, disconnect and slide battery out into wheel well. Reverse order to install new battery.
Jun 22, 2014 | 2002 Chrysler 300M
Unable to log in
Which operating system ?
The Compaq Presario CMOS password is an administrative security measure built into the firmware of a Compaq computer.
This password is stored in the motherboard's BIOS (Basic Input Output System) and provides for hardware-level security.
This password may be accidentally set or forgotten over time and must be reset in order to boot the computing system.
Disconnect the Compaq computer from any electrical sources and remove the side access panel from its case.
This may require the removal of one or more thumbscrews on the rear of the computer case.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules
Locate the CMOS battery.
This battery is a round button-type battery located in the bottom-right corner of the Compaq Presario motherboard.
Grip the battery by its edges and pull it straight away from the motherboard to remove it.
Press and hold the power button on the case for ten seconds to remove any remaining electrical current from the computer.
This removes the CMOS settings and returns it to the default state of having no password set.
Replace the CMOS battery.
Replace the computer's side access panel and re-establish any previously severed electrical connections.
http://www.youtube.com/watch?v=zjGHpJqVJkM
Replace a CMOS battery inside a desktop computer
http://www.dewassoc.com/support/bios/bios_password.htm
http://www.tips4pc.com/articles/Computer Troubleshooting/Remove the CMOS battery to reset the bios password.htm
Jan 14, 2014 | HP Compaq Presario SR5450F (KJ383AA) PC...
Toshiba bios password reset
Are you ok to open your computer? There is a jumper switch inside, which will solve your problem if you can locate it and move it. Or, a simpler solution is to find the CMOS battery, it will be labeled, and remove it for 5 minutes, then put it back.
Dec 21, 2013 | Computers & Internet
How do I replace a y510 cmos battery
Locate your CMOS battery
Caution: When inside your computer make sure you're aware of ESD and all it's potential dangers.
cmos.jpgOpen the computer case and find the battery on the computermotherboard, verify that it will be accessible and that it can be removed. Most computers today use a coin cell CMOS battery as shown in the image to the right.
If you are unable to locate your CMOS battery refer to your motherboard or computer documentation or contact your computer manufacturer for additional assistance in locating it.
Obtain battery information
Unfortunately, most manufacturers will not list the exact type and model of your CMOS battery; therefore, once you have located the battery, write down all information about the battery (Voltage, chemistry, wiring, and packaging). If possible, remove the battery and take it to the location you plan on purchasing a new battery from. The part number for this battery for most computers is CR2032.
Additional buying information can be found on our battery buying tips page.
Removing the battery
If you're computer is using a coin cell battery similar to the above example picture. Removing the battery is relatively simple. use your fingers to grab on the edge of the battery and pull it up and out of the container holding it. Some motherboards have a clip holding the battery down. If your computer has this clip you may need to use one had to move the clip up and the other hand to pull the battery out.
Unfortunately, not all CMOS batteries are removable; some manufactures will only allow a replacement battery to be added. If you're not using a coin cell battery and are not able to determine how to remove it refer to your motherboard or computer documentation or contact your computer manufacturer for additional assistance in removing the battery or how to insert a new replacement battery.
Users with computers that do not have removable batteries only options to install a new battery will most likely also need to set a jumper when adding the new battery into their computer.
Insert the new battery
Once you have purchased a new battery, remove the old battery (as instructed above) and replace it with the new battery.
Enter CMOS values
Once the battery is replaced turn on the computer and resetting the CMOS values to the defaults. After the values have all been entered make sure to save the settings before exiting. Many CMOS setups allow you to press a key (such as F10) to save values and exit all in one action.
If after following all the above steps you continue to experience the same error when your computer starts or your computer is still unable to keep the stored values it's likely that you're experiencing a more serious issues. Most likely causes are bad power supply or bad motherboard.
Apr 19, 2012 | Lenovo IdeaPad Y510 Notebook
How do I remove the battery from my Gateway 5072, do I need a special tool
You shouldn't need a special tool to remove the CMOS battery.
Remember to unplug the computer from the wall before you go poking around inside the computer.
The battery should be located directly on the motherboard and should be easily removable with your fingers.
Dec 24, 2011 | Gateway GT5220 PC Desktop
Find the cmoss battery d505
Unplug the Dell Latitude D505 laptop from AC power. Turn over the so that the base of the computer faces upward. Locate the battery panel on the bottom of the computer and then press the latch on the battery panel in the direction of the arrow on the latch. Lift the battery from the battery compartment.
Press on the latch located toward the front of the computer inside the battery compartment. Pull the cover that is released out and down and remove the cover from the battery compartment.
Grasp the small battery in the slot uncovered when the cover was removed and pull the battery away from the slot to detach the battery from the laptop
Dec 12, 2011 | Dell Latitude D505 Notebook
I need to remove bios password from dell latitude x300
Hi there !
You can remove the BIOS password by removing the CMOS battery located inside your laptop and in the motherboard. Turn off your computer and remove the battery before opening the computer and remove all the screws at the back of your laptop to reveal the motherboard and remove the battery.
I hope it helps you. Good Luck
Jan 10, 2011 | Dell Latitude X300 Notebook
Where isw the cmos battery
it's inside the computer, it's a small round, flat, silver battery similar to those in watches and tons of other devices. It stores the clock time when the computer is shut off. You will need to take apart the laptop carefully in order to get to it. Is your clock getting reset everytime you turn it back on? Then yes you will need to replace the battery.
Jan 21, 2010 | HP Compaq Evo n610c Notebook
The ac is working, but we can't get the airblower
I would check the controls and see if they in fact are actually sending a signal to the blower relay. From what you have said I would assume that is what has failed.
Good Luck,
Gilshultz
Dec 03, 2009 | Heating & Cooling
Lost system password
Only way to remove a BIOS password on any computer is to remove all power sources from the motherboard so its memory can be cleared.
First, remove the main battery from the laptop. Then you must locate and find the little coin cell battery (It looks like a watch battery) on the laptop and remove it for about a minute or so. Then you can replace them in the opposite order.
Your coin cell battery is in a bay on the bottom of your computer. Enjoy!
1. Before removing the coin battery:
2. Locate the memory module cover on the bottom of the system.
exmem01.jpg 3. Use a Phillips screwdriver to remove the two screws securing the cover.
4. Lift and remove the cover from the system.
5. Locate the coin battery.
6. Use a fingernail (or small flathead screwdriver, if necessary) to release the battery ZIF connector.
exmem08.jpg 7. Remove the battery from the chassis.
8. Reverse the previous steps to replace the coin battery.
May 06, 2008 | Dell Latitude C400 Notebook
Toshiba Satellite A305-S6863 Laptop Logo
162 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
