Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
SONY BRAVIA KDL-40S2010 40"
Turned on tv----green faces, light lavender background----NO COLOR
Cable co. says they are not having anyother difficulty with anyother customers in my area, so it has to be the tv.
How can I get the color back????? It's only 2 years old.
  • 1 more comment
  • Anonymous May 27, 2008
    I have the same problem, same tv, same size, about 2 years old. Not only have I had green faces but now I have a red and green lines flickering through the screen
    Les2longbeach@aol.com
  • Anonymous Nov 12, 2008
    Mine does this, too. If I turn off the TV and turn it on again, the color returns to normal, but often changes back to green & pink when channel surfing.
  • tavot344 Jan 18, 2009
    Same problem on 2 yr old unit. Pink and green shadows on the screen looks psychodelic, but that is not what I want.
Mine isnt even 1 year old and same problem. was fine last night, woke this morning, turned it on and there they are green and purple
Posted on Aug 05, 2008
SONY BRAVIA KDL-40XBR2 faces look like cartoons
Tow possibilities. [1] The LVDS cable (the flat cable that connects between T'Con and LCD panel) loose contact at its connection sockets. Re-insert this very carefully, and check. [2] Fault to T'Con board itself. If so it should be replaced. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 28, 2014 | Sony Bravia XBR-Series KDL-40XBR2 40-Inch...
Sony Bravia KDL-60EX700 BAL Board / Flashing Green Amber
It sounds to be a firmware trouble. Will be best to contact the authorized service center for Sony, rather than trying to do it by yourself, as it is a very skilled work, need both concentration and previous experience. google.com/+GopakumarGopalan
Nov 24, 2013 | Sony Bravia Kdl - 60Ex700 60 inch 1080P...
Sony bravia kdl- 52w4100 52 in. LCD tv
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 26, 2012 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
KDL-40s4100 power light on, black screen
Main PCB is bad . I just got the information from a Sony authorize servicer price for the part only $504.87
Nov 27, 2011 | Sony Bravia KDL-40S4100 40 in. LCD TV
My sony bravia screen turned green I do I fix it?
When the color of the screen is complete green, you should not worry. That is the normal color that should be on the screen when no program is coming in because the cable box is off. So simply press OK on the remote of your digital box and your will see picture on your TV. If none appeared, then there is problem on your cable box. Call then your service provider.
Nov 29, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Oct 07, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Color screen
If you are hooked up with a DVI cable you need to either use hdmi, component cables or turn off the non hd override...
Jun 15, 2008 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Dvd screen is pink
If you are using component cables to connect the DVD to the tv make sure you have the red,blue and green colors on your cables matching these colored jacks on the tv and DVD jacks. If one of these cables is plugged in wrong or not plugged in it could cause this. Good Luck
Jan 04, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony bravia lcd tv-
If you are using a HD cable box or satelite with component outputs, be sure that all 3 cables ( green, red, and blue ) are making good connection.A loss of red or blue will cause color shift. Usually,if the tv menu comes up as the correct color but the picture dose'nt, it is most likely a signal problem.
Jul 01, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
712 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
