Question about As Seen On TV Wonder Steamer Kit Iron
How does Wonder Steamer work?
I don't have the instruction booklet for the Wonder Steamer. I bought it used. I need help using it. The first time I put water in it and plugged it in, the steamer didn't even seem to steam. Help!
Conair steamer green light comes on but low water beeps. water full.
How To Use The Conair® Deluxe Fabric Steamer
www.conair.com/how-to-use-the-conair-reg-deluxe-f...
Conair CorporationThe Conair® Deluxe Fabric Steamer (model # GS11DR) conveniently rolls to any spot in your ... This unit comes with a rotating hanger. ... The switch will light to indicate when power is on. ... Note: If the low water indicator lamp becomes illuminated but the water tank is not empty, follow the instructions for decalcification.
[PDF]Instruction Booklet - ExtremeSteam® Upright ... - Conair
www.conair.com/.../gs95_13pa140688_ib_final.pdf
Conair CorporationMar 1, 2013 - ... water only. 8. Plug the steamer unit into a standard 120V AC power outlet. 9. ... Push button on T-nozzle - light will go on and steam will start.
Customer Reviews: Conair Extreme Steam Fabric Steamer ...
Aug 16, 2013 | Irons
Water left in steamer - need to clean clear tank
I'm willing to try this to clean the mold out of the steamer container and possibly the rest of the attachments:
1. Empty the water reservoir completely. 2. Place 20 mL of CLR or bleach into the reservoir. 3. Fill the reservoir with hot water. 4. Shake the reservoir to mix and let stand for about 1 hour. 5. Empty the reservoir completely. 6. Rinse the reservoir 3 or 4 times with cold water. 7. Fill the reservoir with distilled water. 8. Run the steamer into the ventilated air a couple of times to ensure that there is no CLR or bleach residue on the evaporation elements. Thus, there will be no bleach on your cloths.
I have the same problem and will try this out tomorrow. I will tell you how it turns out.
Mar 14, 2009 | Rowenta Compact Steamer - White
Conair steamer leaks water and wets my clothes.
When I use mine I hang the hand held part from my closet door, while I am waiting for it to heat up. When the hose gets too much condensation, from the steam, it leaks out... This will also happen if you try to use in the motion of an iron. The hand held part needs to be at a vertical position at all time to prevent leaking.
Jan 24, 2009 | Conair Compact Garment Steamer Iron
When using steam iron i am left with a puddle of water on the floor how do i control the amount of steam
I think is maybe the hose connections. You need to make sure both ends (by the T-nozzle and by the body of the steamer) are secure. You have to align the nozzle with the rod, and push down, and twist. Try watching instructions for connecting both ends on www.HandBookLive.com under appliances category. There are GS4 video instructions and GS10 (this one has just been posted yesterday)
hoe it helps. Otherwise I would return the steamer. Nowhere in the operating instructions does it say that you can control the amount of stream produced...
Laura
Sep 27, 2008 | Conair Compact Garment Steamer Iron
Rowenta commercial steamer
got this off the manual for the IS 7800
CLEANING
Remove water container and clean the main unit with a damp
cloth. To maintain maximum performance, your steamer must
be descaled occasionally. The descaling intervals will depend
on the water quality and the frequency of use. The unit should
be descaled at least once a year or every 100 hours of use.
For descaling proceed as follows:
1. Unplug the unit and remove water container from main unit
by releasing container lock and pulling up.
2. Fill it with fresh water and shake vigorously to remove any
scale. Pour out the water and repeat if necessary.
3. Purchase a quality decalcifier agent and follow the instructions
of the manufacturer for the proper ratio of the mixture
to water and use.
4. After filling the water container turn it up and down to
descale.
5. Attach reservoir to unit, plug in and switch on.
6. Let the appliance run until the water container is almost
empty and do not steam any clothing with this mixture.
7. Unplug and detach the water container. Rinse it with fresh
water.
8. Fill water container with fresh water and repeat steps 5 and 6.
Note: If after descaling you believe that there is still buildup in
the boiler, repeat steps 1-8.
Jul 22, 2008 | Rowenta Commercial Garment Steamer - White
Conair steamer
Fill it with boiling hot mixture of half water half vinegar. Let it sit two hours. Rinse and repeat as necessary. Hope this helps you out.
George
Jul 03, 2008 | Conair Compact Garment Steamer Iron
Would you return this PS200 steamer?
If the steamer starts making a "gurgling" noise, like its running out of steam, hold the hose straight up for several seconds. It says to do this in the manual and gets the steam flowing again--works great!
Jun 13, 2008 | Homedics PS-200 Iron with Auto Shut-off
Wonder Steamer
Have lost the cord & instruction booklet for the Wonder Steamer.. Can you help?
Feb 20, 2008 | As Seen On TV Wonder Steamer Kit Iron
Conair GS4 Steamer
faa3e02.jpgthis is from conair instructions included with steamer, finally found it, hope it helps some!
Oct 28, 2007 | Conair Gs4 Iron
Irons Logo
207 people viewed this question
Top As Seen On TV Irons Experts
Are you an As Seen On TV Iron Expert? Answer questions, earn points and help others
