Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
My High Limit light comes on, along with service light.
It is not heating. what should I do next?
  • 64 Answers
Check your high limit switches. These can be found in the header. There will be two, and they are right next to eachother. You may pull them out and they may look like they are corroded or have gritty stuff on them. If that is the case, they will need to be replaced. However, this is usually an indication that the stud sensors in the header are corroded and the new sensors switches will again go bad. Unfortunately, the stud sensors are brass little posts, that were poorly made on some jandy heaters. They are available on a part, but near impossible to replace. So, it means you will likely need to replace the entire header or keep on replacing the high limit switches. HTH
Posted on May 30, 2010
  • aquatechpool Jun 02, 2010
    wow! bad advice??
My good man furnace model gmh80903bnca will not get to temp fan shuts off and burners keep burning then kicks off on high limit then starts process over but never gets to temp set at 655
If you have a switch that can manually turn on the fan, try it to verify the fan works. This is what I think is happening. The normal operation should be thermostat calls for heat, inducer fan comes on, pressure switch closes, igniter glows, main burner ignites and then in 30 or so seconds the fan comes on and stays on until the thermostat is satisfied. Once the thermostat is satisfied the burner shuts off and the fan runs for approx 120 seconds then shuts off. I think the control board that automatically turns your fan on is faulty. On most modern furnaces if the auto fan control fails and the furnace gets to hot and limits, when the limit opens and shuts off the burner it also energizes the fan motor to cool the heat exchanger.
Jan 13, 2018 | Heating & Cooling
The start button light is blue, on the screen is beeping the key. i can't use any of program. it shows one minute till the end of drying. what to do?
The exact definition of this error when the clean light is blinking means that your dishwasher is failing to heat the water in an allotted time. This problem can occur on Whirlpool, Kenmore, Kitchen Aid, Jenn-Air, and Maytag dishwashers. The error can be caused by numerous issues but the first thing you want to do is reset the control board.
-To reset the control board press: high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash. If you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
-All the lights will go solid at which point you press cancel to reset the board.
-If the control board doesn't reset, it's likely that you've just got a faulty control board and the control board will need to be ordered and replaced.
The next step in this process is to start a new cycle and see what happens. If the error code returns, then you'll want to reset the board again and check several things. The most common reasons for this error is because the water coming from your household is just too cold. The dishwasher is expecting 110 degree water to enter your dishwasher, so if your pipes are cold, the water may only come in luke warm. To correct this issue, just run your faucet next to the dishwasher until the water coming out is hot. On another note, make sure the dishwasher is washing with good water pressure. You can put a cup in the upper rack facing upwards and run a cycle to see if it will fill within 10 minutes of starting the cycle. If it doesn't fill with water then you know that the dishwasher isn't producing enough pressure which, in turn, will cause the water to not heat. You'd want to take your pump and motor assembly apart to clean inside if you had a loss of pressure.
You could also have a failed component including a faulty heater, control board, or high limit thermostat. You'd need to uninstall your dishwasher, disconnect power and lay it on it's back to check the resistance of the heater as well as the resistance of the high limit thermostat to confirm if they were bad or good. You should get tangible reading of between 5 and 30 ohms on the heater if it's good and less than one ohm on the high limit thermostat. If both of those devices check good, then replace the control board because that's the one device you cannot test.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times
Apr 16, 2016 | Dishwashers
My dishwasher clean light keeps flashing and wont run. it flashes 7 times and pauses then repeats. whats the issue?
This is an error code.
The error indicates that your dishwasher is failing to heat the water in an allotted time. The error can be caused by numerous issues but the first thing you want to do is reset the control board.
Jul 05, 2011 | Maytag Dishwashers
Dryer goes on and spins but no heat. I've opened up the back but what now? Is there a specific part that if blown would cut off the heat? Model is a small one - probably cost about $300 - don't know the...
The thermal cut-off at the top of the heater duct/housing blows when the high-limit thermostat below it fails to cycle the heating element on and off properly to regulate the heater temperature. This thermal cut-off along with high-limit thermostat including the cycling thermostat on the blower housing are wired in series with the heating element and power to it is cut when the thermal cut-off blows as a safety feature to prevent fire. Verify this condition by bypassing the said components. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 11, 2011 | Roper REX4634KQ Electric Dryer
Laars LT - "red" light
means calling for heat if heater doesn't come on check safety circuits
Feb 12, 2011 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Dryer quit heating no power to element what is wrong?
The problem is most likely the thermal cut-off and the high-limit thermostat. The thermal cut-off blows when the high-limit thermostat fails and since these parts are wired in series with the heating element, power to the heating element is therefore terminated. Check the continuity of the thermal cut-off and if it reads open, replace it along with the high-limit thermostat.
You can bypass the thermal cut-off and the high-limit thermostat for troubleshooting purposes. Join together the wires of each part and insulate it properly then reconnect power. The two components indeed need to be replaced if the dryer heats up. If not and still no power to the heating element, check the continuity of the heating circuit. Check the continuity/resistance of the heating element if there's power to its terminals but doesn't heat. Replace the heating element if it reads open.
Let us know if you need further advice. Just indicate the exact model number of the dryer for accurate troubleshooting tips.
Jan 23, 2011 | Kenmore 700 6972 Dryer
Sta-Rite Max-e-Therm pool heater -- cycling and HLS
make sure that you have adequate water flow going through the heater and that your water chemistry is balanced.
Jan 09, 2010 | Sta Rite Sr333na Max E Therm Pool & Spa...
I have a dyno glo rmc-fa100dlx forced air heater. It will light and work for a few minutes, up to about 5, then it will stop heating and the fan will keep blowing. any ideas? thanks!
If the unit comes on and runs but then shuts down, that sounds like an indication of a high limit trip.
Most, if not all, furnaces have high limit switches that keep a constant check on the temp inside the furnace or air handler. On most systems, once this high limit switch has been made (got to hot), the limit switch breaks control voltage to the heating device (strips, gas, fuel, etc.etc..). The blower motor continues to run until the high limit has dropped in temp and reset itself.
On some models, the high limit is a manual reset, meaning you need to reset the switch yourself or shut the unit off and then back on to reset it.
Check all filters and replace as necessary. Check the coils and fan blades for dirt build-up and cleanliness. Check motor belt (if applicable). If all these fail to solve the problem, then your issue either lies within the blower motor itself not moving enough air for proper heat transfer. Or the high limit switch itself is failing.
Jan 09, 2010 | Heating & Cooling
Our tumble dryer has no heat
check your cercite braker first and reset it,next make sure you have 240 volt's going to dryer.next un plug dryer.locate dryer element and use a continueaty meater to check element.also check high limit thermal switch,also check for bad wireing.most dryer's have two high limit switch's.if every thing check's out, than you nead to get a service call.
Nov 15, 2009 | Dryers
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
622 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
