Question about Sewing Machines
The casing that holds the bobbin has come out how is this put back? Janome 1012
  • 40 Answers
Insert the case with the little arm in the top 12 o'clock position. Make sure it clicks into place by pushing it until it clicks.
Posted on Jun 01, 2010
Bobbin shuttle fell out
About 8,950 results (0.69 seconds) Search Results
    Inserting the Janome Front Loading Bobbin Case - YouTube
    ? 1:46
    https://www.youtube.com/watch?v=Mz7-k4G9HFg
    May 8, 2013 - Uploaded by Janome Canada
    Learn how to insert a front loading bobbin case. It's easier than you might imagine. Janome ... Janome HD-1000, Beginnersewing machine.
    How Do I Fix My Sewing Machine: Troubleshooting Your ...
    www.craftsy.com > Blog Home > Sewing Blog
    Nov 7, 2014 - Well, I've been teaching on Janome machines for about 6 years, and I ...Take the Trouble Out of Sewing Machine Troubleshooting! ... has fallen out of the take-up lever, which can happen if the machine was jammed along the way. ... of thread through the bobbin winding tension at the top of the machine.
    Bobbin Case Keeps Falling Out of a Sewing Machine ...
    www.thriftyfun.com/Bobbin-Case-Keeps-Falling-Out-of-a-Sewing-Mach...
Feb 09, 2016 | Janome Hd1000 Sewing Machine
Janome problem
The hook is placed in. Now, there is a bracket that goes in front of it. This bracket is locked by turning little knobs on each side. Now you can push the bobbin holder in firmly with the little handle pointed up. If you don't push hard enough it will fall out.
Jun 30, 2014 | Sewing Machines
Janome bobbin problems
try getting a new bobbin case
Mar 23, 2014 | Sewing Machines
Have Janome DC3050. Bobbin thread is getting caught on the hook shaped guard to the right of the bobbin. Hook race? I know threads got caught in bobbin and believe it bent or moved this. Now makes a...
I don't know your model but my Janome 6500 has a bobbin case held in by magnet on the underside and it will dislodge and move if there is a jam up. This then prevents it from forming stitches correctly. You need to lift out the bobbin case and put it back into position. With mine, when it has moved, the needle then strikes part of the case when it comes down. This often results in a burr in the plastic which then causes the thread to catch again even when the case is back in correct position.
There should be two marks, one on the case and one on the outside to align it to.
9k=
this is my bobbin case, and the cut away part on lower part of the image is the bit that goes into the machine away from you.
Feb 07, 2014 | Janome DC3050 Computerized Sewing Machine
Bobbin case catching thread
I believe that you are talking about the assembly that holds the bobbin case in. The bracket that holds the bobbin case in must be adjusted to allow the upper thread to slide by. Check if the thread will go by this area without "hanging up" while rotating the hand wheel. Also check your bobbin to make sure you have the right one. If it is too high or wide it will definitely be a problem.
Apr 17, 2017 | Janome SEW MINI Mechanical Sewing Machine
Janome 6500 jamming - cleaned out bobbin case - no help
Have you removed the bobbin holder and then put it back in lining up the little red markings on the right hand side? If the case has moved slightly then it will keep jamming and the bobbin thread won't clear to form a stitch. The case is held in place by a magnet and a stopper but it will dislodge if you have a bad thread jam, then it keeps happening even if you have removed all the thread because its not in position.
Check this solution for image how to remove and replace the bobbin case. http://www.fixya.com/support/t9289728-bobbin_seems
When you take out the bobbin case, carefully inspect it for any damage and burrs in the black plastic, if there are any then file them carefully out with a nail file or fine sandpaper, a burr will keep catching thread too. Or you may actually need to replace the bobbin holder if it has been pierced by the needle badly, they are about $35 or so.
You may also want to get it serviced. On my 6500 during its last service the technician added a little piece that is a Janome "after sale replacement" part. It is slightly longer than the standard part, and is a little metal bit on the left hand side of the rotary hook area which is holding the bobbin holder in place better. Haven't had a major jam up since this was fitted so you may want to get this fitted on yours too.
Jul 19, 2011 | Janome Memorycraft 6500P Computerized...
I have a Janome 4900Qc which has the sign Stop for Safety Purposes, this comes up really often, it has been back and been checked but no better now
Are you having thread jamming problems before you get this message?
I found that my bobbin holder which is held by magnets was being dislodged when I had a thread jam up, usually when I was trying to sew something very thick over a seam such as jeans hems.
Have you mastered removing the needle plate and the bobbin holder to clean in under it and putting this all back together again? With my 6500P, the needle had been striking the bobbin holder when it dislodged and rotated out of postion, the bobbin case had holes and damage to the plastic which was then catching the thread as the bobbin rotated making the jams happen.
Each time, I would dismantle the bobbin holder, clean everything, cut the jammed up threads, check the bobbin case and give the damaged bit a file with a nail file to make it smooth again, then put it back matching the red markings on the bobbin holder and the stopper, rethread and start over. I have bought two new bobbin cases too and taken it back to the dealer a couple of times over 5 years.
I've now learnt to not try to stitch over the thick seam intersections, I'll stop before, lift the pressure foot, move the work past the seam, then restart sewing. However, my machine was just serviced last week and it looks to me like the mechanic has added a part to hold the bobbin case in better, its like a little black lug on the left screwed into the outer housing. So perhaps Janome have addressed this issue with an aftermarket repair.
Apologies if this is telling stuff you already knew, good luck.
Mar 07, 2011 | Sewing Machines
My Janome one step is jamming on the first stich under the foot. I think it is the bobbin holder that has moved as it now comes out easily but do not know how to put it back in so it is secure
Raise the needle to it's highest position and this will position the shuttle so it is the correct position for the bobbin case to be inserted.
If this is a drop-in bobbin, the line-up is easy to see. Refer to the maintenance section of your manual.
If this is a rotary bobbin, make sure to hold the lever on the back of the bobbin case out as you insert it into the shuttle. The "arm" on the bobbin case points up.
May 01, 2010 | Janome Sew Precise Mechanical Sewing...
Janome 10000 bobbin case problems
make sure you hold the cotton so it doesn't go under and ball up
Feb 03, 2009 | Janome Memory Craft 10000
JI have a Janome 1100, and I have a problem with the bobbin case. I will be into my embroidery project and the bobbin case will jump and turn around sometimes causing my project to turn, and the needle to...
When you put in the bobbin case, be sure to press it in firmly until you hear it click into place. If you can't press very firmly, or are afraid of hurting your machine, simply lift the latch from the bobbin case, holding it open while you firmly insert the case into the machine. Then release the latch. You should be good to go. Hope this helps!
Jun 22, 2008 | Janome D'cor Excel 5018
Sewing Machines Logo
53 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
