Question about Bosch HBL 642AUC Electric Single Oven
On bosch hbl 646 a uc, when I close the oven door the heat goes off with the heat light off. any suggestions?
5 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Bosch oven won't pre-heat/heat with door closed
Some oven has a door sensor, which prevents heating when door is open, evidently this is faulty, you need a service manual to identify and replace the part, If I find something I will post here.
Posted on May 24, 2008
  • 142 Answers
SOURCE: I have Bosch double oven HBL HBN and does not
sensors would not make it heat up any quicker element might be getting weak,but 10 mins to heat up is about normal.
Posted on Sep 28, 2009
barkencoa
  • 3463 Answers
SOURCE: Bosch HBL 645 oven door won't close all the way
I am afraid that the door hinges are non adjustable, and the only solution is to replace them as a pair.
There should be some kind of latch mechanism at the end of the hinge
where it is fastened to the door to compress the hinge to enable you to remove them.
Hope this helps.
Posted on Jan 04, 2010
espressonist
  • 1711 Answers
SOURCE: Bosch Singe Oven Mode HBL-645-A
The oven is secure undercounter by four screws which you can see when you open the door and are located on the body frame at the left and right.
After that you can pull it out completely so you can remove the top panel cover at where you can reach for the control panel.
Here we have a link with the parts diagrams you can see the other diagrams total 5 by selecting from the left.
We also one video on how to replace the element with a similar oven which however will give you an idea how is your oven and how to remove top internal cover.
Posted on Aug 28, 2011
I have a bosch Oven model HBL745A UC and the heating element at the back of the oven won't turn off.
Most likely part is the oven control board, it has relays on it . There is one stuck. IT is 2235 dollars to replace.
Dec 09, 2013 | Bosch HBL 745 Stainless Steel Electric...
Tip
Common heating faults with Bosch HBL 442 / HBL 446 single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBL 442 / HBL 446 Electric Single...
Tip
Common heating faults with Bosch HBL 742 / HBL 746 single oven
on Jan 19, 2010 | Bosch HBL 742 / HBL 746 Electric Single...
Hope this helps.
Jan 04, 2010 | Bosch Ovens
Sep 27, 2009 | Ovens
Bosch Oven Door Problem - doesn't close at top
On our oven (Bosch Evolution 700 Series HGS7152UC), the problem was getting worse and worse. I found it is was worsening simply because the hinges had started to come loose. I removed the door as suggested above, and although there are no adjustment screws on this model I tightened the now-loose hinge mounting screws. For each hinge there are three screws altogether: two (phillips heads) on the bottom of the door and one (torx head) on the inside wall of the door. After tightening those screws it is a lot better, only leaks as much heat as it did when it was new which is tolerable. Still a bad design.
Mar 02, 2009 | Bosch HBL 742 / HBL 746 Electric Single...
Bosch oven door does not close tightly, takes FOREVER to heat
All you need to do is replace the oven door hinges. as the springs are weak.
It is a fairly straight forward repair to do.
To obtain new hinges, got to:
www.bosch-spareparts.co.uk
or
www.espares.co.uk/bosch
Plz rate my solution.
Thankyou.
Jan 05, 2009 | Bosch HBL 745 Stainless Steel Electric...
Bosch HBL745A Oven door
My husband just figured this out.
- Follow Door removal instruction from the manual.
- There is a screw at the end of the hinge that can be adjusted.
- Adjust the screw to desired height.
- Secure lock nut.
Nov 14, 2007 | Bosch HBL 742 / HBL 746 Electric Single...
Bosch HBL 642AUC Electric Single Oven Logo
149 people viewed this question
Top Bosch Ovens Experts
ashburton
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
