Question about JBL EON 15-G2 Powered DJ Speaker With EQ Speaker
Problem on the horn tweeters EON 1500
Hi, my name is Marcello Daff, I'm brazillian and I'm a singer as well. Years ago I bought some JBL products here in Brazil and they've been very usefull to my work. Recently my pair of EON 1500 has got a problem on the horn tweeters and they began to fail. I don't really know whether the problem is on them or whether on their frequency divisor. How can I know and where can I buy others ? Thank you.
  • 4234 Answers
SOURCE: JBL Eon 15 Blown Fuse
These fuses are most likely 3 Amp fuses. Please note that if the replacements blow as well, that there is a problem within the amp section that will require repair.
Dan
Posted on Aug 14, 2008
SOURCE: JBL EON 15 G2 clicks and pops
my son and i fixed an eon a decade ago that had this problem. we swept a sine wave through the audio spectrum and discovered it started barking somewhere around a low D on the piano.
Turns out the mains connection was intermittent right where it enters the eon from the wall. Soldered the ac power connections and the problem went away.
Posted on Sep 21, 2008
SOURCE: Tweeter not working on 15" EON G2
I had the same problem with no highs from my G2. I initally replaced the HF diaphram and powered it back up and it started smoking and burned out that HF diaphram.
I then found that I needed to replace the whole motherboard assembly as one of the HF chips on the motherboard had blown. Once I replaced the motherboard and the HF diaphram (again), the G2 was back in great working condition.
Wish I had tried ohm-ing out first before I blew the replacement HF diaphram.
So if you don't believe your HF diaphram is blown. I would investigate at the motherboard. I talked to a repair specialist where I ordered my replacement part and he said that those HF components go bad over time. As tough as the G2's are, over time they will need new parts, as the components begin to fail.
Posted on Oct 26, 2008
SOURCE: jbl eon
the eon woofer is designed to fit the small frame of the inside cabinet. The EV woofers look too deep to fit but you can try. I do think that the built in amps were set to work with only the JBL woofers so there might be a signal problem using the built in amp. The eon face seems to have their own screws to hold the grill so if they aren't holding you can drop some cement to help hold the srews in place. The front does not allow removal of the woofer so it seems whatever you do should not effect anything.
Posted on Nov 08, 2008
freetek
  • 5568 Answers
SOURCE: Speaker was dropped - Tweeter Magnet came off -
Clean the mating surfaces very well, mark on the side of the magnet (arrow or dot) which surface of the magnet was glued (shouldn't make a bit of difference, I'm just a little anal) and then use any brand of quick setting 'super glue.' This glue will not only hold well but will also introduce the thinnest film between the magnet and 'keeper.' Too much space between mating surfaces can weaken the field and reduce the efficiency causing an imbalance in volume relative to the other tweeter. If anything else is loose, the tweeter is junk because any shift of the voice coil will cause the speaker to distort or rattle.
If you need to replace any speaker ever, replace both channels or have possibly lousy matching between channels.
Posted on Apr 24, 2009
Jbl eon 1500 horn tests good 3.9 to 4.2 dc restance but will not work
You have probably blown a light bulb in the SonicGuard circuit. You will have to take the cabinet apart to check it.
Jan 05, 2015 | JBL Audio Players & Recorders
The tweeters are not working
The crossover caps may have failed, or the tweeters themselves burned out. Using a small 1.5 volt cell touched across the tweeter leads should produce a sound. If not- they are burned out.
Apr 11, 2012 | Harman Kardon Harman JBL LSR2328P Pair of...
I need to buy a tweeter for my speaker can you help me.
hi,
As it hve a horn tweeter no need to replace the whole unit. You will get the diaphragm. go the following page check the third item. Its the diaphragm for JBL EON 15-G2. An the order code is
DT-004.
http://www.goodhifi.com/MyDias/Diaphragms.htm
ok
Aug 03, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Jbl eon g2 not giving any low sounds only tweeter works
open it up and check cables leading to sub (large speaker) they're notorious for falling off - getting banged around
Feb 17, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
I installed a brand new tweeter in my JBL EON 15 G2 & the new tweeter blew. What else could be the problem?
These are "powered" speakers and any little bit
of distortion can be amplified enough to "blow" it!
Also the amp could be "shorted"! Have your JBL
dealer test it!!!
Apr 20, 2010 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Damaged JBL Eon15 Tweeter
you can probably by a generic type of motherboard from a shop like JAYCAR lookem up on the net ]
May 25, 2009 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Eon 15-g2 upper part of my jbl is getting hot
The tweeter is not the problem. The Eons use the vents below the tweeter to cool the amp and woofer. Sounds to me like you have a power supply problem in the amp, possibly a bad capacitor or diode. You have to check the amp for proper operation.
Feb 10, 2009 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL EON G2 15 loud noise.
The noise may be the reason why the speakers were available used. The tweeter may be defective.
Jul 22, 2017 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL EON 15-G2 Powered DJ Speaker With EQ Speaker Logo
199 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
