Question about Dell E153FP 15" LCD Monitor
BLINKING GREEN LIGHT
MY MONITOR DOES NOT TURN ON.iT IS BLIKING THE GREEN LIGHT
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Dell Master
  • 848 Answers
MY MONITOR DOES NOT TURN ON.iT IS BLIKING THE GREEN LIGHT?
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
1521HSD1 715L1074 PWPC1521XXD1 Dell ADTV1521HSD1 Power Supply Backlight...
Posted on Feb 11, 2015
  • 11,361 Answers
You have shorted out transistors in the backlight inverter circuits.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd: www.lcdrepair.us
http://www.electronicrepairguide.com/dell-E153Fpc-lcd-monitor-repair.html
Posted on May 30, 2010
Error bliking green light an not printing
If only the power green light is blinking, you could try a printer reset that may correct the problem.
1. With the printer on, disconnect the plug from the electrical outlet.
2. Wait at least 3 minutes
3. Plug back into the outlet.
Dec 27, 2013 | HP Deskjet 2050 All-in-One Printer
Tv cycles on and off
Sounds like bad capacitors in nthe power supply, or maybe a regulator in the power supply. Have a tech take a look at this TV set for you, as there are no user replacable parts available in the TV set. Good Luck
Jun 09, 2007 | Panasonic PT-52DL52 52" Rear Projection...
Slim and secure blinking green light
Same problem here... Blinking green light. Purchased new battery and is still doing the same thing. Very disappointed-these cameras are not cheap. :(
Mar 10, 2012 | Summer Infant Slim Secure Handheld Video...
Mitsubishi HC 5500. While playuing the picture disappears. No picture only sound, also status and power lights start blinking red and green
Red and Green bliking with no picture means a service problem. But you might try cleaning the filters first and being sure that nothing is blocking air flow through the projector. Red status solid means replace the lamp, but that doesn't seem to be the indication.
Feb 09, 2011 | Mitsubishi HC5500 LCD Projector
Turn it on and the green light blinks but the
disconnect all the cables from the monitor except the power cable and turn it on if still the same issue the monitor has gone bad.
Mar 28, 2010 | Computers & Internet
Screenblinking blinking
yes replace ac adapter. light on ac adapter does not blink
Mar 07, 2010 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Monitor is black but power light is blinking green. Worked fine last night, but this morning screen was black and light was bliking. Suggestions? Thanks!
Firstly check the power cables nd VGA port is it proper or not nd then if this is proper then ur problem might be in RAM remove the ram and rub it with eraser nd insert it again nd check CMOS battery also ....u will surely get a positive result....
Aug 31, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E153FP 15" LCD Monitor Logo
299 people viewed this question
Alun Cox
