Question about Ford Garden
Kohler 14 hp no compression
I was mowing with my older Ford garden tractor, which has a Kohler 14 hp engine. It made a clunk and now has no compression. I pulled the spark plug and the piston goes up and down, which I believe eliminates a broken rod. Anyone have any ideas of what is wrong and how big a job this is? I don't want to buy a new one right now if I can help it, but can't see investing $500 in a repair. Hoping it is an easy fix.
Thanks!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Ford Master
  • 917 Answers
Check the compression. it may just be a blown head gasket or a push rod may have broke or bent. possible a stuck valve or valve seat. if the engine still spins over by hand it should be a easy fix. and a cheap fix also if you do it yourself. it will require a few special tools and valve grinding compound but there are videos on you tube that show how to do this.
Posted on Jul 12, 2017
SOURCE: Repair Parts Manual / Book Service Garden Tractor
C I am thanking a lot for dealing with my matter and very much I am counting for your help in getting the list of the spare parts with catalogue numbers of my model of the garden small tractor.
I am greeting Ted
Posted on Nov 25, 2008
SOURCE: NO FORWARD NO REVERSE
I had the same problem so I looked under the mower and the belt that goes from the engine to the back of the mower was off so I pushed the clutch as far forward as I could and the belt went on it and it worked
Posted on Aug 09, 2009
  • 61 Answers
SOURCE: No spark in JD lawn tractor engine
it could just stuck, loosen see if moves reset points.
Posted on Sep 07, 2009
  • 1584 Answers
SOURCE: 26hp kohler garden tractor won't start, Has spark,
Have you checked for a good spark from plug, if in doubt replace spark plug.
Posted on Jan 26, 2010
  • 420 Answers
SOURCE: john deere 300 garden tractor hydrostatic drive will not work
check two things, make sure the by-pass rod is pushed all the way in and the drive belt from the engine to the rear end (tranaxle). If both check out ok do not attempt to service the tranaxle at home. have thet serviced by a dealer.
Posted on Jun 02, 2010
Vintage kohler k161 7 hp compression
According to this Kohler link, http://www.gardentractorpullingtips.com/engspecs.htm
the compression ratio is 6.2:1
Sep 02, 2016 | Cub Cadet Garden
I have a 214 kohler engine john deere lawn tractor, what point wires go to hot and the ground
if that is the Kohler 14 hp motor it may have the spark control untit on the motor cover. I recently ran into one like that and switched the coil out from a blown 20 hp kohler engine. I just taped up the excess wires and made sure they were not near any moving parts. The mower ran fine after that. Kohler wants about $160.00 for a spark control unit. There have been no repercussions since making the switch.
Apr 21, 2014 | John Deere Garden
Need to know what oil and petrol needed for best result.
I have been using Syntec 5/50 in a Kohler 14 hp. installed on a large commercial Snapper walk-behind since it was new in 1995. I mow 2 acres about every 9-10 days all season long.
Oct 19, 2012 | Garden
Uneven mowing
make sure the belt sits level there is adjustments for each side
Aug 20, 2012 | Craftsman YT 3000 42" Kohler 22 hp Gas...
I have a craftman lawn tractor with a 15hp kohler engine. Engines starts and runs fine After mowing for a while and then shutting it off the engine will not restart until it cool off completly. Any...
See if there as any difference in compression when the engine is cold verses hot. Also check ignition spark when it is hot. Unit could be vapor locking because of heat. Carb float could be suspect.
Sep 14, 2009 | Craftsman Garden
Electrical wiring for kohler engine
I have a Ford LGT with a 14 hp Kohler K321AS engine. Go to Kohler.com and download the service manual for the K321 engine. The manual covers all of the K type engines and gives diagrams and details of all the different types of ignition and electrical systems. It is free. JS
Jun 01, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Apr 28, 2009 | Garden
Garden Logo
134 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
