Question about Brother HL-5240 Laser Printer
Printing support lines on paper when printing. Already changes toner.
First repleace toner cartridge if is not help you need to repleaced drum
elvis
Posted on Apr 18, 2008
Or toner or drum
elvis
SOURCE:
Why do I get bleed through of print on pages I print out at bottom of page or shadow print on some?
Paper is too thin (use higher "pound" paper).
-or-
Toner is not of good quality (use HP Brand if possible)
-or-
Printer is set to dark or heavy in your page setup (change to normal or even light)
You can also make sure you are using an HP print driver instead of a generic print driver. Go to HP.com and search print driver for you model, download and install (if you don't already have an HP printer driver loaded on your PC).
Jul 29, 2014 | HP LaserJet 3050 All-In-One Printer
Color Laser Printer Pink Tint
have you tried cleaning the charging wire and the transfer belt
Feb 17, 2014 | Ricoh Aficio SP C420DN Laser Printer
I have an HP3500 which I've had from new since 2004. On the whole it's been remarkably reliable but recently I have problems with a multicoloured stripe which appears down the lefthand side. It...
Hi Richard,
Dots, Lines and smudges on the printouts are usually due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and inspect them. You may observe the lines on the green drum. Gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines. (corresponding to the location where you are having a green line on the paper)
Also, make sure that the visible inside of the printer are clean and there is no spilled toner inside, which sometimes results in dots.
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Observing the PCR with the help of a sharp torch light would let you assess the condition of the PCRs at the corresponding location where lines are appearing. Replace the Cartridges one by one and inspect the prints for the changes. I think you would be able to identify the faulty cartridge/ rollers. Also, if the waste toner area is filled and/or the plastic wiper/ cleaning blade removes the leftover toner/ waste from the drum and holds the waste is worn out, it results in spilled toner usually at edges and at early stages lines only.
Moreover, the function of the fuser is to fuse the toner onto the paper and it is usually done at the end of the printing process just before the paper is ejected (and the image/ toner on the paper is just fused - not changed). The fault at the fuser area usually results in smudges, ghosted image or unbind toner (which easily gets erased when touched). The time during the printing cycle when the toner is spread on the paper, additional toner (resulting in lines) is shifted to the paper due to cartridge related issues, which results in lines. Note that after cleaning the rollers, the print quality improves and the lines disappear or lighten. Try and check if the above suggestions work.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 16, 2011 | Office Equipment & Supplies
Prints on my Lexmark T632 have a dark line running from leading to trailing edge of the paper. Toner cartridge replaced but didn't help. Lots of toner scattered through out the printer.
Great job on replacing the toner cartridge. Most probably problem's on the fuser or the charge roll. They may need to be replaced. But also check maintenance count to see if you have already reached the 300,000 prints. It affects the print quality when you have reached the limit.
Jun 24, 2010 | Lexmark T632 Laser Printer
4 faint lines running vertically down the sheets of paper
just open the printer cover and clean the toner with tissue paper and make sure the toner is not damage othewise you have to replace the toner.
Sep 09, 2009 | Samsung ML 2010 Laser Printer
Dark Horizontal Lines on Faxes
on the drum unit that you put your toner inn, There is a blue or green slide lever move the slide back and fourth 10-15 times. If you have some van air blow that area out ( F.Y.I. if you do this some toner will fly out ) if this does not take care of it the drum unit my be bad,
do a 1/2 print test. copier something with a lot of print. open front cover when the paper is 1/2 way through the machine remove drum. Look art the paper and the green drum if the marks are on the paper & drum then the drum is bad. If not the fuser asm is bad, the part that gits hot when melting the toner on the paper,
Jan 29, 2009 | Brother IntelliFax-2820 Laser Fax
Looks like toner is not sealed to the paper.
the machine is only designed for 80gsm paper. you can change paper type through printer options in printer manager to card stock. it wil probably not work though as it is really only designed for 80gsm paper. the toner need to be heated to 200oC inorder to fuse to the paper cardstock absorbs less heat than normal paper.
Jan 03, 2009 | Samsung CLP 300 Laser Printer
Spots on paper
Look on the image drum (bottom of toner cartridge) are there spots on that?? if so clean carefully so as not to damage it or replace the cartridge. If this is not the case open the cartridge door during a print, but before the paper fully enters the fuser and check if the spots are already there, if not the fuser is causing the problems.
May 14, 2008 | Lexmark E321 Laser Printer
Printer is printing black line
Dirty Primary Charge roller. Change the Toner Cartridge.
Bad Toner Cartridge. Replace the Toner Cartridge.
Mar 07, 2008 | HP LaserJet 4 plus Printer
Brother HL-5240 Laser Printer Logo
100 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
